Everything posted by coheed
If there was interest in getting a group buy together I'd be in. Hell if we could get them to do the lifted metric ton one again I'd pay decent money for that set.
Squirrelly Dan: Coheed's 86 Custom
coheed replied to coheed's topic in Member Projects: Your Comanches
It's incredibly basic. I just built a frame with 2x4s and then slapped section of 3/4 OSB on top of it. I think it measures 30 by 80. You can also see in the pictures where I cut out the back bottom of the frame to put the drawer in. The drawer is just made out of the leftover cut of the OSB. I also put 2 eye hooks on either end of the frame and ran 2 turnbuckles to the tie down loops in the bed to lock the frame in place. Eventually I want to redo it so that the platform goes all the way across, and I think next time I do it I'll take the plastic bed liner out to get a little bit more headroom. I'd also like to have two drawers instead of one. I know I've posted in the FB groups when people ask for pics of sleeping setups and there's been a few others that've replied as well, so you might be able to find more there. Truck bed living on Instagram shares a bunch of people's builds and their website has a huge index of info for truck bed living/camping as well. -
You can get amazing deals on those government surplus auctions. We recently auctioned off a old lathe that had a 8-ft bed and a 2-foot work radius, and the guy ended up getting it for $1,800. And I had a kid working for me last semester that ended up buying a single wheel 250 super duty from his dad's forest service unit for $3,000 I think. Granted it was the Triton not the powerstroke, but still.
Ended up going with a heim instead of the poly bushing because of the angle of the track bar mount. Worked out well because that means there's an inch more of thread engagement and I was a little worried about how little was engaged on the poly one. Rebuilt packs with the full length AAL in the middle. Also a quick coat of paint on the 4.10 D35. Worked out to 3.25" front and rear. I'm wondering how much the rear will sag with the camper top and sleeping setup in the back as when both the old axles were in the back it sagged about an inch. But I am planning on a hidden winch at some point up front so maybe it'll all even out At any rate the eventual plan is to get some metric ton springs to compensate for the camping setup weight and the weight of a trailer, and this is a medium term solution. But the switch from 3.55 to 4.10 is astounding. Just crawling around the yard in 4 low I can feel a huge difference. -
The 904 is a desired transmission for classic class drag racing. It'll hold up perfectly fine to the 3.4. The only limitation would be lack of overdrive, and needing to get the flex plate neutral balanced. No overdrive can be compensated for with gearing and tire size. Also, just so you know the transmission you have will bolt directly to the 3.4 with no mods aside from rebalancing the flex plate.
YJ caliper bracket the same as the Comanche one?
coheed replied to coheed's topic in MJ Tech: Modification and Repairs
For anyone curious or looking for the same info, the brackets are the same. -
So I have an older rock krawler track bar and a stinky fab frame side bracket. The bar has a steinjager poly rod end on it currently because I was hoping to avoid a little bit of NVH over a heim. The issue I'm having is the bolt holes refuse to line up with the poly end. If I get one side lined up the other is about 3/8" off on the other side. I've rocked the truck every direction, rocked the steering back and forth, even used a ratchet strap (which I know is a no-no when aligning suspension stuff) and nothing gets it even close. I'm going to try a heim that I have laying around tonight, even though it has incorrect misalignment spacers. My worry is that even with the built in pivot of the heim I won't be able to get the holes lined up. Anyone have thoughts or suggestions?
Haven't seen a red one. Will have to keep my eyes out for it since I commute that way for work. It's very interesting that Comanches seem to pile up in smaller areas lol. If you ever need an extra set of hands let me know.
Replaced the crappy external torx bolts for the caliper mounts with some old Toyota bolts. New front ride height. Axles stretched a bit forward, but I like the look. -
Yeah I originally said I wasn't gonna go more then 2" of lift and I just got the front back on it's own weight at 3/3.5" lol. The longer I own it the more hacks and horrible fixes I find on it. Plus it wasn't a clean truck at $1500 when I bought it, so I don't feel super bad about not keeping it stock. Is his the really nice restored and lifted silver one? I know of 4 MJs around us; yours, mine, the nice silver one, and a swb burgundy one that stays over in Indian Land but I've seen over in Fort Mill a lot.
Lwb was 16 or 24. The 16 is the same dimensions as the 24 but with a shorter vent tube so you can't fill it up as much.
I've got a 16 gal lwb tank that I would give to someone that wants to do this experiment in Fort Mill SC if anyone would be interested in trying this swap.
Thanks man. I can already tell it's gonna ride better with the RE springs even with it still on jack stands. Slow and steady. -
Just saw a Comanche crossing 160 this morning and thought I recognized it. Truck looks great man
I will say I bought the XJ ones and cut about 2 inches off. Fit pretty damn well and cleared the frame like the stock ones. The MJ ones are no longer made so NOS would be the only option.
So I have the earlier knuckles with the separate caliper bracket, 2 sets actually. Long story short the ball joint preload thread is screwed in the set that has the mounts attached and the bolts for the mounts are just not coming out. Even with the oxy/fuel torch getting everything a warm red glow before I try and break them loose. I can grab a set of the YJ mounts off eBay for about $30, but was hoping someone could tell me they were the same before I pulled the trigger.
Snug Top Topper window/cab seals
coheed replied to TheDirtyJeep401's topic in MJ Tech: Modification and Repairs
https://socalcamperparts.com/ I've ordered from this place many times for topper parts. If they don't have it they may be able to help you find it. -
Slow progress with my schedule, but I got the knuckles sand blasted and painted with VHT. Also got the ball joints removed, new axle seals installed, and 3 coats of Por15 on the 4.10 axle. Ring and pinion gears look good. Did the coats of Por15 on separate days so it could cure well in between coats. Also soda blasted the spots I couldn't get to with a brush or wire wheel. Also got the control arms adjusted to where I think I will need them. Well obviously do final adjustments after everything's back together. -
Hopefully they come out soon. The promise of having a prefabbed version is what made me decide to put off replacing these floors.
Got a reply to a comment I left on a Key Parts post weeks ago. They say the manufacturer is packing them up. Only time will tell.
Small update. Starting the axle swap/new lift. Swapping from 3.55s to 4.10s. The axle set is out of my grandfather's Comanche, so it'll be a straight swap. The Dana 30 will get new oem seals and ball joints, control arm bushings, and ZJ cv axles. Both axles will get new brakes. Lift will consist of the following: Zone off-road AAL Zone off-road shackles Rubicon express 3.5" fronts JKS quick disconnects Rock krawler track bar with a stienjager poly end Stinkyfab racing track bar mount Bilstein's front and rear, but can't remember p/n's right now My rear springs are super sagged. Like they sit at factory height with Chevy drop shackles with 350#'s in the bed. Hoping the full length AAL will help and the 3.5" fronts won't be too tall. If they are I'll deal with that -
I would definitely keep it. The long bed toppers are getting harder and harder to find, and I see way less high rise ones then the even with the cab ones. And I'm biased, but think a lifted lwb with a topper is the best look for an MJ.
