Everything posted by Oizarod115
i need help with decisions
Oizarod115 replied to manche0230's topic in MJ Tech: Modification and Repairs
he said its a teraflex SYE kit which means its quality, and idk anything about rough country's CV shafts, we got the one for the xj from tom woods.. http://www.4xshaft.com tom woods is one of the best names in custom 4wheel shafts -
400sbc in the jeep
Oizarod115 replied to billybob_jeep's topic in MJ Hardcore Tech: Epic Journeys to Greatness
NICE! i guess you figured out photobucket then can't wait for finished pics! :cheers: (oh and a dyno pull sheet ;) :brows: ) -
rich fuel/air mix? emissions failure.
Oizarod115 replied to Oizarod115's topic in MJ Tech: Modification and Repairs
well i soldered in the 250 ohm potentiometer and perfectly as i suspected i can now vary the voltage from 5-4 which is perfect. :cheers: :cheers: i set her to 4.7~ (thats a very unprecise measurement considering I'm using a few year old analog multimeter on a scale of 1-10 through 90* of motion. now how should i go about seeing if that is a good setting or not, its still got good power, i smelled the exhaust, seems a little cleaner, maybe not 100% burnt though. but its never gonna be perfect right? ..thanks for all the help on this one hornbrod -
i read through this and it sure seems like rocket science to me. :redX:
oOoH niice, you're not getting the front clip painted too? can't wait to see her. :cheers:
400sbc in the jeep
go to Comanche Club Image Hosting and sign up, (its free) then its gonna have upload pics, and upload them from the fiel on the compy then after they load up, under or beside the pic it'll say IMG code... click in that box and copy paste the code it has into your message where you want the pic to be. hit preview if you wanna see if its workin :cheers: :cheers: can't wait to see em[/url] -
isn't that kindof a waste of money? mickey thompsons arent cheap especially in the 46" variety. (it did say those were baja claws right?)
to tighten the belt i usually tighten her until its not easy to get the belt to twist 90* on the longest stretch (there on the top easy to see) just tighten so it can twist striaght up and down but not much further its worked so far for me ;) don't think its real exact though
did a test on it today with the FLUKE meters from school, gettin 13.2 on the battery just chillin, and 14.37 across the battery with the truck running so she's not overcharging, teach figures some sort of internal short, i'll swap my old battery back in and take the optima back.
yea its all hooked up right.. and my 5v is red/white stopped by and got a pack of assorted ones including a 250ohm and two 200ohms... i'll burn the 250 in tonight... i figure if 25 ohm can move it .1 then 250 will move it 1.0ish right? idk, we'll see. -
uh, you're not really gonna REBUILD an aw4 are you? thats a HUGE waste of effort. i have no idea what a swap like that is worth. the parts alone would be a few hunge. really depends on stuck bolts and stuff and how long it ends up tying you up.
i think i'm gonna put my old batt back in and have them test the optima, if its bad i'll see about just straight up returning it, i could use the $$ right now instead of the extra CCA's
it is THE battery. tires are fine, and the truck was off. my stepdad hears it too and said the batteries they use at work do that and they get tossed outside (away from the shop) then discarded. its coming from the small little felt pad-like area near the negative terminal and the battery is less than 2 months old. and the alternator is less than 6months old and the cables are all new, so it shouldn't be overcharging. she read 12vish adn overcharged would be 14+
well i did this adj map sensor thing with a 25 ohm rheostat from radioshack and i can only adjust it about .1 and that only puts her at perfectly on 5. which i suppose is better than nothing, i wish i could find a 100ohm or 250 ohm one to try that might work better... and I'm wishing now i hadn't soldered all the connections becuase i'll have to heat them off to try a different one. -
working under the hood tonight (ignition on or off, doesn't matter.) i noticed my battery is making a slight hissing noise... which gets me REALL ancy after hearing my toyota-tech teachers many first hand experiences with batteries blowing up from people doing dumb stuff and so on. i know he said SOMETHING about batteries that are making noise like that but i can't remember what, does anyone know anything? this is an optima red top, and it got the living HELL rattled out of it on the access trails to tellico this weekend (very bumpy 20mph rd)
Gas tank/pump compatability
Oizarod115 replied to Twisty's topic in MJ Tech: Modification and Repairs
problem is you're getting a longbed tank, as its an 86, and if you have a longbed thats just peachy... but if you have a shortbed it might not clear the axle and other stuff like that. so they were sayin if you have a small tank from a longbed it MIGHt fit there. -
headin to tellico, nc
Oizarod115 replied to Oizarod115's topic in Adventure Planning / Regional Groups
teaserrr. its bad quality but hey, all we had were cell phones after the vid camera died, but we got all of gaurdrail on the real camera and some other crazy spots too. :brows: top of guardrail :popcorn: -
1-800-radiator is where i got my modine 3-core, delivered next day for 160 i think.
well, just got back... for those that know tellico (and our jeeps) the XJ made it up gaurdrail, and upper 2, then we ran out of fuel (due to tipping up to about 60* on helicopter-pad, and had to siphon some from another rig to get running) made it up in the end though, uh, what else, all of trails 11, 4, 5, and 1 was pretty fun (dirtroad) manche was acting good, no breakages (even though our other buddy was running an open F&r XJ with a d35 on 33's (he made upper2 but bypassed the heli pad and gaurdrail) everyone was able to make the trip home under their own power, kicked @$$ basically pics/vid tomorrow (yeah, vids of near flips ) -
eh, use the name i made if it makes ya happy. ;) piss em off some-more.
thanks man, looks liek i'll be trying that. i wish i could gank one of the fluke meters from school, as opposed to my analog meter :roll: however, at least he lets me use them for w/e i want while i'm there :brows: -
what about a rheostat? http://www.radioshack.com/product/index.jsp?productId=2062299&cp -
Questions from 4x4 Noob
Oizarod115 replied to Ben-88Comanche's topic in MJ Tech: Modification and Repairs
even with my 5spd when i've tried to shift with the tranny in gear, clutch on the floor its just grinded and not wanted to go in.. i usally shift with tranny in N and clutch on the floor (jsut for good measure) -
Ipod's come in TONS of different ways. being that she's a young girl, she probably doesnt have ALL that much music to put on one, and therefore doesnt need an 80GB (yeah some have 80gb drives) another thing you'll need to ask yourself does she want a video ipod? the newest/coolest would be the smaller version the nano, full color 2" screen comes in 4, 8 and idk what else. http://www.bestbuy.com/site/olspage.jsp?skuId=8500856&type=product&id=1186004970881 that would probably do the trick. they also make the same thing in a 4Gb which will hold like 1,000 songs, and cost 149.99 oh and they come in tons of pretty colors... so be sure to find out her fav. color ;) the pricing should be just about the same everywhere. oh, and don't try to get her one that's got better features unless its still and iPOD... to you and me the name won't matter, and might save money, but the name is probably worth it to her
http://gojeep.willyshotrod.com/HowtoMAPsensor.htm thats a pretty slick write-up there, he's using a 1k ohm potientoeriehtng. err... thingy. :roll: but i think i'm gonna try it your way... his is just way to complicated.
