dasbulliwagen
    3
  1. Being a dealer tech, I have NEVER seen a problem with factory plugs. I have seen problems with other brands, but I'm not sure that it has ever been with a 4.0. I myself love the Bosch Platinums, but I'm sure other people will have better opinions as to what works best, as I don't own a 4.0. As far as the cruise, check the vacuum line going to the cruise module under the hood. The WJ is known for the vac lines going bad, at least the rubber parts. Another thing to check if that is ok is the buttons on the steering wheel. If they have a problem they could cause the problem youre describing. If you have access to a good scan tool, you can hook it up and go into sensors, or inputs/outputs, and try to work the cruise buttons and see if the values change or not. If they don't then you would have an issue with the buttons or the harness, usually the buttons. Good luck!
  2. I'm not saying that the stabilizer would cause it, or be the be all fix all, just that its importance should not be overlooked. And as I said before, and other posters, Wheel balance should be first on the list. :nanner:
  3. Took the 87 into work this morning to see if I could figure out the wiring for the AC. Thanks to the downloadable 1988 service manual PDF from one of our other esteemed members, I was able to find a better wiring harness diagram and found that I just needed to add a relay to it and have the unused pins from the dealer installed AC connector hooked to the relay, etc. etc. etc.... and viola! it works!!! Still need to add refrigerant oil to the system though, so no real tryout till next week....someone locked up the AC machine at work, and it has the oil injector I need to put the oil in. Next project... Install the 4:10 rear axle, then the front axle then the trans and transfer case. Maybe next weekend I can start on that! :brows: :brows: :brows:
  4. I disagree about the importance of the stabilizer BLHTAZ. It does more than you think, and you are right about the stock ones on wranglers, they are junk from the factory. Ive see too many wranglers with less than 20000 on them come into the dealer with DW. A good heavy duty stabilizer always helps, but like I said before, you need to check everything else first.
  5. Have your tires road force balanced, and get a good heavy duty steering stabilizer. Those two items will help tremendously. But also do like the other guys said and check all other components and do repairs if you find anything wrong. But wheel balance and stabilizer will help.
  6. Vacuumed the AC system I just put in, Charged it only to find the compressor not getting power for the clutch. I now need to go throught the wiring for the ac and find where my problem lies. After I get all that working I can then start on my 4x4 conversion!
  7. Ive been submitting here for a while, finnally got around to taking pics and going through photobucket. easier than I thought. here's my baby, 1987 Sportruck 2.5, AX4, 2wd, 3:55 R+P I'm in the process of converting to 4x4 with 4:10 gears. Ive already added the AC and Power steering, and added a cold air intake I had laying around after finding out I needed to lose the airbox to have room for the other stuff, and I think it looks cool, though any increase in power is little to none. here's pics of the cold air, and my Dodoge caravan power steering resevior. My donor truck is a 1986 2.8 V6 4x4 with bucket seats, AC, PS, tilt column, and rust free. The PO bought it running and driving with a knocking engine, imagine that in a 2.8! The body is rough in a few places but very solid. I think this may turn into a future project with who knows what kind of motor...maybe a V8???? The owner of the dealer I work for has a 1988 Comanche Olympic Edition 4.0 4x4 SWB...its been having brake problems for years and hes now trying to get me to see if I can fix it...I'm not sure though... too many hands been in it! I told him Id swap the MC assy from my 86 to see if it would help..we'll see. here's the pics of the 88. And we have this little beauty for sale on the lot! Any takers??? And Ill throw this in cause I like it! Image Not Found And here is my other baby... Ghia Marie...riding in the MJ, she likes it because she can see out all the windows!
  8. When I was doing that same swap. I looked at an 88 4.0 to compare brakets to go on my 87 2.5. The brackets are different and don't take into effect the little shock that mounts between the motor and frame. I ended up spending $75 to get all the brackets off of another 2.5 from the junkyard ( they pulled ). And while they bolted up to my 2.5, none of the rest of the stuff was the same...I have no idea what year 2.5 they took those parts off of, but I made it work with a little parts swapping/robbing/grinding. I wish you luck!
  9. What city are you from in Michigan? And what school? I'm originally from Battle Creek. I really don't miss the rusty vehicles. I used to buy a new winter beater every fall so I could put away my nice car for the winter. I didnt really have jeeps back then, but one of my winter beaters was a 1987 Grand Wagoneer 4.2 Selectrac. Poor rustly little bastard. I found out the frame was about rusted in two, so I got rid of it. I loved that full size jeep...would love to have another if I could afford the gas for it!
  10. Welcome ! Nice start you got there. What are your plans for it??
  11. JK changeover was 2007, first year for the 3.8!!!! :mad:
  12. I sure wish I knew what to do with all of my rust free MJ's! I'm just lousy with 'em. :yes: :rotf: :yes: :rotf: :yes: :rotf:
  13. Another thing Ive always heard good things of is Water wetter, an additive to put in your cooling system that helps the water transfer heat faster....something to do with breaking down the waters surface tension to allow more contact between the water molecules and the inner surface of the radiator. They sell that brand or something like it at most parts stores or performance shops.
