87Chief
Everything posted by 87Chief
Oh, I just pulled his eBay store up and didn't see any for MJ's
So I guess he pulled out?
What's the easiest way to seal a fuse box leak?
87Chief replied to Jomanche's topic in MJ Tech: Modification and Repairs
Are you talking about the fuse box itself? Because I have this same problem. I sprayed some water on the fuse box under the hood, moved inside and saw water coming down the back side of the fuse box.. -
I need a driver side turn signal connection. The bulb in mine broke off. Shipping to 29715 I live in fort mill, sc. Thanks
New Fuel Sending Unit... Where to be found?
87Chief replied to 87Chief's topic in MJ Tech: Modification and Repairs
Will a 1987 Cherokee fuel sending unit fit for a 4.0 with 20gallon? Advance part number is E7091S -
finally got fuel pressure, but still no run.
87Chief replied to snacob14's topic in MJ Tech: Modification and Repairs
Check fuel injectors... Make sure you have enough ohms on the connection. Injectors might be dried up and not able to send fuel to the pistons. -
starts at $3500
87Chief replied to Paul Bruchal's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Anyways... Comanches? Oh yeah, like this one at the top of the thread, it looks alright. -
I hardly ever see needles stick out the headliner lol. I'm been wanting to do the headliner, but with my other jeep and money just won't let me. I got some pads and rotors today, I should be able to install them tomorrow.
2.5L Valve Cover replacement
87Chief replied to Sir_Brando's topic in MJ Tech: Modification and Repairs
Yeah it was a vacuum fitting. I was going to rtv it but my friends works for jeep that goes in my class so I got him to get me one. And I was afraid that the rtvwoukd plug the hose. -
It's been awhile... I have been driving this thing a lot lately, it is starting to have some issues, and my TJ's muffler just went out, started rattling today, so I'm stuck on both, but I have done a few upgrades, I got my valve cover situated. I just wish I could get a 4.0L :( any free ones out there? lol near me? lol Here's some pics of the valve cover. Had to jimmy rig, some parts. lol It is from a 2.5L wrangler... So I went to the dealer and asked for this part, it was $10.. Also did the LED lights.. :) ohhh me likey. (And yes, my headliner is held up with multi color needles.. lol)
Sorry it took awhile, but here is what I did.. I bought a 91 Cherokee, or wrangler (prob wrangler, doesn't matter all the same) valve cover off ebay for $25, guy didn't have the grommet so I went to autozone, got a filler cap, some hoses, and rtv.. Got everything situation, then noticed there was a hole that something screwed in, went to the dealer and asked them. They got me the part for about $10.. And here it is.. -
Yes, it will directly bolt on. I did mine not long ago, I got some heater hoses from autozone for the lower air cabin hose to the back of the valve cover and then some vacuum hoses for the front of it. I had to go to the dealer to get my parts for it. I also went and got some new bolts and washers for the cover too. If I get a chance I'll snatch a pic for you.. It might be later tonight.. -
I'll be bringing it to school tomorrow. If I get a chance to bring it in the shop. What should I look for/do for the problem?
How do I check the ujoints..? Is there a certain way other than just looking at them? lol Do i shake it up and down, left right? Thanks
When I go about 25-30 mph I shift into 3rd gear, I hear this kind of grinding noise from tailpipe (well back on truck, heard with window open).. But once I push the gas more, it goes away, then let off it comes back.. It does this in 4th too... It usually happens about 15 minutes of driving... Any suggestions? I brought the truck into class to look at it and the exhaust wasn't welded on to the pipe, just had muffler clamps, my instructor welded it and we did a smoke test to make sure no more leaks, but this still happens... (it was doing th noise before this too...) Thanks
87 2.5 - suddenly, rough idle!
87Chief replied to AMCJeepMJ's topic in MJ Tech: Modification and Repairs
Could be a misfire... Just throwing it out there. lol -
Smoke coming from exhaust pipe...
When I start it up for about 15 minutes, smoke comes out of the tailpipe... I believe it is white, so it would be coolant, correct? I should be able to do a coolant compression test tomorrow and finally do my alignment, for free :) -
Thanks a lot! Would it not be the piston rings? -
Steering Column Compatibility
87Chief replied to bajajunkie's topic in MJ Tech: Modification and Repairs
So, I have a 5spd 4wd tilt that has the 'wobble' in it.. Can I go to the junkyard and get a tilt from a say 90 Xj auto? Does anyone have pics of what you need to 'bypass'? -
I only had time to do 3 spark plug holes today for the compression test... I started with the one closest to the cab and went forward.. Closest to cab results: 75 on first and 150 on last next: 75 on first and 150 last next: 80 on first and 135 on last.. I didn't get a chance to get to the last one because it would've taken too long to move the compressor and such because I had to go to work. Are the compressions in range or no? Thanks -
I pulled the dipstick, it doesn't look milkshakey at all, it is a little black though. I waited for the thermostat to open today and I didn't see any bubbles come up afterwards, it just kept overfilling.. I just emailed my instructor at school to see when I could bring it up there to do a compression test.. Compression test is taking out the spark plugs and turning the engine over correct? -
I looked at the coolant also and it was kind of rainbowy... lol Like oil is in it but it was still bright green.. -
It didn't shoot out that much... It just start filling over the the part where the cap goes slowly... Now if I could see what it did when i start it up with the cap off... I might be able to tell you
