Well the most important issue I'm having is that the switch for the vents only works in the off and only runs on defrost regardless of postion. Is the selector the switch is connected too the culprit?
My driver side front speaker is somehow causing the sound to cut out from bass or volume. The odd part is, it's only when the door is shut that it'll cut out, with it open the sound works fine. I've only got the +\- wires hooked up to the aftermarket speakers, the black wire on the connector isn't hooked to anything.
