Pete M
Administrators
    114
Everything posted by Pete M
  1. Pete M
    Moving Again!
    can't push the point strongly enough that aftermarket dollys can be had with brakes for that long drive down the mountains.
  2. Pete M
    scaled down MJs
    now I have an N scale, HO scale and a 1/24 scale. the little guys were found on etsy, the bigger one on ebay. all 3d printed. the big one doesn't have an interior or drvetrain (yet) but the teeny tiny guys have seats inside! don't know why, but they do.
  3. Pete M
    Moving Again!
    tow dollys aren't insanely expensive and you'll get most of it back when you sell it.
  4. Pete M
    Moving Again!
    the vehicle uhaul wants to inspect it the tow rig, not the towed rig. uhaul has never laid eyes on any rig I've towed. Uhaul dollys don't have brakes (at least none that I've seen). but you can buy a dolly with brakes. wait, are you planning on pulling the one MJ with the other MJ? I'm sure it's been done, but that sounds kinda sketchy to my ears for such a long way over the rockies.
  5. it is exactly what I wanted. the magnet that holds the blade in place likes to hold it up against the flashlight when in my pocket.
  6. gotta get the word out to the guys that frequent junkyards. lord knows I've seen a set or 2 over the years but didn't give them a second thought once I saw the mirrors were toast.
  7. Pete M
    Gas prices
    passed a station with 4.27 yesterday.
  8. I split the post off into it's own topic so more eyes will see it. I do hate POIs (previous owner issues).
  9. people are still finding piles of parts in the back of dealerships.
  10. just think of all the useful experience you're gaining just in case you need to pull the pump during a total power outage in the middle of the night during a new moon.
  11. frame stiffeners are unnecessary for MJs unless you're regularly jumping it or rock bouncing. and even then they aren't really all that necessary. I wouldn't even bother replacing the floor pans if they are not rusted through. just grind off all the rust and paint. under the frame cap is another story and you will want to pull it to get to the rust underneath. you can put it back, or not. I've not heard of a single person having issues because it was gone. welcome to the addiction
  12. there are better ones out there. don't buy one because it have a lift, buy one that runs and drives great... then add your own lift.
  13. it's a piece that goes from the top to the bottom of the door to take the stress off the sheetmetal.
  14. hmmm.... you'd better add one to my shopping cart. next time I get anything else, I'll get that too. I think I'll go with Napa though for the member's truck I'm working on. I can get those on the drive over.
  15. neat. how much is the chrysler asking?
  16. any out there that are better than others?
  17. sweet! people have been asking for such a thing for years now. good to see someone finally stepping up.
  18. -cut off XJ perches and shock mounts -weld on perches in MJ location -shorten driveshaft 1" (unless you're also lift 3-5" in which case the + and - balance out) -figure out what the brake lines need
  19. having an exhaust is definitely progress.
  20. a team effort!
  21. it's super easy. you won't regret it.
  22. waaaay back in the day I put mine on the pass side of the trans tunnel. I rarely had a passenger so it didn't matter (and if I did I could simply remove it and chuck it behind the seat). later I mounted it to the back wall right in the corner behind the driver (mounted to that 3/4" plywood wall I built). then I moved it outside in the bed so anyone could grab them if needed. The Liberty's is mounted to the pass side of the trans tunnel.
  23. takes 5 minutes to trim the steel bushing flush with the rubber. it's like the easiest mod ever. also, no, there are no aftermarkets that bend in like them. plenty of aftermarkets are round though, and that might help a bit.
  24. can you email a better image to comancheclub@hotmail.com? I'd love to have the info for the archives.
