martywarner
    Guelph. Ontario. CANADA
martywarner's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. well took it to a rad shop an they tested for the pressene of combustion chamber gasses in the coolant and bingo headgasket gone. anyone want to buy an 89 2wd with blown headgasket.
  2. not sure how long seepage has been there. as far as pressure test are you saying cyl leakdown or coolant system check? i did the t stat in jan and put a 195 in
  3. ah and there is some seepage on the pass sie of the motor between the head and block
  4. sorry guys just got in off the highway. the truck is the 89 i forgot to change my signature. so it has the stock closed system my bad its the stupid one with the bottle up by the fender i refilled the system tonight and it seems to work fine the 4 miles i drove it home. however the $#!& that is coming up through the bottle is a gross brownish green colour. the water pump seeems to work fine as it moved the coolant as i filled it. gpoing to take it out for a good tour and see what it does would it be n m interest to take it to a shop and get the system flushed? thanks marty :Canadaflag:
  5. So in a long line of cooling questions and problems here it is. Coming home from a friends place the other night on the 401 running right at 100kmh i noticed the truck start to heat up! did not get to hot so was nt too worried. then when i pulled into the drive way and shut the truck off i could hear it bubling away hmmmmmmmm. took the truck out today did not mak it 4 blocks and the temp gauge was maxed SOB so i looked under the hood and realized i know sfa about open cooling systems. so with the information could you guys please help me figure out what the issue is hear? thanks ooooooo and another thin is i barely have heat like not enough to defrost the windows in the winter and even when the truck was overheating it was still not hot? please help winter is hear and its cold. oh byt he way it is a 89 eliminator 2wd 4.0 5speed. thanks guys marty :Canadaflag:
  6. there is a few things to keep in mind when putting a radio in you truck it is best to find a cb shop your local truck stop can point you in the proper direction there. things like coax cable length anntena placement anntena type radio power all help in having a dependable radio that gets out more than 10 ft. on my jeep i have a 4 ft fibreglass anntena off of a pete i used to drive and run the standard 18 ft of coax and my radio is a uniden pc 78 thats been bumped up to 42 watts peak so it works great gets out about 10 miles ;)
  7. ya i thought tha i will look anyway but it did not blow hot before the mishap. on really cold days it makes just enough heat to keep the windshield clear but i still have to wear a touque and gloves and parka i guess i should tear into the dash and have a look see but i will check the vac cannister first thanks.
  8. ya it only blows heat through the ddefrost and dash vents and freezing cold to the floor when that is selected. i am kinda dissapointed my 87 4cyl made amazing heat. gonna just keep fiddleing with the damn thing
  9. i didnt flush but i dropped the coolant and changed the t-stat had a hard time getting the air out not sure if it is all out or not nt the level stays the same and doesnt fluctuate
  10. ok so here is the deal the heat on my 89 2wd 6cyl is not working the motor does not get that warm either the temp gauge goes to about 75 degrees celcius thats like 167 fahrenheit and thats loaded, empty, idle,wide open doesnt matter its gets a little warm but not really. any ideas would be helpful. also does any one have experience with the fibreglass fenders he sell for the manche do they fit well? i want to build a semi prerunner deal and like the looks of masscrawlers mj. i had a little incident with the ditch up north and need some front end beutification. and i bent the axle and had to replace it with one out of my spare truck. thanks marty :Canadaflag: this is the garage door in my garage -18 and snowing..nice just for fun this is what a turbo on my pete looks like when it lets go at 20,000 rpm
  11. I had a 95 nissan hardbody 2wd prerunner style and we used to jump it out of my friends berry patch i will see if we can dig up the pics somewhere we measured it out at like 42 feet distance i cut the top of my head open on the roof it was a blast
  12. martywarner
    towing
    ten four all over the geo metro bsing of uhaul check the classifieds if someone comes up with $200 its gone
  13. martywarner
    towing
    thanks guys the truck is a 2wd and i thought about just undoing the ds and wire it up to the box but if you say i can just let her buck them i will marty
  14. martywarner
    towing
    Het guy just bouncing some ideas off of you. I am moving back to thunder bay On and am gonna be towing my 87 2wd with my 89 2wd no i thought about putting the 87 on one of those u haul dollies backwards so i don't need to remove my shaft. but i think that is gonna get a bit hairy on the triwsties running along lake superior. so i guess i will be stuck putting the truck on forwards and removing the shaft. just looking to see if anyone else has towed there manche with another and wondering what i should expect. :Canadaflag: thanks for the help guys marty. When in doubt tach her out
  15. Well today was fun had to go to toronto to load this morning it took me 4.5 hours to drive 93 kilometers. there was maybee 2 inches of snow on the 401. I'm from thunder bay and the only thing that slows down traffic like that is 20+ cm's of snow, this morning was ridiculous. I hate southern ontario can't wait to go north. :Canadaflag: marty
