14
It did? Right after refreshing the ICU to coil contacts? Whooda thunk it?
weird power problem..... (I know, crazy right)
cruiser54 replied to starkizer's topic in MJ Tech: Modification and Repairs
Time to do this. Actually it was time a long time ago. LOL Renix Ground Refreshing The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, and wasted money replacing unnecessary components. The components grounding at the dipstick tube stud are: Distributor Sync Sensor, TCU main ground, TCU “Shift Point Logic”, Ignition control Module, Injectors, ECU main ground which other engine sensors ground through, Oxygen sensor, Knock Sensor, Cruise Control, and Transmission Sync signal. All extremely important stuff. The factory was aware of the issues with this ground point and addressed it by suggesting the following: Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. Scrape any and all paint from the stud’s mounting surface where the wires will attach. Must be clean, shiny and free of any oil, grease, or paint. Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn’t hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Reinstall all the wires to the stud and tighten the nut down securely. While you’re in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, and reattach securely. Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver’s side of the firewall. This cable is undersized for it’s intended use and subject to corrosion and poor connections at each end. First off, remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Reattach securely. Remove the other end of the cable from the rear of the head using a 3’4” socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely. A suggestion regarding the braided cable: I prefer to add a #4 Gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18” long with a 3/8” lug on each end works great and you can get one at any parts store already made up. Napa has them as part number 781116. A further improvement to the grounding system can be made using a #4 cable, about 10” long with 3/8” terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. Napa part number 781115. If you want to upgrade your grounds and battery cables in general, contact Jon at www.kelleyswip.com. He makes an incredible cable upgrade for a very reasonable price. Revised 11-28-2011 -
Are we sure we're taling about the IAC? IAC has electrical connections, but no vacuum connections.
Turn signals stopped working
cruiser54 replied to E4Marty's topic in MJ Tech: Modification and Repairs
You have 2 identical flasher units in the fusebox. One is for Hazards, one for turn signals. Do this. Turn the hazards on and look at the fusebox. Put your finger on each of the round silver flashers plugged in there. The one NOT clicking at this point is the turn flasher. Swap the flashers and see what happens. -
Try this: Renix Jeep ICU/Coil contact refreshing The contacts between the coil and the ICU on your Renix Jeep can become corroded and loose causing a complete or intermittent no-start condition. I recommend the following procedure as a maintenance precaution to insure this is eliminated as a possible cause now and in the future. The coil is attached to the ICU by two T20 Torx bolts. Remove these two bolts and lift the coil up off the ICU. You will see 2 pins and 2 sets of contacts. Clean both the pins and springy contact pieces with a good electronics cleaner. Squeeze the springy contacts closer together with some needlenose pliers. Apply some dielectric grease to the contacts and bolt the coil back on to the ICU. While you’re right there unplug the connectors from the ICU and inspect the pins in the harness connector. Make sure the pins are not retracted into the connector. Spray out the connector and the receptacle of the ICU with the same good electronics cleaner you used earlier. Apply dielectric grease to the connectors and plug them back in. I feel this procedure should be performed at least once in the lifetime of a Renix Jeep. Revised 11-29-2011
Headlights and taillights?
cruiser54 replied to kawaboy13's topic in MJ Tech: Modification and Repairs
Try poking around on www.eautoworks.com for the lights. The taillight bulbs I suggested can be purchased at Napa. -
Just do the cleanup of the ground at the firewall. You're not gonna SEE the problem. -
Double post. Ooops. -
Just for fun, check the ground cable that goes from the firewall to the back of the head. Using a 15mm wrench, remove the bolt holding the cable on to the firewall. Scrape the paint off the firewall down to bare metal where the cable attaches. Polish up the cable end and reattach securely. -
4.0, 242 engine replacement question 1988
cruiser54 replied to mknherhappy's topic in MJ Tech: Modification and Repairs
Good advice here. I'll add something since I've done 2 mid 90s HO to Renix swaps. You can use the HO head. Intake ports are off slightly. Probably no more than most factory matches between manifold ports. Use the Renix gasket. Swap Renix dizzy, flywheel, valve cover, etc on to new motor.. -
Bulb wattage in the 55-60 range is good. Hella and Phillips are good brands. For dual filament bulbs as in tail/turn signal/brakes, I use 2357s. They're a heavy duty version of the old 1157s and are brighter. I've tested them side by side at night. For single filament bulbs like reverse lights, I use 795 bulbs. They have the base of the old 1034 with a halogen globe on them. As for general brightness, it's always good to polish your lenses. I use Meguiar's plexiglass cleaner followed by their polish. -
inside cab lighting
cruiser54 replied to jamespwsullivan's topic in MJ Tech: Modification and Repairs
Those lamps ground eventually at the overloaded instrument panel ground described in the following write-up. BUT, there is a connector for them called a C118 under the left side of the instrument panel and behind the kick panel. Improving the Instrument Panel Ground The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver’s side dash. If you lay on your back and look up under there with a flashlight, without wearing a hat, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ¼” or 5/16” head on it. This ground point is responsible for handling the ground circuit for the following items: Dome lamps, Seatbelt and key warning, trans comfort switch, wiper switch, headlamp switch and delay module, fog lamp switch, cargo lamp switch, all instrument panel grounds and illumination, power windows and door locks, cruise control dump valve, and a few more things. The problem is that where the ground point is located does not have a good contact with the chassis where the ground should be. The solution is simple. Make up a jumper wire with #10 gauge wire about 10” long. On one end, crimp on a ¼” round wire terminal. On the other end, crimp on a 3/8” round wire terminal. Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point, one over the other. Look above the driver’s side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely. **Special note for Comanche owners: Make your jumper wire 12” long and attach it on the driver’s side kick panel close to the fusebox on the 8mm stud.** Revised 11-29-2011 -
Turn signal indicators
cruiser54 replied to foreman1063's topic in MJ Tech: Modification and Repairs
I just followed your write up on adding the IP ground jumper wire when I replaced the fuse panel. Unfortunately, did not fix this one issue. I'm thinking maybe the problem is in the gauge cluster. :dunno: Does your volt gauge read higher? -
turn signal issue!
cruiser54 replied to SantaCruzComanche's topic in MJ Tech: Modification and Repairs
Try this: Improving the Instrument Panel Ground The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver’s side dash. If you lay on your back and look up under there with a flashlight, without wearing a hat, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ¼” or 5/16” head on it. This ground point is responsible for handling the ground circuit for the following items: Dome lamps, Seatbelt and key warning, trans comfort switch, wiper switch, headlamp switch and delay module, fog lamp switch, cargo lamp switch, all instrument panel grounds and illumination, power windows and door locks, cruise control dump valve, and a few more things. The problem is that where the ground point is located does not have a good contact with the chassis where the ground should be. The solution is simple. Make up a jumper wire with #10 gauge wire about 10” long. On one end, crimp on a ¼” round wire terminal. On the other end, crimp on a 3/8” round wire terminal. Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point, one over the other. Look above the driver’s side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely. **Special note for Comanche owners: Make your jumper wire 12” long and attach it on the driver’s side kick panel close to the fusebox on the 8mm stud.** Revised 11-29-2011 -
Try this: Can't hurt and can only help. Improving the Instrument Panel Ground The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver’s side dash. If you lay on your back and look up under there with a flashlight, without wearing a hat, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ¼” or 5/16” head on it. This ground point is responsible for handling the ground circuit for the following items: Dome lamps, Seatbelt and key warning, trans comfort switch, wiper switch, headlamp switch and delay module, fog lamp switch, cargo lamp switch, all instrument panel grounds and illumination, power windows and door locks, cruise control dump valve, and a few more things. The problem is that where the ground point is located does not have a good contact with the chassis where the ground should be. The solution is simple. Make up a jumper wire with #10 gauge wire about 10” long. On one end, crimp on a ¼” round wire terminal. On the other end, crimp on a 3/8” round wire terminal. Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point, one over the other. Look above the driver’s side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely. **Special note for Comanche owners: Make your jumper wire 12” long and attach it on the driver’s side kick panel close to the fusebox on the 8mm stud.** Revised 11-29-2011 -
Fuel pump fuse and relay
cruiser54 replied to Whisslaren's topic in MJ Tech: Modification and Repairs
I checked my 90 MJ last night and if you use the starter relay as a reference, the posted illustration is bass-ackwards. -
Just so ya know, it's a real good possibility the relay illustration is wrong. As in they have the relays listed backwards. -
Found Trans - What do you think?
cruiser54 replied to 87MJTIM's topic in MJ Tech: Modification and Repairs
How much does he want for the whole thing? -
Excellent point!!
:( Thanks cruiser , I thought the same thing but was paranoid about MJ electrical gremlins unknown to me . On the positive side , I might as well get the alternator re-wound to 100 amp + at the same time :yes: :cheers: Gord Here's something worthwhile to do so your gauge is more accurate: Improving the Instrument Panel Ground The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver’s side dash. If you lay on your back and look up under there with a flashlight, without wearing a hat, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ¼” or 5/16” head on it. This ground point is responsible for handling the ground circuit for the following items: Dome lamps, Seatbelt and key warning, trans comfort switch, wiper switch, headlamp switch and delay module, fog lamp switch, cargo lamp switch, all instrument panel grounds and illumination, power windows and door locks, cruise control dump valve, and a few more things. The problem is that where the ground point is located does not have a good contact with the chassis where the ground should be. The solution is simple. Make up a jumper wire with #10 gauge wire about 10” long. On one end, crimp on a ¼” round wire terminal. On the other end, crimp on a 3/8” round wire terminal. Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point, one over the other. Look above the driver’s side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely. **Special note for Comanche owners: Make your jumper wire 12” long and attach it on the driver’s side kick panel close to the fusebox on the 8mm stud.** Revised 11-29-2011
I've done the #1 swap twice. Easy. Use the Renix manifolds, valve cover, dizzy and flexplate/flywheel. Simple.
Acts very similar to my 87 just before the diode/rectifier bit the dust inside the alternator.
