Everything posted by mnkyboy
Mnkyboys 89 Comanche project
mnkyboy replied to mnkyboy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Slowly getting it dialed in. https://youtu.be/68yUuUGzElQ- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I reworked the idlers to get better belt contact with the powersteering pump. Before/after.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
A little ghost ride in 2wd double low (152:1) https://youtu.be/7LQASqkSgp8- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I've had people ask about the noise from tbe supercharger,here is a video of the engine running and one of the exhaust. https://youtu.be/i7LW6TR3twI https://youtu.be/qrcn3fgQKKc- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Which 4.0 is preferred for a swap?
mnkyboy replied to Jtrux's topic in MJ Tech: Modification and Repairs
91-95 are in my opinion the best years and have the good 7120 head. 96+ is when the pistons changed and are known to drop skirts,96-99 have an 0630 head that is more crack prone than the 7120. 00-01 have the 0331 head that is even worse for cracking. -
Can someone demystify seat options?
mnkyboy replied to EUREKA's topic in MJ Tech: Modification and Repairs
I even posted on it,7 years ago. Remember talking to him about it on PMs. -
Mnkyboy definitely has 97 Dakota seats, not sure who posted the other info. -
A short video of the MJ climbing a fairly steep stretch of road.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Maybe eventually. The MPFI donor had it so i kept it,it's nice to know i have the option for it.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Took the MJ for a drive,even hit the highway,it did so well that i decided it deserved a bath.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
This.. Doesn't have to be perfect but at least try. As for building a 4 banger,there's absolutely nothing wrong with that,it's a good little engine.
Last big piece to the intercooler puzzle showed up.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
$60-$70 new on E bay,just make sure to get the right year range for your rig. 87-90 and 91 up don't interchange.
Yes it's the Autometer,iirc it was the only MJ/XJ specific one i could find at the time.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Finally got the gauges wired up.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
My crossmember is completely flat and attaches where the crawl box bolts to the T case,i could probably have put it in the stock location and used the stock mount. I cut the tunnel out of my truck then lifted everything up into the cab so along with the flat belly everything actually sits up out of the way too.
http://www.maxxima.com/products/product_detail/451/Hybrid-Series-LED-Oval-StopTailRear-Turn-and-Backup-Light.html#.WLijJZ-IbqA These are the lights,Ebay will likely have the best price on them.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Issaquah Washington
I think about going every year,it's about 3.5hrs each way for me.
I run a slip yoke eleminator on my MJ,our trucks typically don't need to have them like the shorter wheelbase Jeeps do but it is nice to have.
Dakota 40/20/40 seat brackets
mnkyboy replied to flyn2er's topic in MJ Tech: Modification and Repairs
I get messages all the time about mine,of everything that's done to my truck the Dakota seats get the most questions. The issue with mine is that my truck had Chevy car seats that were attached to wood blocks and screwed to the floor,I didnt have any MJ rails and the Dakota seats didn't come to me with rails either, i made brackets from scratch and used generic rails from a conversion van. Because of that i can't really do a good write up since my install is different than someone that had the rails,i usually send people here. -
Got the ice box and pump for the intercooler today,it's shiny so it has to be loaded with horsepower.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I could see that time if you had done it before,the average person out in the garage is probably going to take a bit longer.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I believe mine is 6lbs with the current pulley. Hopefully i can get the gauge wired up soon and find out for sure. Most people don't end up cutting the hood,most I've seen mount the SC on the passenger side and set it lower. My biggest issue is that i have the water/air intercooler sandwiched in there making my set up really tall. That sideways mounted SC kit looks pretty cool,i bet it would look great under your hood.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I've driven the truck a little bit and it scoots along pretty good. I still need to set up the wide band o2& boost gauges and water/air intercooler before i can really play with it. I ordered a 4 gal ice box to mount in the bed and a pump,just have to decide on a heat exchanger then i can set up the intercooler,the wide band and boost gauges are mounted in a pillar mount and just need wired up.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
