13
Rickman's First Comanche... projects to follow.
eaglescout526 replied to Rickman's topic in Member Projects: Your Comanches
Hunter Green, Hunter Green, Hunter Green. -
That tan they offer looks a little on the nutmeg side to me.
No start, broke down. Help!!
eaglescout526 replied to coolwind57's topic in MJ Tech: Modification and Repairs
CPS every time lol. Is it a Renix one? -
CPS perhaps? Could be heat soaked. -
Makes sense. Wasnt sure if the OEM way was on the mind at first when you made that.
Like on the back side of the bench was a carpet like material for the fabric.
Actually I like the idea, It is pretty smart and better than relying on say 30 year old door card to hold the map pocket in place if you were to carry a FSM of Chiltons manual around. That being said, the fabric also has to be up to the challenge. Quick question, did you consider going with the original carpet like back when you made that?
Cost to probably put those in, plus you could get map pockets in the door.
Problem with that is you’d have more work than it is worth to do. Not to mention the MJs frame construction is not the traditional body on frame like you think. It’s a uniframe design. Meaning the bed is on a frame but the cab forward is unibody like it’s XJ sibling.
*X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 141 Zone 41-Cincinatti 1AA U.S. Dealer Retail 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Dual 700 Amp Maint. Free Batteries BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DCK 4SPD MANUAL TRANS - AISIN SEIKI DMD 3.55 Rear Axle Ratio DRJ Dana M235 Wide Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS EPD ENGINE - 2.5L I4 TBI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA 19 SPKRS SRT High Perf Audio SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z75 Right Front Spring Group V Build date 2/9/89 Body code TL61 Sold by POLO JEEP INC, MUNCIE IN
1987 Pioneer (INKY) 4x4 4.0 Auto
eaglescout526 replied to CGCWO's topic in Member Projects: Your Comanches
Hmmmmm. On the right track. -
Misfire under load when accelerating
eaglescout526 replied to gators_2006's topic in MJ Tech: Modification and Repairs
Right, I have a 2.5L, trying to help. That is the TPS that mounts to the back of the TB and it should be flush. You are right about the arm should just sit right on top of the TPS arm and actuate. The front is the ISA motor and that’s a different animal on its own. I’ll break out my TBI manual this evening to help provide info on the TPS. -
TPS voltage signal will make it act funny as it tells the ECU how much fuel it needs to dump into the engine to keep up with the acceleration and what not. The TPS is supposed to be flush with the TB and the linkage shouldn’t have any obstruction to the TPS arm. So you could’ve found your problem. But just keep an eye on it for a bit and see if it acts up. -
Lol i don't know. Just another reused code like always.
*X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 172 Zone 72-Portland 1AA U.S. Dealer Retail 5KK First American Title Insurance CO. ALA ALK APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PW7 Bright White Clear Coat QW7 Bright White Clear Coat RA8 Delete Radio SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z77 Right Front Spring Group VII Build date 8/29/89 Body code TL62 Sold by FRONTIER JEEP-EAGLE INC, PORTLAND OR
*D1 TRIM STYLE D1 - CLOTH BENCH -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 4AF 5AL Low Series Tracking APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ Dana 35 Wide Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z79 Right Front Spring Group IX Build date 5/8/89 Body code TL62 Sold by ROYAL-ZOCCO CORP, OXNARD CA
*A6 Seats - Vinyl High Back Bucket -YY 3LR ADE COLD WEATHER PACKAGE APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHK ENGINE BLOCK HEATER PXB QXB TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 6/16/87 Body code TL61 Sold by JOHNSON JEEP, ANCHORAGE AK
Turn signals (or blinky bits)
eaglescout526 replied to Jesse J's topic in MJ Tech: Modification and Repairs
Yeah that and the flashers that I can see that say “552” on them can be used for either hazard or turn signals. -
Welp I’m at it again. Another NOS parts purchase incoming in a week.
Both 552 flashers can be either or. According to Chrysler’s catalog. -
Name this part(link would be great too)
eaglescout526 replied to rylee144's topic in MJ Tech: Modification and Repairs
Not seeing it in the catalog. -
Ah, makes sense. Compression test ought to still help show the health of the engine. As far as the TPS, test it and see what it’s readings are with the key on engine off. You want to make sure it’s getting 5 volts to the sensor and the TBI manual says output and wide open throttle should be around 4.64(could be wrong, have to look) volts. -
Looking at an 88 MJ is it 2wd or 4x4?
eaglescout526 replied to Rickman's topic in MJ Tech: Modification and Repairs
You're welcome. Ohhh theres more than just one lol. -
You're comparing FCA crap VS AMC Engineering at its finest here though. Sure the JT(not tarnishing the original J-truck name) can carry your family or friends for the weekend trip but it has a lot more disadvantages when comparing it to a real Jeep truck. While the MJ is a single cab, you are getting a legendary engine/trans combo, more bed and simplistic reliability in one package. And an MJ this clean and this low of mileage is not a truck that you find laying around and what they are asking seems a tad high but within all the reason here.
