13
*ZZ TRIM STYLE ZZ - BUCKET SEAT -ZZ CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL Build date 12/4/85 Body code JL62 Damn, it has the good clutch set up and did you get the clock at least?
See now is the time to start scooping up all those lamps that don’t have the lens.
*Q7 Cloth Low-Back Bucket Seats -SA Charcoal 174 Zone 74-Denver 1AA U.S. Dealer Retail 5KR Midland Corporation ADA Light Group ADL Skid Plate Group ALR APA Monotone Paint ARM Radio AM/FM Cassette BAY 105 Amp Alternator BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUF Full Length Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2B STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KLH LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE Ambient Light LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Bumper MCA MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAF High Altitude Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 2/22/90 Body code JL61 Sold by LITHIA CO SPGS JEEP-CHRY INC, COLORADO SPRINGS CO
*B1 TRIM STYLE B1 - CLOTH &&&&&&&& VNL BENCH SEAT -Q8 AGC APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING &&&&&&&& LABEL NHQ Transmission Heater PB3 QB3 SBA POWER STEERING SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 7/31/87 Body code TL61 Sold by GIANT JEEP-EAGLE, VISALIA CA
*ZZ TRIM STYLE ZZ - BUCKET SEAT -ZZ ADA LIGHT PACKAGE AJZ CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGZ Transmission- 3-Spd. Automatic EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL RAF RADIO - AM/FM/MTR SBA POWER STEERING Build date 10/24/85 Body code TP62
Yeah thats also what I was thinking. Ill proceed to the next step and get it together and try to get at least the front pulleys together.
This makes me want to get down my original set that came with my MJ and fix them once these come out.
As far as I could see the choke shouldn’t be holding it open. But I can’t get it up to temp yet because I don’t have the cooling system running at the moment. I plan to get that slapped in and back together shortly. Encountered an issue with one of the t-stat/reservoir mounting bolt being messed up in the block. But it is a high fast idle on start.
What’s bad is I have a feeling it is the carb. I’ll give it a shot and see what happens. I have a feeling I put the throttle discs in the wrong spots.
Whoops. I left out the part that I did fully disassemble and clean the carb as it was pretty much stuck and not moving at the throttle plates. I’d like to think I rebuilt it right. The only thing that seems to elude me is this high idle. I haven’t done any adjustments other than linkage to get it to set right and more or less for the throttle closed thinking that the linkage is not adjusted and holding it open. So far no true adjustments have been made other than linkage and the fuel to air ratio screws.
So for those who may not know I have a ‘60 T-bird with the 352ci and an autolite 4 barrel. I got the engine running but I can’t seem to get it to come down at all. I’ve checked for vac leaks and can’t seem to find any that I know of and I adjusted the fuel to air ratio screws at the base and still nothing. My next step is to start making some adjustments to the carb and what not but I’m wondering if anyone who has more carb experience has any thoughts. what’s bothers me the most is this car ran 20 some odd years ago but then was parked. As far as what I have gotten into it, I haven’t ripped anything out that would’ve made it run nice and smooth. Now I know it can’t be because the engine doesn’t have a load on it as I don’t have any of the pulleys hooked up, could it?
Mysterious Wire Under Passenger Side Dash
eaglescout526 replied to ktmall07's topic in MJ Tech: Modification and Repairs
Ah. But yup it’s for the radio. Guess you’d never know since the radio doesn’t get used. -
That plugs into the other silver plug by your hand. It goes from the radio to the antenna. -
I’ll give it a quick test today.
89’ Pioneer MJ Barn Find
eaglescout526 replied to oleskool's topic in Member Projects: Your Comanches
Flare nut wrenches! -
'90 Eliminator (Puddy)
eaglescout526 replied to Jtslick89's topic in Member Projects: Your Comanches
Oh of course! Wouldnt be a Jeep if it wasnt always something. -
I’ve been wondering how this MJ has been doing. Too focused on the XJW? -
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Got the rear interior assembled, not entirely happy with how the rear hatch closes on the bottom piece but it is what it is. can't complain too much. I also removed the upper half of the rear bench and the seat belts. Upon removing the third lap belt I found this gem: Pretty sure its a piece of the 80's but still was a neat thing to find tucked under the belts. Now to keep cleaning and make my way forward. -
ever had your fridge konk out while you're away on vacation?
eaglescout526 replied to Pete M's topic in The Pub
My parents fridge while my dad was out just stopped running. Fans were spinning and everything except the compressor. Luckily it’s a GE unit and I found some things to do some diag and found the compressor controller had failed. So my parents order a new controller I installed it and the fridge came to life. The fridge isn’t even that old either. -
I’ll get this switch out Tuesday. Also since I have one missing the back half, I’ll show you it’s internals.
Yup! Meant to look the night I found it in the catalog. I’ll get it tonight.
Soooo thats where those two went.
Never mind I found the part number. 56002281 GM number: 25509432(yes Chrysler actually lists the GM number in the catalog)
I think I have one laying around with all my spare cruise parts. I for the life of me can not find that switch in the catalog anywhere.
That explains why I couldn’t find them all in one section haha.
