14
Major Electrical Issue... BE AFRAID!!!
cruiser54 replied to pilecenturyfarm's topic in MJ Tech: Modification and Repairs
quadruple post -
double post -
I'm building one. Drove my first one in about 1990 or so. Pretty wild one though. It was a project MJ built by Jeep Racing. Hesco 4.6 with a Paxton supercharger and Electramotive programmable fuel injection. Shortbed 2WD, lowered with wide tires and IMSA type flared fenders. Screaming yellow in color. I believe it went to the crusher after a few months.
Actually, it's Murphy's site but feel free to check it out. He's posting all my write-ups there. If I were you, I would do the Ground Refreshing and Relay/Connector refreshing right off the bat. I'll provide them here for you. What year is your Comanche BTW? Renix Ground Refreshing The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, and wasted money replacing unnecessary components. The components grounding at the dipstick tube stud are: Distributor Sync Sensor, TCU main ground, TCU “Shift Point Logic”, Ignition control Module, Injectors, ECU main ground which other engine sensors ground through, Oxygen sensor, Knock Sensor, Cruise Control, and Transmission Sync signal. All extremely important stuff. The factory was aware of the issues with this ground point and addressed it by suggesting the following: Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. Scrape any and all paint from the stud’s mounting surface where the wires will attach. Must be clean, shiny and free of any oil, grease, or paint. Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn’t hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Reinstall all the wires to the stud and tighten the nut down securely. While you’re in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, and reattach securely. Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver’s side of the firewall. This cable is undersized for it’s intended use and subject to corrosion and poor connections at each end. First off, remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Reattach securely. Remove the other end of the cable from the rear of the head using a 3’4” socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely. A suggestion regarding the braided cable: I prefer to add a #4 Gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18” long with a 3/8” lug on each end works great and you can get one at any parts store already made up. Napa has them as part number 781116. A further improvement to the grounding system can be made using a #4 cable, about 10” long with 3/8” terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. Napa part number 781115. If you want to upgrade your grounds and battery cables in general, contact Jon at www.kelleyswip.com. He makes an incredible cable upgrade for a very reasonable price. Revised 11-28-2011 I suggest unplugging EVERY electrical connection in the engine bay you can find, whether engine related or not, and spraying it out with a good electronics cleaner, visually inspecting the terminals, and adding dielectric grease before plugging it back together. Be sure that the connectors to the ballast resistor mounted near the air cleaner housing are clean and tight. ALL of the relays should be removed, the terminals wire-brushed until shiny, and the receptacles sprayed out with contact cleaner. Then dielectric grease should be added before plugging them back in. I do this on every Renix era Jeep I purchase or work on for someone else. Revised 03/15/2012 -
Be sure the CPS wires aren't touching the exhaust manifold. Check and see if the wires are tight on the ballast resistor mounted on the driver's side inner fender. You coulda bumped them while working on the manifold.
Nice catch, Matt!!
Might try this first: Improving the Instrument Panel Ground The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver’s side dash. If you lay on your back and look up under there with a flashlight, without wearing a hat, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ¼” or 5/16” head on it. This ground point is responsible for handling the ground circuit for the following items: Dome lamps, Seatbelt and key warning, trans comfort switch, wiper switch, headlamp switch and delay module, fog lamp switch, cargo lamp switch, all instrument panel grounds and illumination, power windows and door locks, cruise control dump valve, and a few more things. The problem is that where the ground point is located does not have a good contact with the chassis where the ground should be. The solution is simple. Make up a jumper wire with #10 gauge wire about 10” long. On one end, crimp on a ¼” round wire terminal. On the other end, crimp on a 3/8” round wire terminal. Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point, one over the other. Look above the driver’s side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely. **Special note for Comanche owners: Make your jumper wire 12” long and attach it on the driver’s side kick panel close to the fusebox on the 8mm stud.** Revised 11-29-2011
Ground Refresh Cable Size
cruiser54 replied to Optimaldave's topic in MJ Tech: Modification and Repairs
The wrong sender would peg your gauge IIRC. Do yourself a favor and get the good stat from the dealer. Little pricey but makes the Jeep warm up quickly and keeps the temp stable. 83501426. -
Vacuum canister question
cruiser54 replied to jasongreg28's topic in MJ Tech: Modification and Repairs
Start tracing the hoses. Most common place is behind the battery that they split. -
Care to elaborate. Did you upgrade the harness or just plug them into the stock harness? :cheers: The harness first, for sure. I recommend the harness upgrade for 2 reasons. One is you will have brighter headlights and an excellent upgrade path to follow in the future should you decide to. Secondly, the harness eliminates a high amp load of the headlight circuit running through undersized wires going through the headlight switch causing premature failure of the switch. You know when it's gonna fail, don't you? At night!! The supplemental harness is probably easier to install than a headlight switch is to replace. Not to mention the fact that many times the headlight switch plug melts down shortly before the switch does and further muddies the waters.
