Everything posted by mikekaz1
1991 short bed metric ton DD build
mikekaz1 replied to mikekaz1's topic in Member Projects: Your Comanches
Rear flares are on now! -
Cut out the rot and put some patch panels in And reluctantly used some bond to even things out from the old stuff -
jeep mj with 33s and stock gearing yes or no?
mikekaz1 replied to eyepod's topic in MJ Tech: Modification and Repairs
33" and 4.10 on my TJ and I love them. 33" and 3.55 on the MJ and it works. -
Brush guards and bumper comparability
mikekaz1 replied to Comanche 87's topic in MJ Tech: Modification and Repairs
I know mine doesn't mount to the bumper bracket or frame. Its just to the bumper sheetmetal. So although it looks nice. Not much actual protection... so instead of just hitting my bumper. If I got hit it would just cream my whole nose. -
Prepping the rear for the Napier flares.... previous owner apparently LOVED bondo -
it says 2005 rubi front... wouldnt that be tj? and the same width as the factory mj front?
well i know that obviously, i guess my real question would be are the fuse/relay connections factory wired to work with the addition of the dash controls and equipment? or is there still intermediate control wires/connections missing
MJOTM - August, 2015 - Lurch's '92 Eliminator
mikekaz1 replied to neohic's topic in Comanche of the Month (MJOTM)
curious.... where did you get side marker lights with the clear edge? ive never seen those before -
I'm doing a full parts install as mine isn't AC optioned. So on that note are the electronics also plug and play? Or should I just use a toggle switch?
http://www.amazon.com/RED-TEK-R12a-Refrigerant-Recharge/dp/B00DJDYORU $70 not bad
I was looking it up, doesn't sound like a half bad alternative, at a lower cost then a retrofit also. and to branch off the flammable part, I think I read something about a 1300 degree flashpoint which I would think to be about double any expected temps anyways
so my MJ doesn't have factory air but my parts truck does. its set up for r12 as its an '88. now I know I can get the o ring retro kit for r134. BUT my main question is has anyone tried the "NEW" legal R12A refrigerant? its suppose to be a direct swap with r12. and have similar COLDER properties to r12 than r134.
got my Napier V2 flares on the front! -
Thanks! EVENTUALLY one of those other beds will become a matching trailer. Of course I like taking on way to many projects at one time. -
Sold off that 1986. Back to 2 red and 2 black! -
Well if it has already been discussed then so be it. I would just find it more convenient to search just my home area FIRST to find something I may be able to pick up that day easily. Then outsource after. Of course this is all up to you guys. I appreciate your time on this!
HITCH PLATES!
mikekaz1 replied to krustyballer16's topic in Vendors- members making products for MJs
Got mind the other day. Package came in a little dented but nothing unexpected. The zip ties did well. And plates look great. My bumper bolts on the other hand aren't going to come out as well as these look. Haha -
Hey. How hard would it be to break the classifieds into states or regions? That way you can keep your search a little closer to home.
Very clean! Love the no-nonsense simplistic nature of this interior.. Does the bench come stock with this particular trim? or did you add it? And that steering wheel.. airbags had to go and ruin everything. Thanks a lot OBAMA This one came stock with gray buckets. But I swapped this bench out from the plow truck. And ya I love having no airbag! -
HITCH PLATES!
If they are built to spec for a factory hitch. Then they will probably fit just like a factory hitch would. Just saying guys. -
Got my boostwerks t case shift linkage in. -
HITCH PLATES!
I can't wait for mine. Arggggg -
HITCH PLATES!
I'm thoroughly jealous of how nice your rear bumper is... and tailgate... and undercarriage...... damn Massachusetts winters -
HITCH PLATES!
Not a bad idea! Save on shipping I'm sure too -
HITCH PLATES!
that looks awesome!
