87Chief
Everything posted by 87Chief
Right WJ lower control arms?
87Chief replied to 87Chief's topic in MJ Tech: Modification and Repairs
Thanks! -
I was wanting to get some WJ lower control arms and was searching rockauto for some new ones and search for 1999 Jeep grand cherokee 4.0L limited and was wondering if those were the correct ones? Here is the part number if anyone wants to look to make sure DORMAN Part # 520320 Thanks :brows: Mike
or one from an MJ with a tachometer...?
Steering column movement
87Chief replied to ole yeller comanche's topic in MJ Tech: Modification and Repairs
yeah my friend and I did this awhile back.. Took about 3 hours to take apart and put back, but it was our first time doing it. And we didn't feel like taking the whole thing apart so we were able to get atleast 2-3 bolts and just tighten those up and it's much better now. No wobble no more. -
You could probably have a leak somewhere, maybe master or slave cylinder. If it's gunked up I would do a fluid exchange. Just push the pedal, bleed it, then repeat adding new fluid as necessary
Someone on here has a tuffy center console on here... I'm sure it's from a XJ though..
I am looking for a gauge cluster for my MJ to swap for gauges, I want the RPM gauge and everything. I really want one from a 2.5L with 5 speed.. You can email me. littlemlittle@gmail.com Thanks! Mike
Cluster you're looking for will have all gauges but will have a blue background instead of white
What's the most miles you got from a full tank?
87Chief replied to Jerry's topic in MJ Tech: Modification and Repairs
About this ford injectors... what year and models? And I'm not sure what my mpg is because mt fuel gauge is messed up (sending unit) -
Piston Skirt.... how much work to replace or....?
87Chief replied to guckingfuy's topic in MJ Tech: Modification and Repairs
get a 2.5 from a YJ -
What's the easiest way to seal a fuse box leak?
87Chief replied to Jomanche's topic in MJ Tech: Modification and Repairs
ever figure it out? -
Great deal on the black interior!
Difference in Valve Covers? (For the 2.5)
87Chief replied to Zenobian_84's topic in MJ Tech: Modification and Repairs
Not yet, my idle was a little rough before it though... I had some blowby, but don't anymore. Plus I didn't have to be so careful about cracking it... I cracked two that I tried to put on since they were so old, so I wanted aluminum and it's much better -
'88 Olympic Pioneer - the addiction continues
87Chief replied to Rymanrph's topic in Member Projects: Your Comanches
If you ever need help, let me know, I could take a trip down and help. I think I'm about an hour or so away.. If you catch me on my days off haha -
I useda 94 wrangler 2.5 on mine.. I got the little fitting on the side of it that screwed in for the CCV system... It was the vacuum part, and the back of the cover I just got some heater hose from auto zone and a hose clamp and rigged it to the back of the air filter housing.. I got new bolts and washers also, because the old bolts will not fit on the 94's valve cover.. Hope this helped, I did have a picture... It's in my build thread, got the project thread and go to 1987 jeep comanche chief and there are pics there. -
I have not gotten any yet, but I do need to, the bench is after about 2 hours of sitting in it gets very uncomfortable, well every seat does... It might just need new padding.
I will have to go to walmart or get some from work tomorrow.. I finally fixed the wobble in my steering column. My friend and I did tonight, it took us awhile, but it was our first time tackling it... Everything is tight and I'm happy with it. Now I just need to go to the JY and get a ZJ tierod and some new tie rod ends..
You can replace the valve cover with an aluminum one from a 87-94 2.5 wrangler.. That's what I did... Was tired of mine cracking. I got new bolts and washers and hasn't leaked yet..
Thanks would that be at a parts store? I've seen the felpro high performance ones.. And that's hilarious about the same jeeps. It's a jeep thing I guess haha
I have looked for the one piece gasket for the 2.5l oil pan gasket.. But can't find one, anyone have a part number? If they didn't make one for 1987 do I put rtv on both sides of the cork?
A list of things when rebuilding..?
I am going to start by replacing most of my seals... Rear main, Oil pan gasket, because it is very oily under the truck.. Anyone have a list of part numbers for some good seals/gaskets? Thanks -
smell of gas in the morning
87Chief replied to crazycommanche's topic in MJ Tech: Modification and Repairs
I had the same problem. I filled up on gas got it full. 2 hours later girlfriend took me somewhere then we cam back where I parked it. Gas all over the ground. Found out my the seal on my sending unit, where the red and black wires go into, was leaking. Probably same thing you have.. -
Where did you get your carpet?
So.. I went to take my exhaust manifold off and the bolts in the front, were very loose. I hardly turned them and they came apart. What would that mean? I'm thinking about taking the whole engine apart and seeing if it is warped. Any suggestions? Thanks
I put the old One back in and now it's reading about 60psi when I start it up