88 MJ idle issues,.. Seems like a miss 2.5L
cruiser54 replied to JENSSEN's topic in MJ Tech: Modification and Repairs
Same effect. Vacuum leak. Glad you found it. -
That's what I was thinking of suggesting to the OP. Those vac hoses near the TB are notorious for rotting and causing all sorts of problems. I bought an 86 MJ because a guy couldn't figure it out and just wanted to dump it. When I went to pick it up, I brought some vac line. Installed it, started the Jeep and drove away. -
auto tranny issues
cruiser54 replied to rollovercomancheguy's topic in MJ Tech: Modification and Repairs
Is your transfer case in Neutral then? -
auto tranny issues
Clarification, please. Did you install the converter on the engine or the trans first? -
I put split-loom over mine. I hate yellow!!!
Have you installed the harness yet?
You will like the headlights and harness as long as you use the e-code Autopals.
Get that stud tight. It's super important!!! -
Me, too. But two 6 gauge cables will be fine, especially having one from the critical dipstick tube stud to the chassis. Actually, I have a 4 gauge from the stud..... -
Probably be fine, but if you've got more cable left over and get put ends on it, do this. Make another cable to run from the dipstick tube stud to the 8mm stud on the passenger side inner fender just below the upper shock mounting area. -
1986 2.5 Rough Low Idle
cruiser54 replied to CaffeineTripp's topic in MJ Tech: Modification and Repairs
I bet this will work for you. Renix Jeep C101 Connector Refreshing The C101 connector on 1987 and 1988 Renix Jeeps was a source of electrical resistance when the vehicles were new. So much so that the factory eliminated this connector in the 1989 and 1990 models. The factory recommended cleaning this connector to insure the proper voltage and ground signals between the ECU and the fuel injection sensors. We can only imagine how this connector has become a larger source of voltage loss and increased resistance over a period of almost 25 years. The C101 connector needs to be cleaned at least once in the lifetime of your vehicle. Chances are it’s never been done before. Almost every critical signal between the engine sensors, injectors, and the ECU travel the path through the C101. The C101 is located on the driver’s side firewall above and behind the brake booster. It is held together with a single bolt in it’s center. To get the connectors apart, simply remove the bolt and pull the halves apart. You will find the connector is packed with a black tar like substance which has hardened over time. Take a pocket screwdriver or the like and scrape out all the tar crap you can. Follow up by spraying out both connector halves with brake cleaner and then swabbing out the remainder of the tar. Repeat this procedure until the tar is totally removed. This may require 3 or more repetitions. Wipe out the connectors after spraying with a soft cloth. If you have a small pick or dental tool tweak the female connectors on the one side so they grab the pins on the opposite side a bit tighter. Apply a true dielectric grease, not the stuff that came with your brake pads, to the connection and bolt it back together. Revised 11-29-2011 -
Not that I'm so much worried about spraying TB cleaner on anything inside the engine bay, just that it's a bit hard to find any leaks on vacuum hoses and lines with it, along with carb cleaner and soapy water. So I'm under the assumption that no matter the year or engine, all Comanches had the C101 connector that was just plain ol' junk? In 89 they did away with the c101. TB cleaner should work perfectly to find any leaks.
