Crash
Everything posted by Crash
I do not have one yet, but times however many on the boostwerks linkage, I plan to convert my XJ eventually and my MJ when I do a 4WD conversion.
87 is renix, they will actually run decently without an Os2 hooked up. Yes, they do run on ECU parameters, but they do run. A while back when my O2 was failing on my renix XJ, I disco'd my O2 sensor and it ran fine until I could afford to buy a new one.
can a '97 front clip be installed on a '88 comanche?
Crash replied to 81Chero's topic in MJ Tech: Modification and Repairs
Looks to have a "W" cut out, so I would guess warn? -
What's the word on this?
temp gauge sensor after HO swap
Crash replied to teamsmith's topic in MJ Tech: Modification and Repairs
Best thing to do in this case is go to your local parts store, and pick up a threaded "bushing" to adapt from the housing to a one wire renix sensor. I believe that the t-stat housing threads are 3/8 npt and the renix sender is 1/4 npt. -
Since you want bigger tires and new wheels anyways, try to find a set of TJ MOAB wheels. They are 16x8 and bolt in. 265/75 will be the size you want to run, maybe 265/70 if you find a deal.
4.0 water pump differences question
Crash replied to big66440's topic in MJ Tech: Modification and Repairs
DO not waste your time with Flowcooler pumps. They are problematic. Either go to your local Carquest, Napa, etc or the dealer. -
If you can afford it, Bilstein 7100s or Fox 2.0
2 junk rustys steering stabilizers....
Crash replied to krustyballer16's topic in MJ Tech: Modification and Repairs
If their monotube SS is like what is shown on their site, I would say it will definitely be an improvement. And is has proper bushings on both sides. Hope they are not charging you for the more expensive one though. -
The 3/4 cluster I have in my MJ right meow is basically the same. Mine has the old logo in it. Yours may have the "low fuel" light in that spot.
8.25 E - brake issue (disc swap)
Crash replied to ftpiercecracker1's topic in MJ Tech: Modification and Repairs
I think I will be using these when I do my rear disc swap. http://www.shop.blackmagicbrakes.com/Wizard-Brackets-Reverse-TJ-Style-Parking-Brake-Cables-BRAKE-WIZARD-BRACKETS.htm- 16 replies
- emergency brake
- grabbing
(and 2 more)
Tagged with:
Get your money back, and go to your local Carquest, Napa etc and pick up a stock replacement stabilizer. -
converting an 89 tbi to 93 mpfi questions
Crash replied to 89MJ4spdman2wd's topic in MJ Tech: Modification and Repairs
I think the 4.0L pump will work, as far as I know the earlier 2.5 pump doesn't have enough output. -
Definitely get the fenders to match the header panel. Unfortunately, my MJ is 4 different colors currently, but if you check out my build thread there is 97-up header panel, fenders, hood and doors. The doors are not just plug n pray. -
It could still be a 90. I'm guessing it doesn't have a tach so 3/4 cluster?
I may have an exploder 8.8 available soon. Gears are unknown as of meow.
Well. For soa. You need to weld shock mounts on the axle. With the estranged plate up top. Not much you can do with that.
I guess that is a cheap way to do SOA. Since, from the factory, the shocks were mounted to the u-bolt plate mounts. Are they still mounted there? Just above the axle. or did PO add shock mounts on top of the axle? pics would help.
Yesterday I M+B my 265/70R17 Yoko AT-s on my JK Moab wheels. Finally got some wheel lug nuts and some red loctite. Got them installed today. Looks much better. https://drive.google.com/file/d/1inhiUrXpULoEqjdNyt4u6rsQ45_y8D8DdQ/view?usp=sharing https://drive.google.com/file/d/11mToaqM6rc9EoKJ8z2PhLtLpHls9iUEJBQ/view?usp=sharing
Got my wheel adapters today. Missing a few wheel nuts, so I ordered some up on amazon. https://drive.google.com/file/d/158-L6CexSFIqRTKoOm2KJCBadQL6CvXFVA/view?usp=sharing Also, picked up a free stock skid. Everyone knows what those look like, so no photo for that.
Drill them out.
A Comanche Build.. The story of a dead XJ..
Crash replied to WiscoXJ's topic in Member Projects: Your Comanches
If you're gonna make an omelette, you gotta break some eggs. -
I have seen a few with SBC in the rear. Not like the one in the OP. I have seen some nice Baja bug's There is one local that has a turbo Subi motor in it. I have an old rusty pos 73 beetle that was free from my dad. Hoping to get rid of it soon.
shipping a truck really isn't that much money. should be under a grand. that's a rust free truck for under 1300. :yes: This ^^ Then you can spend the left over cash you have on making it great and have it be YOURS.
