mjeff87
    8
Everything posted by mjeff87
  1. mjeff87
    The auto show
    It's about this time of year when I start chanting "Let's go PENS!" lol..... On the MJ front, I'm looking for a project truck. Close to me. And cheap. :rotf: The KJ is nice and all, but it's just not cutting it.
  2. mjeff87
    The auto show
    Mmmmm......DiNick's roast pork and rabe. Awesome sandwich. :drool:
  3. If you are anywhere near southwestern PA, I have a spare 2.5 sitting in storage. You can have it for free if you can get it.... Jeff
  4. Post #15 in this thread..... http://comancheclub.com/topic/19732-random-informative-picture-thread/
  5. -pedal assembly (unless you keep existing and eliminate the clutch pedal) -floor shift assembly for the AW4 -TCU -engine side wiring harness from the '88, which includes the pigtail wiring for the TCU (and NSS) -TPS from the auto (or the whole TB), autos have a second wiring connection -kickdown cable and associated bracketry -speedometer cable, possibly (your existing may be too short) -trans crossmember, mounting plate and trans mount....take all of this with the trans -the entire TC shift assembly
  6. Not the best pic, but the 2.5 is the bottom one. Top one is a 4.0 (HO) HTH, Jeff Image Not Found
  7. FYI, you can buy a replacement flange kit for that crossmember flange. They're hard to find, but I've used them in the past. Lemme see if I can find a part #.... Jeff edit: It's a Maremont #30175 kit, but nevermind....I see your problem is at the other end of the cat.
  8. yep. Here's the whole shebang pulled out as a unit: Image Not Found and here's the whole 4.0 shebang going back in. Yes, it is as scary as it looks LOL. Image Not Found
  9. Not to pick nits, but does it actually fit a 2.5L? Those starters mount to the underside of the block, not the bellhousing.....
  10. The junkyard suggestion is a good one, but with one caution.... Make sure the 'yard didn't punch a hole in the pan to drain the oil from the vehicle before they set it in the yard. I wrestled with a very nice looking pan on a junker one hot summer day for over an hour before I could get it off, only to find a nice round hole in it once I got it on the ground.
  11. pull the coil wire AND the fuel pump relay, so you don't wash down the cylinder walls and booger up the cat with fuel while cranking. Once you have oil to the top end, reinstall the relay and the coil wire.
  12. Had a stinger on my TJ (not quite as obnoxious as the one Don posted, but not a stubby one either). Biggest PITA I ever had when it came to doing anything under the hood. Only reason I had it was because the bumper (with said stinger welded to it) was free. More than once I thought about breaking out the sawzall and removing it. Never even came close to needing it on the trail. Jeff
  13. I dunno about the body panel, but I can confirm the actual plastic battery tray did vary between model years. I've pulled a couple of them out of junkyards that didn't fit the same battery I was replacing the tray under. It would follow that the panel changed dimensions as well.
  14. well, there seems to be enough chrome on it for ya Don..... then again, maybe not :rotfl2:
  15. I agree with ALL of the above :rotf:
  16. Is it for realz this time???? http://blog.caranddriver.com/its-official-jeep-wrangler-pickup-is-coming-in-2017/
  17. From the point that you are at, the injector just pulls up and out from the housing. It may not be willing to come out (there's a large o-ring around the body of it), but it will eventually.
  18. Yes. See the 2 metal lines that run into the back of the TBI cover (the big black round thing in the center of your pics)? Those are the fuel lines (one supply, one return).
  19. re: overflow bottle When I converted to 4.0, I reused my stock 2.5 overflow bottle (as shown in earlier pics). I kept the stock 4.0 air filter box, though, and had to modify things a bit. I deleted the EGR solenoid and associated plumbing and wiring (capped off the EGR altogether as well) and had to cut/fold the pinch seam above the inner fender to accommodate the 4.0 wiring harness behind the bottle. It worked fine.
  20. Thanks. Mine had a bench, but I swapped it out for those XJ rocker buckets (reused the bench floor brackets). Not only more comfortable, but the cloth seats were much, much cooler. Did I mention that the black interior was HOT? :rotf:
  21. it was an AMC-era option (through 87). My MJ had a black interior.....was nice, but HOT. Especially with the sunroof I had and no A/C. Image Not Found Jeff
  22. Do you remember if the cigarette lighter panel was blank, of if it had just the socket installed and not the lighter element? It had a blank plate, but the wiring for the lighter was tucked into the dash
  23. My 87 had an AM radio, no cigarette lighter, and a cargo mat.
  24. I remember Jeff (mjeff87) and Rick (xjs4ever). :thumbsup: :waving:
  25. It fits inside a hole inside the "inner tank" inside the tank. Yours is probably stuck inside the hole (when you pulled the pump out, it stayed). You can try to stab the end of the line into the nipple (very difficult), or fish your arm inside the tank and pull it back out. You need fairly skinny arms though :) Jeff
