Just got thru replacing the power steering pump on my '87 2.5. I wanted to swap the one I had where the resevoir was bolted to the radiator frame and connected to the pump by hoses, to one like you're showing.
Going over a half dozen blocks I decided the main mount like you're showing in the pic, is the same for all '87-90 engines. They made the pump itself and the pulley different to match the years, engines.
You should have it like new in two or three days. Welll, maybe a week. Actually the 2.8 is not all that bad of an engine. Don't expect to much from it and don't push it. I have a '86 with the 2.8, 5speed and 95,000 when I got it.At 115K it started smoking so bad I parked it. Was going to drop a 2.5 into it and found a wrecked S10 with a low mileage, good running 2.8 so I just went with it.Good luck. Jim :thumbsup:
There are several different methods to be used when electrical trouble shooting. This one is about as basic as you can get. Get a piece of wire long enough to reach from the battery to the fartherest light on the truck. Left rear TL. Attach a clip on one end. This will clip onto the pos bat post. If you have or can get a test prod, use it. If not a straight pin, a safety pin, anything that can puncture the wiring insulation and or the rust, corrosion on the terminals.. Now if you can reach bare metal at the socket touch the wire to it. The bulb should light.If not then follow the wire back to a plug. See if you're getting voltage at the plug.The biggest cause of electrical problems is corrosion. Separate all the connectors and inspect them for corrsion. If your the cautious type you might want to install a 10-15 amp fuse in the lead. Me? I get sparks, I just jerk. Good luck.
Give some kid a buck to sit in the truck and hold his foot on the brake pedal.
Get a 10 inch long 5/8th diameter bolt. Remove a spark plug. Screw the bolt into the plug hole until it contacts the piston top.
Park sideways on the hill side.
Park the truck at the bottom of the hill and walk up.
Nope.It's still burning out of control. And the wind isn't helping any. And it IS NOT a April Fool joke. In this part of the country, one does not joke about prairie fires,
