pitbull4x4
Everything posted by pitbull4x4
Congratulations on a 299. Best I had was around 250 and bowled for years
Need years on Cherokee motor for swap
pitbull4x4 replied to pitbull4x4's topic in MJ Tech: Modification and Repairs
Thank you for the info. -
So nobody knows if a 2000/2001 4.0 out of a cherokee will fit in my 89 MJ using my motor mounts and auto tranny ???? -
pitbull4x4 posted a topic in MJ Tech: Modification and Repairs
Need to know what the newest year will work in my 89 MJ with 4.0 auto. I put a 97 Cherokee 4.0 in it and has a bad knock. Guy is pulling the motor to see what the problem is. Will a 2000 and 2001 XJ motor work or is a 1999 the newest I can go ?? Just seeing if a motor or rebuilding is cheaper. Thanks for the info -
Look at 87Warrior post. Got them to work after we flatten them and rebent. Still was hard to get them to fit and look good
Do NOT GET C2C IF DOING A FULL ROCKER !!!!!! I got them and were a pain to get them to work. Good luck
I have a 97 ho in my 89 Comanche
97+ rear flares, how to
pitbull4x4 replied to floundering's topic in MJ Tech: DIY Projects and Write-Ups
Thanks for the write up on the 97+ flares. I have a 99 XJ front end and was trying to figure out how to mount 97+ flares on bed. Although the picture of the older ones sanded do look nice -
Line floor pan, or what?
pitbull4x4 replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
You are very lucky with only a small hole. Mine was so bad the floors needed pans both sides. But now I have rust free cab corners, outer and inner rockers and floors. I just sprayed bed liner on floors -
upgrading injectors question
I saw people buying them from Programbo. At around $80 Thank you -
I'm lookingto upgrade my injectors on my 89 Comanche, 4.0, auto , 2wd. My 4.0 is bad and replacing with a 4.0 out of a 96 Cherokee. Have seen people saying Volvo, 5.0 Mustang and Neon. What are the best ones with best price
exhaust manifold question on 4.0 89 comanche
Thanks for helping this old guy out !!!! -
About 15 years ago, a friend of mine went to look at a 69 Camaro. Add said blown motor , $1,800 OBO. Got it for $1,500. Loaded it on trailer. Got home and looked under it. Saw the wires on starter not hooked up. Hooked them up and drove it off
will 2001 XJ 4.0 motor work in my 89 Comanche
I am going to swap engines. Just asking if it will work with the parts mentioned . Also I'm putting an auto and t-case out of 91 XJ in to do my 4wd swap -
My motor in my 89 Comanche. 4.0, auto, 2wd has a warped head and block. Can move pistons in cylinder with finger. I know a 99 and older 4.0 will work using my intake, exhaust, valve cover , flexplate, flywheel, distributor, and the newer thermostat housing. So if I use the same parts will a 2001 XJ 4.0 work also ? Reason I ask is because I found low mile good running one they will pull for &350. A member on here said it should. He sounds very smart at what will and won't work. Or would it be better to stay with a 99 or older motor
Had one in my other Comanche. Leaked when sitting still in rain and snow melting. They are nice in the summer, but never want another one
Got mine at pick your part. 50% off weekend and were only $9.99 for both fronts
what years of tranny & t-case will work
Thanks cruiser54 -
Staying with a auto. Yes I'm getting the rest of parts (front alxe, drive shaft, ect) but just asking what years of tranny and t-case. -
New to the site and obsession. Purchasing first Comanche, need advice
pitbull4x4 replied to RonMexico's topic in The Pub
I bought my 89 Comanche for $325 and drove it home. Its a long bed, 4.0, auto with 280,000 + miles. Its getting cab corners, inner and outter rockers and floors fixed. The bed sides were fixed last summer. I don't have a welder so a good friend is doing the body work. I'm up over $550 and will owe more when done. So a rusty truck is very costly to get fixed. Good luck on which every way you go
