ComancheNewbie
ComancheNewbie's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. I took off the bottom dash piece for a better look....I felt the bar that slides up and down the steering column when I turn the key, and I loosened the 2 bolts on the ignittion switch...amazinlgy it works just fine now. When I turn the key off, the engine shuts off everytime now....wtf? I didn't do anything yet! haha BUT... my question is, what is the device called that the bar is actually sliding in and out of? It's mounted more on the side of the steering column vice the top. The "ignition switch" I bought from Autozone (Part# LS442) is not what the bar slides into, but is mounted on top of the steering column. These are the two bolts I loosened.
  2. Ok, I just replaced the water pump, so now I'm back to the engine not sucking coolant again. Last time, it took 2-3 days for the coolant to finally get sucked in. Any other tricks on how to "burp" the system and get rid of this damn air pocket that keeps forming?
  3. I have to pull the center plug on the distributor to shut off my engine because when I turn the key off, the damn thing keeps running! :dunno: I've been told that I can adjust the ignition switch. How do you do that? Anyone have pictures?
  4. I'm already using screw clamps and if I tighten anymore, they might cut into the hoses.
  5. :no: OF COURSE! How stupid was I to think you could actually fix these old damn trucks! :wall: It runs good and cycles coolant, but now I have a coolant drip. I think it's from the waterpump or the lower radiator hose. I've also seen a tiny tiny little bit leak from the bolts on the thermostat housing, but I don't want to tighten them too much as that's how I cracked the first housing. I guess I need to buy all new hoses and a new water pump. :rant:
  6. I ended up buying it. Only $10 and since I'm making multiple stops into Autozone every week for this POS truck anyways, I figured what the hell. My father-in-law said he's used it and it worked well for him. The bottle says to use every 6,000 miles and will stop leaks usually within the first 2 days or 100 miles. I think it all depends how bad your rear main seal is.
  7. I guess I just had air in the system, because it finally started circulate coolant. Now on to the next problem! :shake:
  8. I guess their could be air in the system, I know this is common.
  9. I didn't replace the water pump. Just the radiator and thermostat.
  10. I'm about ready to blow this truck up! I just installed a new radiator and thermostat and the engine isn't sucking in any coolant. I ran it way above "normal operating temperature" and still nothing. WHAT'S WRONG!?!?
  11. I saw a quart of Rear Main Seal "Stop Leak" at Autozone and I was just wondering if anyone has tried it. I think it was $10. Obviously it's not a good fix, but temporary until I have time to change the seal maybe?
  12. Picked up the radiator, thermostat, thermostat gasket, and upper auto trans cooler line @ autozone for $136. I snapped the cooler line when removing the old radiator. Install this weekend.
  13. I was finally home long enough this weekend to work on the "beater." I pulled the radiator and sure enough, the plastic is cracked on one end, explaining my white smoke and leak. So I need to pick up a new along with a new line I snapped trying to disconnect it from the radiator. That thing was a b*tch!
  14. If I get within 50 feet of a car the radiator goes out,,,the walmart parking turns into yellowstone when I walk through it. :cheers: If I get within 50 of my Comanche something else breaks on it. :fs1:
