Everything posted by maddzz1
That letter is an example of how crazy religious people are. She says shes glad she don't have children? she is probally so uptight from being raised by an overbearing religious lunatic of a mother that she has never even been on a date. :nuts:
Things usually happen for a reason, especially to good people. You said you have wanted to move. Well maybe now you can move and still collect a check (from collecting) while you move and get settled and hopefully find a new job before benefits run out. Try to stay positive Brent.
He already changed it 3 times
From the reading I have done chico, a thermostat is actually there to keep the engine hot, not cool. Ive also read that our engines like to run hot. If it isnt overheating and your new tank has fixed the problem with the cap on the expansion tank then I say forget about it. only because it seems like there is nothing left to check.
MAYDAY MAYDAY!!!!!! stupid open system cooling
maddzz1 replied to martywarner's topic in MJ Tech: Modification and Repairs
It sounds like there is rust in your system from somewhere. If you are not comfortable flushing the system yourself than I think you should bring it somewhere and have it done. For the $7, I would replace the thermostat when it is done too; I would get one that is 195* Just saw your second post. A pressure test would be a good idea. Are you sure it isnt just antifreeze that settled there when it overheated? your sure it is coming out between the head and block? -
That is right near me. If you decide to buy it, i can pick it up and ship it for you if the owner isnt willing to ship.
Welfare should last only 4 years. You should HAVE to be in school FULL TIME and they should let the person keep medical and food stamps for one year after the 4 years is up and they have a job with a degree. Once you sign up, your 4 years has started. if you stop school for a year you are off the program until you sign back up but that year still counts against your 4. This should save alot of money in the long run. And it goes to: if you aren't willing to help yourself then the gov won't do it for you.
Looks like Pete could squeak out a win this week :bowdown: (even tho his opponent only started 5 players) :yes: which could move Pete into a tie for 1st in his division; accomplishing his goal for the year: Quote from Petes post: I'll bite. I feel the need to prove that a novice that beat experts when it comes to dumb luck. #2 took out meatcurtains which leaves me and him in a tie for 1st place.
I think the brakes were only different on the rear depending on the axle; I think the fronts are the same but not positive. Try Rockauto.com for the e brake parts. If they aren't listed on the site send them an email. great prices and service.
Low/ inconsistant oil pressure
maddzz1 replied to Ben-88Comanche's topic in MJ Tech: Modification and Repairs
:eek: Can it really be that simple? I have the exact same problem and i also use a fram filter! Its about time for an oil/filter change anyway so i will definetly try it. Yes, It can actually be that simple. Good for us; Bad for fram. -
A fram filter did this to me too. I replaced it with a NAPA Gold (which is made by WIX) and the problem was fixed. No more Fram for me. -
What be this electrical thinger?
maddzz1 replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
It looks like it may be a voltage regulator. But not sure. -
I have been wanting to get a decent digital for a while and the prices are finally coming coming down enough, so hopefully soon. Is there a setting on digital cameras to take black and white photos? I have always liked B&W photos.
Maybe you should offer to take them wheeling at the next comanche club get together if they start producing foer you.
There have been some good players on waivers lately. Keep your eye on the free agents Pete. Alot of times people have to put a good player on waivers to pick someone else up to cover a bye week. Thats when you snatch up the good player. My wife picked up Chris Chambers and some other decent wide receiver last week.
Wahoo, Your just mad because you got beat by a girl. :rotf: SW2, You, Me, and Meatcurtains are tied for 1st place.
Rear Main Seal Repair gone bad
maddzz1 replied to robfg67's topic in MJ Tech: Modification and Repairs
I'm not sure but I don't think the dealer has the doubl lipped one. You can get it at NAPA. -
Filling coolant in a closed system
maddzz1 replied to james750's topic in MJ Tech: Modification and Repairs
When I put my new radiator in I just filled thru the pressure bottle. When it sucked the antifreeze down I just added more. I did not drain the block tho. -
So you have to remove the bulb thru the side, right? The lens does not come off (w/out breaking)?
How do you change the bulb? The clear lens turns a little to the side but thats it. Is there a way to get the lens out w/out breaking the little clips?
If he doesnt want to work out a deal when you talk to him I would remind him that the number of people you can make sure don't come to his shop is alot larger than the number of people you did send to him.
mj sender/pump in xj tank?
maddzz1 replied to redneck23ms's topic in MJ Tech: Modification and Repairs
Someone tried to fit the XJ sending unit into the MJ and the they are actually opposite of each other. The float arm and the filter are on opposite sides which caused it to hit on the "pan" inside the tank. So I think the same thing would happen if you tried the MJ in the XJ tank. Here is one thread with some good pics http://www.comancheclub.com/forums/view ... nding+unit -
Another window regulator thread
maddzz1 replied to mfpdm's topic in MJ Tech: Modification and Repairs
Would using an anti-seize to coat it instead of grease work as a rust preventer? -
Picked-up the axles...let me know what you think
Sorry I didnt get back sooner rob. Me and a friend actually buy alot of small parts for our Mjs from them. I thought he might give you the refund as I have never had any problems with them. They even tape letters to all there shipped packages asking to let them know if there is any problems and they will fix it. I was actually there on Friday and have to go back this week.
