14
aw4 swap, pending deal: VERY IMPORTANT!
cruiser54 replied to ftpiercecracker1's topic in MJ Tech: Modification and Repairs
I don't believe they had the AW4 though. -
Napa 272310 is an upgrade for the fan clutch.
comanchie 1988, 4.0 Litre HELP
cruiser54 replied to Comanchie Mike's topic in MJ Tech: Modification and Repairs
This is great. We got to poke fun at you AND help you fix your Jeep. Welcome to Comanche Club. -
Runs Like Poop in Closed Loop
cruiser54 replied to flint54's topic in MJ Tech: Modification and Repairs
I eliminated the vacuum line from the TB to the MAP on both my Renix Jeeps. Ran one from the intake manifold directly to the MAP and tapped and plugged the TB opening with 1/8" plug. Had an extra hole in the intake where I had removed my IAT when I moved it to the air cleaner housing. -
Comanchie Miguel: Comanchies are generally pink and have frills around the fender openings. Seriously though, check your CPS. -
h/o 4.0 block with renix intake will it look?
cruiser54 replied to asm4mcc's topic in MJ Tech: Modification and Repairs
First off, ain't no 25 horses difference. It's more like 8 at the most and it isn't from just the head. This was written just for the OP. I've done more than a few of them. Any questions, post them up. Cruiser’s HO into Renix Swap This swap is easier than some will lead you to believe, generally those who have never done it. Those of us who have done it, like myself, will share with you the things that need to be done for a successful swap. Just think of it as swapping in a long block. The HO and Renix have some differences but none that can’t be overcome very easily. Any HO engine from an XJ or ZJ through 1998 can be used. One running change was that the rear of the head was no longer drilled and tapped for the temperature gauge sender beginning in the 96 model year. The sender can be relocated to the threaded hole in the thermostat housing taken from the HO engine. You’ll have to extend the wire to that location. Some brave souls even drill and tap the HO head for the sender. You will be using the intake and exhaust manifolds from your Renix, along with all your sensors and wiring. Since the intake ports of the HO are slightly different, you use the Renix gasket. Exhaust ports are identical. You will need to use your Renix distributor as it is different than the HO because they use different fuel management systems. The flywheel or flexplate from the Renix must be used so your CPS gets the correct signals. The valve cover from the Renix allows you to keep your CCV system intact and requires no modifications. The HO block will have a plug in the coolant galley on the driver’s side of the block, closest to the front, which needs to be removed so your Coolant Temp Sensor can be installed in it’s place just as it is on the Renix. It requires a 5/16” square drive or a modified 3/8” drive that has been ground down to fit. Do this before installing the engine. As for the knock sensor, which is located just above the oil pan on the driver’s side of the engine about mid way, all the blocks I’ve seen are threaded for it. If not, I’ve heard they may be drilled but not tapped. Tap the hole if that’s the case. Revised 07/24/2012 -
Have you tested it and determined it is bad? Renix CPS Testing and Adjusting Renix CPSs have to put out a strong enough signal to the ECU so that it will provide spark. Most tests for the CPS suggest checking it for an ohms value. This is unreliable and can cause some wasted time and aggravation in your diagnosis of a no-start issue as the CPS will test good when in fact it is bad. The problem with the ohms test is you can have the correct amount of resistance through the CPS but it isn’t generating enough voltage to trigger the ECU to provide spark. Unplug the harness connector from the CPS. Using your voltmeter set on AC volts and probing both wires in the connector going to the CPS, crank the engine over. It won’t start with the CPS disconnected. You should get a reading of .5 AC volts. If you are down in the .35 AC volts range or lower on your meter reading, you can have intermittent crank/no-start conditions from your Renix Jeep. Some NEW CPSs (from the big box parts stores) have registered only .2 AC volts while reading the proper resistance!! That’s a definite no-start condition. Best to buy your CPS from Napa or the dealer. Sometimes on a manual transmission equipped Renix Jeep there is an accumulation of debris on the tip of the CPS. It’s worn off clutch material and since the CPS is a magnet, the metal sticks to the tip of the CPS causing a reduced voltage signal. You MAY get by with cleaning the tip of the CPS off. A little trick for increasing the output of your CPS is to drill out the upper mounting hole, or slot it so the CPS bracket rests on the bell housing when pushed down. Then, when mounting it, hold the CPS down as close to the flywheel as you can while tightening the bolts. Revised 07-30-2012
Didn't get the TPS wet did ya?
Use the following instructions and check the CPS: Renix CPS Testing and Adjusting Renix CPSs have to put out a strong enough signal to the ECU so that it will provide spark. Most tests for the CPS suggest checking it for an ohms value. This is unreliable and can cause some wasted time and aggravation in your diagnosis of a no-start issue as the CPS will test good when in fact it is bad. The problem with the ohms test is you can have the correct amount of resistance through the CPS but it isn’t generating enough voltage to trigger the ECU to provide spark. Unplug the harness connector from the CPS. Using your voltmeter set on AC volts and probing both wires in the connector going to the CPS, crank the engine over. It won’t start with the CPS disconnected. You should get a reading of .5 AC volts. If you are down in the .35 AC volts range or lower on your meter reading, you can have intermittent crank/no-start conditions from your Renix Jeep. Some NEW CPSs (from the big box parts stores) have registered only .2 AC volts while reading the proper resistance!! That’s a definite no-start condition. Best to buy your CPS from Napa or the dealer. Sometimes on a manual transmission equipped Renix Jeep there is an accumulation of debris on the tip of the CPS. It’s worn off clutch material and since the CPS is a magnet, the metal sticks to the tip of the CPS causing a reduced voltage signal. You MAY get by with cleaning the tip of the CPS off. A little trick for increasing the output of your CPS is to drill out it’s mounting holes with the first drill bit that just won’t fit through the original holes. Then, when mounting it, hold the CPS down as close to the flywheel as you can while tightening the bolts. Revised 11-29-2011 -
Key off, got voltage at the stud? Key on, got voltage at the yellow wire? If yes and yes, it should charge if the alternator is good.
No. On the GM alternators, the voltage regulator is built into the alternator. The ECU has nothing to do with it. If the battery tests good and the alternator tests good, there's obviously a wiring problem in the vehicle. And according to the OP, the wiring is good...........
smoking out tail pipe oil burning
cruiser54 replied to rollovercomancheguy's topic in MJ Tech: Modification and Repairs
Not long. -
Get yourself a can of throttle body cleaner and spray around the intake manifold and throttle body. If there's a vacuum leak there, you'll know it when the spray hits it.
No. If the alternator is good, it should be charging if you have voltage at the stud all the time and 12 volts at the yellow wire with the key on.
Have you checked for battery voltage at the threaded stud on the alternator and for 12 volts at the yellow wire in the two-wire plug at the alternator with the key on?
Renix I-6 high revs at startup
cruiser54 replied to jamespwsullivan's topic in MJ Tech: Modification and Repairs
Excellent idea. -
It's not hard to test a TPS. For the issue you guys are having, use the flat 3 wire connector for diagnosis. RENIX TPS ADJUSTMENT Before attempting to adjust your TPS be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up. IMPORTANT NOTE: With the Key OFF, and using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS. The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. Wiggle the wiring harness where it parallels the valve cover and also over near the MAP sensor on the firewall. If you see more than 1 ohm of resistance, or fluctuation in your ohms reading, some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed. MANUAL TRANSMISSION: RENIX manual transmission equipped XJs have a three-wire TPS mounted on the throttle body. This manual transmission vehicle TPS provides data input to the ECU. The manual transmission TPS has three wires in the connector and they're clearly embossed with the letters A, B, and C. Wire "A" is positive. Wire "B" is ground. Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Adjust the TPS until you have achieved this percentage. If you can't achieve the correct output voltage replace the TPS and start over. AUTOMATIC TRANSMISSION: RENIX automatic transmission equipped XJs have a TPS with two connectors. There is a flat three-wire connector, same as the manual transmission vehicles have, and it is tested the same as the manual transmission equipped vehicles—FOR ENGINE MANAGEMENT RELATED ISSUES. However, the automatic TPS also has a square four-wire connector clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU. FOR AUTOMATIC TRANSMISSION RELATED ISSUES. Check the four-wire connector side of the TPS. If you have ENGINE issues check the three-wire connector side of the TPS. For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced. Revised 05-28-2012 -
4 bangers have ISC, Idle Speed Controllers and 6 bangers have IACs, Idle Air Controllers. They work completely different from one another.
That doesn't sound good at all. Perhaps wrong bearings or the thrust bearings installed on the wrong journal?
Throttle Position Sensor aka TPS is probably failing. But, I wouldn't do anything else until I had refreshed your grounds and cleaned the c101 connector as they can add resistance to the TPS circuit and cause exactly what you describe. Have a multi-meter? If so, post back and I'll post up some instructions to deal with the ground and c101 issues. -
Whaddya mean "won't crank"?
I think yo uhave to replace them shen they stick like that. Check it out.
Isn't there an ISC motor that the throttle linkage uses as a stop? ISC=Idle speed control.
cant find replacement E brake
I think the photos are fine. It would be great to find a solution to the e-brake issue. -
There was a recall on them for popping off after being set. Cracker, I'm interested in your fix.
