Unglar
Everything posted by Unglar
  1. Unglar
    NAXJA NW Fest
    Where was that?
  2. Unless you like the little wind wings, you should look for 97+ doors as they have the full window.
  3. Unglar
    heater valve
    I have the complete heater unit out of a '89 XJ 4.0 5 spd. Your welcome to whatever part you need, but will have to describe it better.
  4. Doh! I meant drive shaft... glad you all are smart enough to realize that. :-)
  5. Can you use the stock axle when you go SOA?
  6. Major bummer! Good idea, the full roll cage will be a must, also, doesn't the missing cab provide some structural integrity? Would have to come up with a way to re-inforce the remaining cab.
  7. Keep in mind that it depends on what year. 87-96 XJ are generally direct bolt on. 97+ require some modification but can fit and are a nice upgrade, especially the header.
  8. Thanks for the pics and future write up. So that seal puller just hooks one side of the seal and pulls it out? Did it work good or could a flathead do the same job?
  9. How about pics of the seal install? :-)
  10. If your putting it on your '86, all '87 and above need some modding. It has been done by several folks on here, you can check it out in the build threads.
  11. Congrats! :thumbsup: Can hardly wait to see you run at Bonneville!
  12. Aye Happy Pap's Day!
  13. Nice work! :thumbsup: Can you post a pic of your towbar installed so I can get an idea of how you hook it up? Also, will send a pm for the pdf.
  14. Also, check the wire that runs from the battery/Alt to the distributor. It runs close to the block and I found mine had a bare spot and was shorting out.
  15. In the video I heard someone say 88.7, maybe it was 188.7?
  16. Anyone know how fast he went?
  17. :rotf:
  18. Welcome to the club! :thumbsup:
  19. I would be interested in a pin that is a side view of the MJ. Also interested in your ring.
  20. Probably should verify which D44 he has since there have been many different versions over the years.
  21. Nice, what are the odds of that? I wouldn't go so far as to offer him a beer though....
