Everything posted by DesertRat1991
Hauled off +900lbs of tree trunks in my short bed. The metric ton leaf packs from Geneal Springs just laughed and shrugged. Plenty of clearance left.
How to Straighten Bumper
DesertRat1991 replied to James92's topic in MJ Tech: Modification and Repairs
I got a nice result working with a metal refinisher to straighten a bumper. They usually have experience doing restoration work for the hotrod community. They know how to patch, stretch and shrink metal and can also handle powder coating or chrome dipping. Bodyshops just want to turn and burn insurance work. What you really want is a restoration. Strip, straighten and refinish. -
Rear Bumper near Long Island, NY, Southern NH or northern MA.
DesertRat1991 replied to Salvagedcircuit's topic in Wanted
Wow, haven't seen that one before. I like it better that better than Fry/Westin. -
33in tires on 4.5in lift
DesertRat1991 replied to JimManche17's topic in MJ Tech: Modification and Repairs
You can fit up to 33x10.5 without cutting if you properly adjust your bumpstops and turnstops. I'm on metrics that are roughly 32x10.5. -
Budget front recovery points?
DesertRat1991 replied to jakesmog's topic in MJ Tech: Modification and Repairs
It may work in an emergency, but there are better designs out there. Perhaps most importantly, that shackle doesn't appear to have a rating stamp. It may not be safe for recovery use. Try to find a mount that is machined out of a solid chunk of steel with no welds. It's also better if the part inserted in the receiver has 4 holes so that you have the option of running the shackle either horizontal or vertical. Having options is nice if you ever need to do an off-center pull or a pull across an elevation change. Something like this: Shackle Hitch Receiver, 2 inch 42000 Lbs https://a.co/d/6rAShbv -
So what kind of lights are you running?
DesertRat1991 replied to Spinnakerblue89's topic in MJ Tech: Modification and Repairs
I thought the stock headlight pattern was terrible. Outside city limits where streetlights were few and far between, the shadows and hotspots wreaked havoc on my eyes. Truck-Lite LEDs with the Putco harness felt like a night vs day difference. Stock low beam: Truck-Lite low beam: -
I think this is your best bet. The OEM mudflaps are too small and dinky looking for a lifted rig with tall tires, and they don't hang low enough to the ground to be functional.
Dana 44 Rebuild Kit Reccomendations?
DesertRat1991 replied to Warren99's topic in MJ Tech: Modification and Repairs
Well, they don't look like 10" D44 drums. What is the part number on the backing plate? It should be visible in the area cicled below. You may also want to look for a 7 digit BOM number on your axle tube [XXXXXX-X]. That will tell us roughly what years/models your axle could be sourced from. -
Welcome! Quite the dilemma. I'm somewhat partial to color matched camper shells.
That's a really odd bird you're describing. OEM D44 should have 10" drums but it is possible to swap 9" D35 hardware on to a D44. As the saying goes... "a lot can happen in 30 years." Best way to sort out what you have would be to find the part numbers on the backing plates. Quick question, are your drums smooth around the outside, or do they have cooling fins? -
Dang.... RiP
Another happy OTRATTW customer... L-series illuminated by the unused footwell light wires in the OEM harness (orange/black). This ties their illumination to the rest of the cabin lights.
Definitely read the fine print. In some states you can't haul or tow anything in an antique vehicle. For me, it wasn't worth rendering my truck useless as a truck.
Custom Gaskets for HVAC
DesertRat1991 replied to H3ADBANG4L1F3's topic in MJ Tech: Modification and Repairs
Interested..! There's a wagon load of reasons why I haven't ripped apart my dash to install A/C yet, but this would address one of them! -
91 4x4 iliminator shorted 5spd 4L HO
DesertRat1991 replied to Elm Robichaud's topic in Member Projects: Your Comanches
Nice truck! Too bad you couldn't save that color matched shell. -
1991 H.O. stock exhaust
DesertRat1991 replied to HoboBones's topic in MJ Tech: Modification and Repairs
The Walker parts were well made, but I seem to recall several members have tried to source Walker MJ parts through various vendors only to find they are hopelessly backordered. It's possible that Walker has finally made another run but parts were scarce about a year ago. Maybe call around a bit before you get your hopes up. -
Grand Total for Calendar Year 2023: 1 Just the one I passed by on a road trip. No junkyard finds near me this year. That's kinda scary.
Just got an e-mail: Warn $150 rebate extended to Dec. 31
It was a Ramsey 6k. Note that curb weight for a bone stock MJ is ~3000lbs.
General Rule #1: Minimum winch capacity is 2x vehicle weight including all mods and all your adventure gear. Then, add a fudge factor for the extra load created in sticky situations. In some ways, deep mud can be worse than rocks because of the suction created. General Rule #2: Maximum winch capacity is the largest winch you can afford, that will actually fit on your rig. Larger winches will offer a more generous duty cycle for quicker recoveries. The down side is that they weigh more and your charging system may not be able to handle the load. If a winch exceeds the capacity of your charging system it does not "fit." These are small trucks but a properly kitted rig with larger tires, armor, gear and passengers will be knocking on 4500-5000lbs before you know it. I would say an 8k winch is a conservative option, but 10k to 12k is a more comfortable choice for an offroad XJ/MJ. Side note: You just missed some killer Black Friday deals on Warn winches. They were like $200 off this weekend.
While on a roadtrip back in August, I spotted this guy headed southbound through Maryland. This is the only new MJ I've spotted this year (not counting repeats I've previously seen around my local area). Slim pickin's this year.
Facebook. He wasn't hard to find at the time (2018ish?). He was doing business as Detours of Maine, making parts for the Toyota market. According to Google, looks like his business reputation took a major hit during the COVID years. That's unfortunate.
Yah, I contacted him a few years ago, after he relocated to Maine, to ask if he would do another run and he declined. That said, this place is awesome. Another one turned up! It's 1/3 the weight of my current winch bumper, provides better approach angle than a front mounted hitch and doesn't require cutting our front fenders. I have no problem slotting an easily replacable bumper cover but fenders are off limits. It really is a shame this solution is out of production. *cough* @krustyballer *cough
The correct link ends for rear load valve
DesertRat1991 replied to robfg67's topic in MJ Tech: Modification and Repairs
