13
1986 v6 fuel pump replacement
eaglescout526 replied to Jeff Rodgers's topic in MJ Tech: Modification and Repairs
Wait. The 86 2.8L had a FI sending unit and not just a sending unit for the gauge? Weird. But yes a short bed 18 gallon tank will not fit in a long bed without some sort of modifications. Course it might fit but only two straps are needed to hold it. But the 2.8L is a mechanical pump from the factory. Unless someone rigged an FI sending unit to work. -
Uh so apparently one of my lists now consists of parts that are/were at a now defunct dealer. Jasper CDJR doesn’t seem to be in business(or they might be under the name of tutton) anymore as none of the parts in my list are popping up in the locator. I will keep an eye on this.
I will be working on posting them this evening and descriptions and where they go.
Help appreciated. Fuel pump issue
eaglescout526 replied to Johnfishin1's topic in MJ Tech: Modification and Repairs
As 89 MJ said. Just depends on how you drive her. Drive her hard and fast, 16mpg easy. Drive her like a grandma and you might see higher. -
Yup thats the one. Change form idiot light cluster to a 5/6th or a full? Theres few write ups on it but you need the right year cluster and the sensors for temp and oil. 84-86 have a different speedo connection than the 87-90 clusters but you can swap out the cable to the newer style and use an 87-90 clusters. Otherwise yes that fuel gauge is known to be a bit more sensitive to the fuel sloshing around. -
No problem! As for the bouncy gauge, clean your grounds and its also mostly the float in the tank that will do that. I guess you have the idiot light cluster? -
So if you crawl underneath, you will see the drive shaft and the fuel tank. The sending unit hoses and wires face the drive shaft. So yeah the lock ring holds it in place. Its an all in one unit which measures how much fuel is in the tank and has the fuel pump attached. No.2 is what holds it in. -
Nope. Thats the beauty in it. Remove the lock ring and the assembly should come right out. Now judging by the sounds of it, you have the 2.5L 4cyl correct? -
I would recommend testing the fuel pump to ensure it still functions. Fuel pumps don’t like to sit in fuel and in turn won't work. They gum up and can just not work at all just from sitting for so long. -
Lol I mean y’all could’ve also easily said keep ‘em. I’ll probably work on labeling the parts.
So these days money seems to be a bit tight and it has been a long while since I have done a NOS parts dump since buying a house and all. Anyhow I have several and I mean several lists/word docs of the part numbers I have collected from my tenure while working at the dealer. Now I’d love to sit down and rescue all that I can from the dealers but it’s not feasible at the moment. 99% of the part numbers are Jeep/AMC parts that still float around. The other 1% is likely to be things for other Mopars. Would y’all like to see these lists and take a gander at the parts that still exist out there? I’d have to go through and label what each number is but there’s so many parts still floating around.
Ball joint inserts
eaglescout526 replied to 70barracuda's topic in MJ Tech: Modification and Repairs
That being said, this issue is only applicable to 4wd knuckles. I found that late 87 and what I can guess would be past 90 2wd knuckles don’t have the insert. At least the knuckles on my 88 doesn’t have them but the knuckles for the 86 2wd beam I have had them as they basically are 4wd knuckles with spindles in them. -
I would do both the cluster ground improvement and check the bulb in the cluster and make sure it’s contacts are good. In high moisture areas you could have some corrosion going on. And I'm sure cruiser will chime in and say to clean the connector behind the headlamp regardless as it is not a weatherproof plug for some reason or another.
Has the EPA really gotten that bad? Ugh.
21 slot grille on ebay
eaglescout526 replied to Pete M's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Ha! You can’t tell me that this guy doesn’t know what he has when he’s got it valued that high. -
I have a set as well that I have restored if 500 MJ can’t find his.
Like the bezels that go around the lamps on a factory bumper?
1J7FJ66L4LL199601 1J7FJ36S3NL199601 One of two options. its either a 90 or a 92
Meh. Its just Peugeot pushing its euro agenda in the US.
STOLEN COMANCHE in San Fran
eaglescout526 replied to jazzyjeeper's topic in MJ Tech: Modification and Repairs
That’s unfortunate. Best part is that it’s a color that stands out so that’ll be an easy find…hopefully. -
*ZZ TRIM STYLE ZZ - BUCKET SEAT -ZZ AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGW DDQ Transmission - 5-Speed Manual DMN 4.18 Axle Ratio EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE PS, That is an AMC35. Not a Dana. Build date 7/26/85 Body code JM62
*X3 -YY AGC Black Ram 1500 Sport Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DDJ 5SPD MANUAL TRANS A881 (JA-41) ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING &&&&&&&& LABEL PE4 Colorado Red QE4 Colorado Red SBA POWER STEERING TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 7/14/87 Body code TL61 Sold by ROBERTS JEEP EAGLE, LA PUENTE CA
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ AJT RADIO PREP GROUP AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery -Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGX TRANSMISSION - 3-SPEED AUTOMATIC EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HC0 All Vehicles W/O Air Cond HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE Build date 8/27/85 Body code JM62
Bruce has to enroll at MJ academy
eaglescout526 replied to brucecooner's topic in Member Projects: Your Comanches
Lol fair enough. But AZ seems to have a really weird Jeep culture. Like yes there was plenty of Jeeps around me growing up. I saw mostly XJs, ZJs and YJs, but none were ever jacked up and lifted from what I recall. Now a days its JKs, JLs and all the other little Jeeps Chrysler has produced and you might be able to find some stock YJs, XJs(97-01) TJ's and the other classics driving around but the drivers of them look to be starting out or its just their 'car' from point A to B. Funny enough, been driving my MJ for 6 years and I have never had a JK owner actually recognize what I was driving until a month ago. It was actually an enjoyable moment. Anywhoo back to the MJ at hand!
