coheed
Everything posted by coheed
  1. So, I found some parts diagrams with YJ parts listed and it gets interesting. The 88-90 catalog didn't list the gamblers as an option, however it lists the 52002971 center caps that do not fit the YJ gamblers and has the 10 hole with rivets as p/n 52003758. 91-93 parts diagram shows the gambler using p/n 52007398. Note it also differentiates the 10 hole with rivets wheel as p/n 52003758. As eaglescout kindly pointed out I have AMC caps which are p/n 8952003759. 94-96 parts diagram actually list both the 5 hole and 10 hole without rivets as the same p/n 52007398 and both use 52003759 for center caps. It seems that Jeep themselves labeled them as the same wheel.
  2. Interesting. Thanks for digging. I've seen people talk about 15x7 versions of the gamblers before, but have seen no pictures of them. I know I've seen people reference both the OE 10 hole wheels as gamblers too, so could just be muddling of the terms. Looks like I need to pay more attention to YJ stuff for sale in hopes of finding some.
  3. I also saw that but was thinking someone here may have more info. Both versions have a DOT stamp on the back and almost every set I've seen locally in the last few years has the JWL logos so I don't think they're from a mail Jeep. Doesn't mean they were made by the same supplier though. The maybe 3-4 sets I've seen without have been trashed and really would only be good for a trail rig. 3 of my 4 on the truck don't have a logo and at some point, I'd like all of them to match. Even better if I can find enough to have the truck and trailer all matching. I seem to remember reading years ago that the ones without the JWL logo were YJs and the ones with were TJs but it seems harder to find info like that now. The hub bore itself and the distance from the WMS to the center cap is the same, but the actual opening for the cap is about 1.5mm difference. Just enough to not be able to swap them. It works great for it. Plus, now the truck, trailer, and the porch can all have matching wheels lol.
  4. So, I've tried googling but google is kinda garbage now. I have 2 different types of Gamblers on my truck. They have different part numbers on the back, they obviously have different castings they were made in, and they use different center caps. What's the deal with the difference and how do I find more without the JWL logo cast into the face? Bonus pic of my "hose reel"
  5. Man, if that was a 7 5/8 i would totally get it.
  6. Just to put more info here, my truck measures over 3 inches what the factory service manual says it should measure with four-wheel drive springs even without the aftermarket shackle. Using the method posted above mine measures 12 9/16" from the axle tube to the frame rail.
  7. My condolences. Losing those kinds of friends is definitely one of the harder things to deal with.
  8. I have the general spring ones listed here. With a 3/4" lift shackle it put's my lwb right at 4" over stock completely empty. With the canopy on it's a little lower than that but the carrying capacity is WAY better than the AAL I had before. It's for sure stiffer than the sagged stock leaves with an AAL but it's not out of the ordinary stiff. I've had plenty of non-truck friends ride in it and they say it just rides like an old truck. Whether you'll be level or not depends on your front spring. Mine's a very old RE 3.5", so it actually only gets the front to 3.25", but that means the truck has the factory rake to it which I prefer.
  9. Mine is just 64" at the widest and about 45" from mount to mount. So I think you were sent the wrong one.
  10. Just for clarification General definitely does still make a metric ton spring. They just don't make the one designed with the lift and military wrap that the original club group buy was for > https://www.generalspringkc.com/leaf-springs/jeep/comanche/ I recently put this one on my truck and with a shackle that gives about 3/4" lift I'm sitting at 4" lift over stock roughly. And that's with a long bed and a camper top. With a 800# slide in camper it's still sitting just at 3". So keep that in mind with short beds. I'm not amazed with the paint that comes on them, but have no complaints otherwise as of almost 5 months of use. How it rides unloaded With the camper top And the camper and trailer hooked up, all in relation to an old 3.5" Rubicon express front spring that rides at 3.25" ish over stock.
  11. https://stronghandtools.com/products/hole-plug A magnetic copper spoon will make the job a hell of a lot easier.
  12. I have the add a leafs that got me to 3.5" with a shackle I'm not gonna use any more if you're interested. They're the full length ones from a zone off-road kit I got from @scguy a few years ago. I'd let them go cheap.
  13. SC requires the car to at least be 25 years old, and it can only be used for club activities such as shows to be registered and plated as an antique. They restrict the driving to a certain amount of mileage a year, and you can't drive the car as you regularly would. You also have to have antique insurance on the car. However, if it's over 25 you can run a year of manufacture tag. So, since both my trailer and my Comanche are 86s I got a matching set of 86 car and trailer plates off eBay and can run them. Maybe we could make a printable "club membership" card for anyone who needed it? Kinkos does laminated stuff if it needs to be official looking.
  14. I went with Bilstein 5125's in the rear pn 33186542. For the fronts I got the 24188197 that are intended for the XJ/MJ. I'm right at 3.25" f/r and they ride much nicer than the Monroe OE spec ones I had before the lift.
  15. Slowly digging and digging. Got the foam mostly off of the roof. Still can't figure out where a boat rack would have attached to. The entire middle is just the aluminum skin on foam, which gives no real rigidity. The outside edge has a this weird 1 1/4" quarter round to give the curve of the roof structure. Couldn't find anywhere local that sold anything similar without a massive tool set up cost. Menards sells 1 1/4" quarter round, but I'm not taking a 10 hour trip for 24' of trim. I'm gonna use the router table at work and try and replicate it as best I can out of 2"x2" since all of it is rotten. At some point a critter had burrowed tunnels through the roof foam. Not sure what would burrow into styrofoam, but I know I don't want it in my camper lol. The fold out sides are more rotten that I thought, meaning I'll need to rebuild them as well. Aiming to get the roof redone in the next few weeks as I was taking some screws out of the door frame and about a gallon of water shot out. So, I want to get the roof to a point where the frame isn't taking on water anymore.
  16. Not a massively satisfying update but have been parts gathering all year. I've got all the panels and braces to replace the floor, along with seam sealer and paint for inside and out. Need to find some time to get that done. Also, I had been searching for about a year for a 3.4 donor. I originally was trying to find a 93 as they would have a 4L60 not the 4L60e, but that proved nigh impossible. That's when I saw @dasbulliwagen post in the pub about values on his parts cars. I went up and checked the car out and we got it to run momentarily on starting fluid as the fuel pump is most certainly dead. We arranged the sell and now I've got the Camaro at the house. It was cool to meet another longtime member in person and get to see a truck I've been reading about for years now. The plan is to thin the wiring of all unnecessary stuff and make a stand-alone harness to control the 3.4 and the 4L60e. The car came with a set of Pacesetter headers that I'll see if I can use and some aftermarket radiator fans. Which is nice since I won't have to buy any. There's a little funky wiring here and there, but overall the car seems in great shape. I nabbed a ZJ NP242 with less than 100k on it for $100 and bought a Novak adapter so it'll bolt to the back of the 2wd 4l60e. I've also bought a metric ton of seals to change on the 3.4. I've got a long trip out to Oregon this year to visit family and my daily and mom's car need a good bit of work done to them, not to mention stuff on the house that needs done, but I'm aiming to get all of this accomplished by the end of the year.
  17. I would be very interested in the Camaro if you'd be interested in separating. I'm also only a 2 hour drive from you. Edit: As far as the value of the Camaro, I've been looking really close lately trying to find a donor for my 86 and the going rate in at least the 250 miles range I've been looking in seems to be $2000-4000 for the 3.4s mainly dependent on mileage. Not sure how the title comes into play because I haven't come across one with that particular situation. As for the value of the others. I'd say the 86 roller would probably fetch $1500ish going on the prices I see on FB and CL. The Wagoneer is a different beast. To the right person it would be worth a good bit, but to the average XJ buyer I doubt they'd give much for it. You might have better luck moving that one on the XJ Wagoneer group on FB.
  18. Clearing crap off the property. Metric ton springs barely flinch with 8 sections of rotten fencing and a pallet in the back.
  19. On occasion I've bought SKF and got a Timken bearing and the other way around. I replaced the ones on my truck with the Mevotech ones on Rockauto last year and have had no issues after 5000ish miles. The only reason I didn't go with Timken or SKF is the Mevotechs had double the length of warranty at the time. For joints I'd stick with Dana as well.
  20. Long road trips are my favorite form of vacation and travel. My longest in the Comanche was right at 3200 miles. I'm hoping to take it up the Alcan highway into Alaska one day. Central and South America would be an awesome trip as well. Good luck on your travels and most importantly have fun.
  21. This is such a crazy cool build. Very excited to see a Comanche with a M57. I know the Patrol guys in the southern hemisphere love swapping them in because of the torque and they sound awesome. You're gonna have one hell of a truck once it's done
  22. Hey at the very least a photo shoot would be necessary lol. Digging into the roof more I'm even more puzzled though. Oh I definitely will. Life at the moment is keeping me from traveling a lot, but I'm trying to gear myself up for when that opens up I'll be very prepared to goof off far and wide. So I dug into the camper much deeper last Saturday. Got the canvas fully pulled off so I can remove the bad sections and make templates to recreate them. Got some swatches in to try and color match and surprisingly the natural canvas is the closest color match. I might try to use some RIT dye to match, not sure yet. And I'm still perplexed by the roof. I donned my respirator and started pulling the ceiling off. The whole thing is moldy. It very much seems like the Styrofoam is just glued to the aluminum roof skin. I had to jam my scraper in between the foam and whatever it's glued to rather hard just to get this little bit off. Also, the foam is completely soaked in water. Judging by the surface area and how much water comes out I think it probably adds about 75 lbs to the camper Also pulled the veneers off to get an idea of how the lower "walls" were built. Seems like 1/8" ply with what was advertised as a distressed elm veneer. The outside seems to just be 1/4" ply. Elm is nigh impossible to get in a typical lumber store but I've found a very small husband and wife team that sells specialty veneers for very reasonable prices so I can keep the interior in the red elm it originally came with.
  23. I've been following a guy on Instagram who's swapping a 3UZ into his 3rd gen 4runner using a R150 and 35's. If the older 150 can handle the 3UZ's stock 330 ft/lbs while turning 35s I think you're on the right track.
  24. Yeah I reused the original u-bolt plates so it has the shock mounts. Currently I have some KYB excel-g's that were on my truck before I upgraded to the Bilstein 5100s. Makes it much nicer to pull.
  25. Honestly I'm really tempted to just put some leveling jacks on the back of the frame and leave it on there
