SloatsburgComanche
SloatsburgComanche's Achievements
  1. there are 3 poles and one connecter on coil one positve pole then positive wire connector then negative pole what is supposed to be connected to the wiring connector between two poles??????thanks
  2. still not really helping me in need wiring diagram for coil
  3. -DROVE JEEP 3 MILES AWAY TURNED OFF...WOULDNT START FOR 5 MINS THEN DID......FIGURED IT WAS COIL.......DROVE HOME AND IT DIED WHILE DRIVING........ HAD AN IDEA TO PUT COLD WATER ON COIL AND IT STARTED RIGHT UP.....DROVE IT HOME......SAT LAST NIGHT.....TRIED TO START THIS MORNING AND NOTHING.....PUT NEW COIL IN ALSO NOTHING.......NOID LIGHT SAYS NO SPARK AT ANY CYL..... I NEED A WIRING DIAGRAM FOR THE IGNITION COIL....AND POSSIBLY THE DISTRIBUTER........................PLEEEEEEEEEEEEEASE HELP ME I NEED TO FIX YESTERDAY!!!! :doh: :bowdown:
  4. 88 comanche prob same switch at cherokee I need the wiring diagram for the wires coming out of the switch
  5. i need a wiring diagram for the rear taillights/brake/signal/lescence lights from the cab back can anyone help?? 88 jeep comanche 4.0L
