eaglescout526
Administrators
    13
  1. Its a GM 2.8L V6. Garbage engine.
  2. Well its great as a utility which is the part I love. The part I hate is how I didnt realize how much I loved the look of a MJ without the topper but with the soft top. She gave off that kind of sport truck vibe and I liked it. So its a love/hate and I don't mind it. It will have its advantages at some point, I just got it not to long ago.
  3. 4.0L's are pretty abundant. Just gotta find a cheap pile of rust XJ for the swap.
  4. Calm down there Tommy tutone. Kinda wanted to say James Halliday in celebration of Ready Player Two's release. Great looking truck! Shame you plan to ditch the mighty 2.5L.
  5. *B1 TRIM STYLE B1 - CLOTH &&&&&&&& VNL BENCH SEAT -Q8 AGC APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JHA WINDSHIELD WIPERS - DELUXE(intermittent wipers) JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ PWB QWB RAF Radio - AM/FM Cassette SBA POWER STEERING SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJN 15" Aluminum Wheels Build date 6/21/88 Body code TL61 Will you be able to provide us a paint code on the firewall VIN plate?
  6. Finding the metal slaves is tricky but they can be had. The plastic ones are all too common. They explode from the poor u-clips holding the slaves pipes in place causing them to burst if the clips wiggle out.
  7. I think I’m looking at the older 242 shift bezel plates. They have the same shift pattern as the newer style and this style pictured above comes in AMC packaging so I think they just might be the older style. Actually I did some research and they are for the 228 which the 242 replaced in 87. The 228 has hi lock and lo lock along with 4wd meaning it was very close to the 242 in operation.
  8. Yeah I am not sure. The catalog says it’s just a t-case shift bezel. I might have to break out the ole paper catalogs.
  9. Anyone know which T-case this is?
  10. Every garnet part I have acquired have been darker in color than the firethorn. My only theory why that may be is age of the part, the colors and material slowly degrading and such but have not been able to really figure that out. I had some web guides that were darker than the firethorn, I have two garnet rear XJ belts that are the same dark color but those would be dark anyways. So I am not sure but I can say the panel will be darker.
  11. indeed it is. It will serve as a template for new door card backs when I go to cut them.
  12. No problem! Yes. I have one of their covers as well and I love it a lot. I just recently got a camper shell and I have a love hate with it.
  13. *X1 TRIM STYLE X1 - CLOTH BENCH -YY 153 Zone 53-Minneapolis 1AA U.S. Dealer Retail 5KN Metro Cars of Detroit ADL Skid Plate Group ALN Body Color Bumper Group APA Monotone Paint ARL BAY 105 Amp Alternator BCY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ Dana M35 Wide Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKF LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon NHM Speed Control PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z67 Left Front Spring Group XVI Z86 Right Front Spring Group XV Build date 9/25/89 Body code JL62. Yeah after seeing your truck makes me miss the sport truck look I had going with mine with the vinyl bed cover.
  14. Define a fix? I am in the same boat with trying to figure out why at certain intermittent speeds, they operate fine. But the moment you set the wipers to low or high, they drag and I have done about every damn thing I can think of other than bathe the entire linkage in lithium grease.
  15. Perks of working at a dealer. We have found late 88-92 MJ's to have the most accurate build sheet for their vehicle. Need a new buzzer? I have a couple blue ones.
  16. Huh, I guess yours is a bit longer than mine. Whoops! Better to have too much than not enough.
  17. *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 172 Zone 72-Portland 1AA U.S. Dealer Retail 5AM Largo Tracking 5KN Metro Cars of Detroit ADL Skid Plate Group ALN APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana M35 Wide Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE MUD &&&& SNOW TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 1/8/89 Body code JM62 1J7FJ36L6KL505999
  18. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR DDQ Transmission - 5-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY RAB Radio - AM/FM SBA POWER STEERING Build date 9/24/85 Body code JL62
  19. I have already deleted the other pics of parts off my phone but I got the older style rear XJ belts in garnet, medium blue and black along with some shift bezels and a 242 shift bezel, some switch panel block offs, 84-86 info center circuit boards, some V-belts for chunk and some instrument cluster sockets.
  20. Has selec-trac, D35 and 30, keyless entry, power everything, lighted visors, under hood lamp, headlamp delay, fogs, front plate bracket. Anything you want to know?
  21. Awesome! Glad to see you got them working. Have you found out the connector style yet?
  22. *C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -SA Charcoal 164 Zone 64-Memphis 1AA U.S. Dealer Retail 26C Customer Preferred Package 26C 2TC Customer Preferred Package 2TC 3VN Customer Preferred Discount 4BJ Wheel Credit 4HA Special Scheduling Condition I ALA APA Monotone Paint BAR 90 Amp Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ Dana M35 Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KER KWR STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PG5 Hunter Green Metallic QG5 Hunter Green Metallic Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TMW Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z82 Right Front Spring Group XI Build date 9/20/91 Body code JL61
  23. Kinda an idea. Have you tried the steam clean method? Something tells me that the engine may not have been serviced in a long while.
  24. Ok so my makeshift clutch idea kinda failed so I am doing the way another T-bird owner did it with gasket paper. Otherwise it kinda worked but it would stop catching when you would use the favorites buttons.
  25. More to come too. Those are gonna be wall hangers.