  14. Newcastle Brown Ale, or Negro Modello......good shtuff!!! :cheers:
  15. Thanks for the support guys, replaced the started and hoped for the best. They left hopefully never to be heard from again, I'm just waiting for them to complain about the exhast leak it had! :brows: :brows: :brows:
  16. Mineral spirits, or laquer thinner is the only things Ive ever used. Cheap and you can get them anywhere. good luck!
  17. The Cv shaft is a shaft and Cv joint built together, it is one assembly with the boot and everything. To replace pull off the caliper, the rotor, then get to the backside and with a 13mm 12 point socket on a 1/2" drive wrench remvove the three bolts holding the hub to the knuckle. They will be tight, then carefully knock the hub assy off. This may be tough too if it is rusty at all. The hub assy is the wheel bearings and wheel seals all together in a single unit so be careful removeing it if you arent putting new ones on. Soemtimes they will just knock right off, other times youll need a little encouragement to get them off, but one the hub is off, the axle assy will slide right out, slide your new one in being careful not to mess up the axle seal deep inside the axle and put eberything back together. Good luck!
  18. Or if you want to just get a new ZJ CV shaft assy from autozone or somewhere, they are selling new ones now for the same or less than rebuilts, I think around $100. CV shafts never came stock in an MJ. Some one probably just had one lying around and decided to thow it in there to replace a bad u Joint axle. Either way will work.
  19. 3000 rpm sustained will not hurt a thing for any period of time, at highway speed the load on the engine really isnt that much, just enough to keep up speed and combat aerodynamics. My Hyundai Tuscon has stock 5:37 gearing with the 2.0 4 cyl and runs around 3500 at 70 MPH which I run across country on a regular basis. I would be more worried it the rpms was in the 4-5 range. 3000 will not hurt anything.
  20. Try Acellerated Motion cam and lifter kits. I can't remember where I saw them from, but they seemed to have some fairly big cams available, out of Canada IIRC eh? www.amotion.com/amcams.html Call them up and see what they say!
  21. Had a customer bring in their 06 Grand Cherokee the other day, wouldnt start, the whole thing covered in carolina red mud, open the hood, and the whole hemi has an inch of red mud all over it. Well, I hook up the jump box, get it running and notice the battey light on in the dash... its not charging. I get my flashlight out, move the air ducts and look at the alternator which is packed pull of mud and must have burned or ground down the inner working of it. We order them a new alt and tell them there will be a charge to hose this thing off so we can work on it. I get the alt replaced and everything is working so I pull it out and park it thinking I was done with it and these people could go back to Raliegh where they came from. I noted on the repair order that because of the mud intrusion, they could have other problems pop up. The customer comes in today to get it after driving for an hour and a half, turn the key and the starter just spins freely! Not engaging! And somehow its my fault! Its my fault they buried their soccer mom unmodified hemi Jeep in the mud at the Uwharrie state park! So tommorow I get to replace the starter on it, still with an inch of mud covering all of its underpinnings. I can't wait! (note the sarcasm) I just hope nothing else goes wrong with it till after they leave, because somethingelse will go wrong with it. Those new Cherokees may be trail rated, but its not mud bog rated. Its not bury the hood and front end in the swamp rated. It not STUPID rated!!! Freaking preppy a-holes! IF YOU WANT A TRAIL JEEP.... BUILD ONE!!!!!!!!
  22. I need to save this whole thread before it gets deleted!!!!!!
  23. I have never tried this or heard of it being done, but the ZJ is very similar in a lot of ways to the MJ/XJ. It should just be plug and play. Search the threads on here though, I seem to remember reading that it would be best to keep the original MJ valve and plug one of the ports in order to do away with the rear valve, though I can't tell you which one. Good luck!
  24. I'm working on this project myself. Youll need the braketry to mount the compressor and remount the alternator, all the high and low pressure lines, receiver dryer, condensor, the compressor itself, the HVAC housing assembly including the metering block. You will have to pull the dashboard completely out and the old heater housing assy, and replace it with the HVAC housing assy. In mine, all the wiring was already in the truck, just unused, there is a connector for the whole assy behind the radio. after mounting everything up, youll need to find the wiring under the hood for the compressor and the low pressure swith and wire them up. then have the system vacuumed real good, before charging with the correct amout of R134a refrigerant and the proper amount of refrigerant oil. Oh yeah and did I meantion youll need a kit to convert everything over to R134a refrigerant, which is no big deal, just a couple of adapters. You should also make sure you get a NEW receiver dryer if you are stealing parts from a donor. Not difficult, just time consuming. Good luck!
