13
1987 4 cyl MJ Rough running condition
eaglescout526 replied to jeepogeek's topic in MJ Tech: Modification and Repairs
I have original NOS AMC 2.5L O2’s if you’d like to go that route. The REM is easy to navigate. Nicks instructions for the device are pretty easy to follow. I believe it’s the bottom left button that will show each individual read out of each sensor. -
Roughly about $70
Theres three Mopar knock sensors left.
Makes sense. My grandmother still has the very same sets me dad and uncle played with. I wish to acquire them but can't yet.
Every time I see your Legos I can't help but think that yall have some of the 80's space sets judging by the colors of the greys.
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AGY Seating Group AHL HEAVY DUTY INSUL PACKAGE AJZ APC TWO TONE PAINT PACKAGE - II AWJ Visibility Group BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR CUF FULL LENGTH FRONT CONSOLE DGY Transmission - 4-Spd. Automatic,47RH EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAB Radio - AM/FM SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 1/21/86 Body code JP62
Replacement Heater hoses
eaglescout526 replied to 89 MJ's topic in MJ Tech: Modification and Repairs
1-52003880 2-52003881 4-52003882 5-52003876 6-52003877 7-52003878 Assuming you have retained all the Renix set up, these are the numbers. -
Want some part numbers? That’s how I found one for my AC setup. Its a Gates hose but it was cut to fit and it was bent where it was needed to be. -
So steam clean or water decarbonization as others call it involve getting the engine to operating temps and using a squirt bottle with the throttle body or the vac hose to the booster to ingest tiny amounts of water in which when water enters the combustion chamber, it blasts the carbon deposits off with the steam that was created. There’s a few videos out there that shows it working pretty well enough to give it a shot. I wonder if you have sticking valves. How filthy would you say the engine bay is? -
CA-pearl white.
MJ specific visor harness.
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
I know it seems like I am playing 20 questions but I just want to make sure you get the right harness and connector, do you know or have seen the plugs? I went through Comanche Dawn again to make sure my assumption on it having a factory dash harness was correct, didnt want to mess up there either lol. -
Makes sense. Alrighty! I will whip something up for ya, the visor is going on the passneger side, right? Is it going in your 91 or Comanche Dawn? If its the 91, I have no idea how much of the interior harness is the same from the Renix but I assume the visor used the same metri-pak connector. -
Interesting. Do you know which year the visor is from or no? It won't make the visor harness difficult for me to make, just won't utilize the ground from the dash harness. -
Painting the instrument cluster bezel
eaglescout526 replied to schardein's topic in MJ Tech: Modification and Repairs
It still hurts to see that XJ. -
Lol. Yeah it was sometime earlier this year that we all made a big deal on why that XJ was in the yard. Still not known I think. -
*X1 TRIM STYLE X1 - CLOTH BENCH -H9 131 Zone 31-Boston 1AA U.S. Dealer Retail 5AM 5KM ALM APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT ,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ Dana M235 Wide Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KKG LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black rear Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3 QS3 DOVER GREY MET C C SECONDARY PAINT - HS3 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 5/12/89 Body code JM62
Lol. We already did when this Jeep first popped up. -
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ AJS SUN/SOUND/SHADE PACKAGE AJY Popular Equipment Package APC TWO TONE PAINT PACKAGE - II BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGF H D A904 AUTO TRANS EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY RAC RADIO - AM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE Build date 2/18/86 Body code JM62
New clutch won't fully disengage
eaglescout526 replied to Manche757's topic in MJ Tech: Modification and Repairs
Yay for math! But I swear I don’t act my age at all. I swear at my generation a lot and disagree with everything they do and how it’s done. That being said, it’s probably also why they didn’t do a great job with your clutch. -
It’s a crude method utilizing water as a means to blast carbon deposits off the piston heads. It only works on a engine at operating temp. Thinking about it, doing sea foam would be the better choice or even some high octane fuel. -
I might try it this year with the camper. Or at least run some lights inside holy crap that gives me an idea!
Not many but if you watch the Motorweeks review of the 86 MJ you'll see it has a garnet interior with a garnet dash bezel. Something tells me though that the audience liked black a lot better. -
Damn the catalog and Chrysler for hiding certain part numbers. There is seriously alot of part numbers that only veterans would know what they are and for. I might have to dig and see if I can find the matching filler but that is nice. Really well done on painting the dash bezel. If I hadnt restored the one I have currently I probably would go to the dark charcoal for my bezel. I might have to find another one and test such. -
Yeah its right there right up to the chrome. I honestly never ever thought I would reference that picture again. I do miss that bezel and kinda regret selling it but I have a NOS brushed aluminum in its place. As does @CoastChief as a form of payment for the body moldings. Yes there was two of those left and I kept them a secret, oops. But both NOS pieces don't have the fillers either which is incredibly odd and the catalog doesn't have a part number for a brushed filler so I wonder if black ones were painted silver to match since it was a filler piece. But I am sure as hell am gonna get a dash bezel and paint it almond for Chunk. -
I had this NOS medium blue one a couple years ago. @saveevryjp1998 has it now but from 84-87ish they stopped and moved to the woodgrain, black with chrome paint, black, silver and of course, the coveted brushed aluminum. I have been tempted to do a charcoal one but it won't look right so I have stuck with black. But amazing work!
