87Chief
Everything posted by 87Chief
Dome Light wiring question...
87Chief replied to 87Chief's topic in MJ Tech: Modification and Repairs
I see but I only have2 wires for my LEDs.. Red and blAck I don't know what to do with the striped.. -
My father and I restored this lovely trailer... Took frame off and everything... It was great... http://www.wranglerforum.com/f118/jeep- ... 331-2.html
I am doing the LED upgrade in the DIY section, but I figured more people will look at this one in the Tech section.. I am having trouble figuring out where these wires go... LED pad... and the Pillar wiring... (black/white, black, and red) I am wondering which of the wires goes where... Pretty sure red/red black/black, but what about the black and white? Thanks
Ok, here is where I am stuck... I took some pics, so I hope this isn't hi-jacking... Two wires from the LEDS... And from the Pillar light... (black/white, black, red) What do I hook up to what? THanks
I have everything except the dome light package... I don't understand how you drill it in... Where do I drill into? My stock light just kinda pop out. No drilling needed. Also the wires in the back... Which ones do I use? Thanks everyone.
Changing the whole column is probably easier than taking it apart. Yeah I figured that.. What would I have to take off?
I have a question... I am thinking about buying a 89 tilt steering wheel column, will it fit in my 87 2.5? I'm pretty sure its from a 4.0. Are the plugs the same (like plug ins and everything) Also, how hard is the job to do? What do I need to take off and such? I know the lower dash, gauge cluster... Thanks
Could I get a set up for the pcv system from a Cherokee at the junkyard? Will a 4.0 airbox fit where the 2.5 is? Thanks
Would it be easier just to switch out the steering hweel column with another that doesn't wobble?
Yeah, says in certain measurements... like 100" 40".. I don't know which to get.. Also, how would I go about installing it??
Where would I go about finding a speedometer cable for a 2.5L 4 cyl 1987 Comanche Chief... I have checked Rockauto, but it says only for auto trans... I have a 5 speed...
Ok. Thanks I'm getting a 98 wrangler 2.5 aluminum and hoping it will fit. For the pcv, could I get a set up from a Cherokee ?
But isn't there any year for Cherokees or wranglers?
Ok I'm still having problems with my valve cover... What years an what models of Cherokees and wranglers will fit my 1987 2.5L valve cover?
Hello guys, gals, I was wonder will my camper top fit on a 86 Toyota pick up shortbed. Mine is a shortbed also, 87.. The measurements are about the se. I just want yalls point of view
:popcorn:
Lol. Yeah we have a lot of engines sitting around in the class shop we use for 'practice rebuilding' just to make sure we get it right. I guess times have changed since then huh ;) jk. But for $20.. Can't beat that.
Yeah thanks guys. The reason I'm doing it is because I want like a new engine for my daily driver... And my class is in the rebuild stage and only allow 3 engines in and classmates are bringing in 350's and stuff and I won't have room for my little 4 cylinder. So I'm going to tear mine down at home and try to keep up with the class, though we have groups and I'll be working alone, but eventually I'll get there.
Hello all, I know some of you have done a engine rebuild and was wondering if you could tell me what all I need? Like the sizes of the pistons and all... It is a 2.5L 4 cylinder... I've been doing some research on rockauto.com and not sure what to get... Like the sizes and everything... Thanks for the help before hand!! Mike
Thanks, In class the other day my instructor said if the speedo cable is loose or not in all the way your speedometer could go back and forth rapidly... Mine does that... Should I pull it out, spray with some brake cleaner then dip some trans fluid on it and put it back in? But would that cause the rpm gauge not to work??
Looking for the cheapest, yet effective lift.
87Chief replied to 86ComancheXNate's topic in MJ Tech: Modification and Repairs
How much actual lift will you get with the zj coils and chevy shackles?
