28
Everything posted by HOrnbrod
M-i-c-h-i-g-a-n, or at least that's how I spell it. :fs1: Yeah Pete-man, that's got to be rustrating. :mad: Hopefully soon you'll be down in these here parts where it's not too much of a worry. :cheers: I wonder how Big Bob from Buffalo handles it........... :bowdown:
Most likely the latter. :nuts:
:agree: Tuna phishing.
Mine works just fine. How do you spell Corrosion?? :yes:
A new member with power steering swap questions
HOrnbrod replied to shackwrrr's topic in MJ Tech: Modification and Repairs
All 87-01 Jeeps (AFAIK) used the Saginaw TC series pump. There were subtle differences with pressure settings, pressure/discharge hose locations, and the reservoir tanks, but they can all be adapted throughout the years to each other. The HO pumps will work with the Renix engines and vice-versa. The hardest thing is adapting the correct mounting brackets for the various engine and accessory combinations for your application, i.e. w. and w/o A/C, intake manifold, etc. Just have to do your homework. -
That's a freeking work of art CW. Looks like all's that left are the fenders and paint. Wish I had the talent to do a project like that. Freekin' beautiful mate. :cheers:
adding power steering...
HOrnbrod replied to wolfpackjeeper's topic in MJ Tech: Modification and Repairs
Here's a link that will tell you the ratio of the many available faster steering gear boxes that are bolt-in for the XJ/MJ w. the Saginaw 3-bolt boxes. I used a 96 ZJ box (12.7 ratio vs. the 14.1 stock box ratio), but all ZJ 93-98 boxes have this quicker ratio. For the pump I used an 04 TJ pump, as the higher pressure was correct for use w. the ZJ box and the bracketology was correct to mate with my 01 intake manifold. http://www.chevelles.com/techref/ftecref29.html -
I got my Electric Life window regulators on sale from them. Exact bolt-in. Great units, made in Italy, and twice as fast and of better quality than the crappy OEM power window regulators. They're mucho cheaper too. :cheers:
David, if you decide to use the stock door switches, let me know. I have a big box full of OEM switch panels and switches all in good shape. :cheers:
Good idea JT, but those Benz switches require a special panel mounting hole with offset release tabs to snap into place. Some of these aftermarket switches below will mount mucho easier: http://www.a1electric.com/switches.htm
Yep, and the wirings already there back to the indicator light in the cluster. Just p/u the right w/w tank with the low level float and plug 'er in.
How noisy is your fuel pump?
HOrnbrod replied to CWLONGSHOT's topic in MJ Tech: Modification and Repairs
Been there - nothing for MJs. -
Does anyone manufacture a poly tank for MJs? Seen them for CJs but never for our rigs. I'd get one in a heartbeat if I could find one. -
I just hop in my 45 year old electric powered Alumacraft yacht anchored out in the back yard. :D Bass, bream, B&W crappie, channel cats, blue gills, yellow bass, and fresh water stripers. Puts lots of fresh fish on the table and is a great relaxation. Nothin' better mates. :cheers: Image Not Found
A bit off-topic but we starting keeping domestic geese overseas when we lived out among'st the locals in various countries where intruders were a problem. Better than Dobermans for watching the property; you can't make friends with them by giving them a steak, distract them with a dog in heat, etc. and they make a hell of a racket when someone or something is around. They kept out all the vermin. The Navy still uses them as watch-geese in some of the remote comms stations. Great tasting huge eggs too. We've had some out back through the years too but they always end up going off with the Canadian geese who hang around the lake. Damn Canucks. :Canadaflag: :yes:
Well Tim, I feel your pain, (no pun intended). Back in 04 I had a cervical C2 and C3 fusion because of disk derioration. Worked well until about two months ago when the left shoulder pain returned. Last week I went in for an MRI; arthritis calcium deposits have grown up on the lower plate fusion. Friday went in for a steroid spinal injection, hasn't helped so far, they say it takes about four days to kick in. This sucks. Using mild pain killers and beer. Temp help. If the steroid shot doesn't work, it's back to more disk surgery. DAMN! Legal weed if it helped would be better than beer I'm sure.............
Just for kicks and grins, check the voltage drop w. a DMM across the ballast w. the engine running. You should see about a volt or two. Might not being relay switched in the circuit on IGN RUN. :eek: -
Nice cure Juan. CW, as far as noise for mine, the only time I hear it is when I turn the key on before starting. Do you have your ballast resistor still wired in the fuel pump circuit? The drop in operating voltage quiets it down quite a bit after starting. -
Axillary Fan does not kick on
HOrnbrod replied to 87Warrior's topic in MJ Tech: Modification and Repairs
I'm using two OEM 1997+ 10-blade aux fans with a Spal PWM controller. Writeup is here: http://www.comancheclub.com/forums/viewtopic.php?f=9&t=8342&start=15&hilit=spal Start on page 2. -
Edelbrock Remote Reservoir Shocks - Feedback?
HOrnbrod replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
Since when has your opinion ever been humble CW? :yes: I've had many Benz's throughout the years all were upgraded with new Bilsteins eventually; they are great shocks. But EXPENSIVE! If I couldn't get OME stuff at cost I'd prolly be using Bilsteins. Thanks Wahoo! -
Time for a new parts supplier, my friend!!! Friends like this, who needs the problems!! :D CW Actually I was a little hard on the boys from O'Reillys. Usually they are pretty good. The real blame is with the morons who do the drop shipping from Wagner. My local O'Reillys had to order most of the stuff direct from Wagner. The boxes showed up w. the correct part numbers on the outside, but the parts were wrong. Lesson learned: OPEN ALL parts' boxes before leaving the store. :eek:
The momentary contact push button switches would work, you would need two for each window since you are not controlling the passengers side window remotely from the drivers side. But those little push button switches usually have a pretty low amp rating; the regulator motor can draw over 10A especially if the channel is tight at the top like mine is. I'd rather use a single heavier two pole double throw momentary contact toggle switch for each window to be safe. Course that would mean the passenger would have to reach across to your side of the dash to move their window. :fool:
No worries mate. It only gets worse. :D
These are still available: http://store.edelbrock.com/imagesproductsthumbshocksxtresi-11.aspx Universals. Anyone get the fully extender/collapsed specs or do I have to call them? Mounting: No problem for the rear except possible length. What about the front w. the top stud mounts? EDIT: Just found Pat's and Adam's previous posts on the XJ-specific shocks. Looks like Edelbrock has close out that line. :oops: -
Is THC the ingredient that makes you so hungry that you'll eat 90% of the contents in a garbage dumpster? If so, I vote no for THC. It will just add to the problem now w. fat, overweight, and lazy youngsters we have now. Not that I've ever done any weed lately, but that used to be one of the measuring sticks for good sheite or bad sheite. :cheers:
