maddzz1
Everything posted by maddzz1
  1. here's the link: http://www.naxja.org/forum/showthread.php?t=921205 I think anything up to a 90 will work, but I would go with 86 thru 89 to be safe. Then they switched to the electric speedo.
  2. Is the axle tilted too far forward or backward (pinion angle off)? causing the buckets where the coils sit to be tilted toward the cab? Are the tires centered in the wheel wells?
  3. I got a st croix premier fishing rod and a bass pros gift card (which i will use to add a shimano symetre to the rod). And my daughter put the prime rib in the freezer instead of the fridge, so by the time we noticed it was too late and we had to order chinese food. :doh:
  4. Hey jeff, any progress with this yet?
  5. maddzz1
    ewwwww.....
    Dig it up, pit it in a few garbage bags and drop them out front of the nearest jiffy lube late at night.
  6. Does it give any message when it shuts down or when you start it back up?
  7. What djag accused Wade of isnt even possible. Wahoo, I don't have commissioner type privelages. All I can do is choose certain options when setting up the league (like having a flex position). Anything else has to be done/ok'd by the commissioner of nfl.com. Like if someone wanted to drop an "undroppable player" they would need to send the request to him, not the person who set up the league. I had alot of fun playing this league this year and I hope everyone else did too. I would definately be into doing it again next year. Maybe we can all chip in $5 or $10 with a winner take all league. This will also prevent people from joining that arent going to finish out the season. With all that being siad: Congrats Wade You deserved the win. I think you definately had the most consistent team all year and definately one of, if not the best, team in the league. :bowdown: :bowdown:
  8. Could someone please post the info of which gear ratios come with which engine/tranny combo again. I can't find it.
  9. Hey Jeff, I resemble that remark. I have no such thing! Who make's 'em? :D You resemble that remark? :huh???: Are you trying to say you look like a chrome windshield washer cap? :dunno:
  10. You can also order a set from teamcherokee and just replace both of them. Thats what I had to do because one had a key broke in it and the other one fell apart. here's a tip for replacment: The clip that holds them in is very hard to remove. There is a plug on the end/side of the door; if you remove it you can get a screwdriver against the clip and tap it with a hammer to pop the clip off.
  11. Would it be possible to get (read as do they make them) ravines for the back with different back spacing to even it out. If it is possible, I would think it would be cheaper/better than spacers.
  12. There is one on my truck that was there when I got it. The snaps for it are actually right into the bed sides, then the cover snaps to them. I would never have had holes punched in the bed to put the cover on if it had been me. 87comanche has a nice one that he scored on Ebay for real cheap and it looks and fits great.
  13. It is sherman site that has Mj pans. http://store.shermanparts.com/cgi-bin/s ... mg_num=075
  14. I like how he says "jeep comanche(XJ series)" :dunno: :???: here's a site that has the MJ ones: http://store.shermanparts.com/cgi-bin/s ... mg_num=075
  15. If the truck will stay running with the key held to the start position but stalls when you release the key back to the run position then this is the exact problem that lead me to find this site. If this is the case, it is a wire next to the fusible link next to the battery. I am not sure exactly which wire it is because I eventually brought it to an auto electrical shop and had them find the wire; after finding someone else who had the problem and told me how to fix it. I also tried the ignition switch and ballist resistor before finding the solution. To everyone: My feelings are badly hurt that no one remembers my first question on the board. :no:
  16. Sorry Maddz1, Thrice Whooped... Looks like #2 and Rocket Dogs for all the Marbles... Yes, it appears my trap has failed me. Good luck #2. Ill be routing for you. You definately have the strongest team. :bowdown:
  17. Sorry Maddz1, Thrice Whooped... Looks like #2 and Rocket Dogs for all the Marbles... Yes, it appears my trap has failed me. Good luck #2. Ill be routing for you. You definately have the strongest team. :bowdown:
  18. A good start might be installing a double diaphragm booster if you havent already.
  19. A good start might be installing a double diaphragm booster if you havent already.
  20. Is it the 4cyl 4speed or 5speed that has 4.10's?
  21. here is a link to an an electrical manual that taz posted. may be a different year, but should be similar. viewtopic.php?f=9&t=12734
  22. Wahoo, I did not change the rules. If i had, the first rule would have been that wahoo is not eligible for the playoffs even if he comes in first. :wavey: When I looked at the records last week I actually expected to not make the playoffs, I wasnt aware of how it was judged. Now to #2. Yes, it appears that you have fallen into my trap.
  23. maddzz1
    i love ebay
    I always click on the auctions only tab. Eliminates all the buy it nows.
  24. I hear ya. i had never owned a jeep and had one truck before. It was given to me by my father because i always liked it and he didnt need it anymore. I found this forum because it had a starting forum. After doing some reading it became obvious I wasnt the only one who liked these trucks. I have also spent endless hours reading, usually because like you stated, starting out reading about one thing leads to reading about five other topics you had no intention of looking at.
  25. I don't see what he did wrong. Do you mean your not supposed to run water thru your engine? :wavey: :dunce:
