Everything posted by Lewt2007
If this is not a cargo light, then what is it?
Lewt2007 replied to 8valvehero's topic in MJ Tech: Modification and Repairs
factory rear bumper delete option mine has the plate and light behind the tube rear bumper- 11 replies
- cargo light
- bed
(and 1 more)
Tagged with:
got the cherokee one piece front under the truck and put a set of 31x10.50 tires on 15 in six spoke wheels photos to come of it how it looks and sits now soon to have the 93 cherokee computer and engine harness installed to correct transmission problems along with a late model cherokee radiator and a aftermarket trans cooler to eliminate transmission cooling problems
You are correct as the 4.0L will not fit into an '86 MJ. They redesigned the whole engine compartment in '87 to fit the longer 4.0L in there. I've seen GM 3.4L and 3.8L engines swapped in place of the 2.8L but haven't seen too many 4cyl's upgraded. There was an AX-5 behind the 2.8L in mine but that was only cranking out a whole whopping 140hp. I chose to swap in a Chevy 350 instead of fighting with the 4.0L (was looking at putting more power in there so was either going to be a 5.7L V8 or 4.7L stroker). Novak makes adapters to put an AX-15 behind the engine and they make motor mounts to fit, but the motor mounts will have to be slightly modified to fit the '86. I'm not sure exactly what you're planning on doing with this Jeep but you will need an AX-15 5sp manual trans if you intend on going with anything larger than the V6. my body was a 86 2.5 and i put the 4.0 out of a 90 in it without modding the firewall the difference is in the core support area not the firewall
http://www.miniclip.com/games/monster-stunts/en/#?utm_source=facebook&utm_medium=fb-post&utm_campaign=monster-stunts check out the link game involves a monster Comanche
I'm in Lisbon ohio if any of you want to race em come on down to lisbon at Tri County Four wheelers here are our sand drag dates 2013 Race Schedule Street stock $20 100% payback May 18 (test + tune) June 8 June 22 July 13 August 10 September 14 - FALL BLOWOUT Gate fee $10 12 and under, free 65 and older free active military free Primitive camping is available on Sand Drag weekends. for more info Check out www.tricounty4x4.com
a little info about my shop and yes its a fully equipped auto repair shop Lewton's Garage 121 N. Nelson Ave. Lisbon, Ohio Bob Christy supplied the address and offered the following details: "I know the Lewton family and their Jeep dealership in Lisbon, Ohio very well. I used to race with Pappy and Davey Lewton. The dealership is still a garage and you never know what you're going to find in that old building. In fact, Bill Lewton, the patriarch of the family has a great collection of Willys vehicles from his 1918 runabout to a supercharged Kaiser Darrin to a really nice 1951 Jeepster. They stopped being a jeep dealer shortly after Chrysler took over Jeep." Davey Lewton, who runs the garage now, owns the CJ-3B seen in this 2002 photograph:
i have a set of led driving lights mounted to the rear bumper of mine
i did 5% tint on both sides myself just got the install kit and two rolls of 5% dark at the local walmart and have passed several state and local police with it and have never been stopped for them being so dark
tow hooks were also dealer installed not necessarily part of the off road package i have it but don't have the tow hooks they used a different bumper bracket that they mounted to besides the standard bumper bracket that most xj/mjs had
i seen one a few years ago at a repair shop that was a comanche with dual front wheels
but what do you do if the transfer case doesn't have a place for the vacuum switch and is out of a later year cherokee
Looking for some parts for 87 Comanche
Lewt2007 replied to 87comancheMI's topic in MJ Tech: Modification and Repairs
bushwacker is making flare kits for the mj http://bushwacker.com/fender.asp?dhtmlgoodies_TruckSUV=5&dhtmlgoodies_model=91&search=Search -
they were built on jeep j10 frames with heavy duty suspension under them
just tinted the windows on it last summer they are one shade above being illegal dark here in ohio
local landscaping company neer me has 3 or four of em that are used daily as landscaping trucks
between me and my dad there are 10 jeep models my comanche my 98 grand cherokee a 03 grand cherokee 2 j20s a j10 2 cj 3b's a xj cherokee parts jeep, a willys jeepster and many others made by jeeps parent company over the years
Better make sure those have the 5 on 4.5 bolt pattern or they will not bolt up without the use of adapters to get the larger 5 on 5 bolt pattern
i switched to Casterol gtx high mileage with a bottle of Lucas oil stabilizer in mine it has 130 on the second motor. i had the boys at the quick lube at the wal-mart store i worked for change the oil for me and have had no problems whatsoever with the fram filter for the 4.0 sad thing is all of them are made the same place they just put a different canister on the outside but are pretty much the same inside i have 60 pounds of oil pressure on first start up and it stays around 60 pounds running hot.
i might have one have to check the cherokee that i got the drive terrain for mine out of ill sell it to you for 50 plus whatever flat rate shipping is at the post office
i use napa evercraft tools lifetime warrenty have broken ratchets air ratchets sockets and the occasional screwdriver due to ive got a napa store in my hometown and my dad is at napa several times a day if i break it its replaced no questions asked
correction pro-line is still making them i just checked they are 43 dollars new i got a brand new one its going to go on a traxxas t max chassis here is the link to the page to buy them http://prolineracing.com/bodies/jeep-comanche-full-bed-clear-body-one-piece/
My dad is a jeep mechanic by trade we put the 93 Cherokee motor transmission and transfer case in my 90 comanche all we did was change the flexplate and distributor over from the original 4.0
i am looking for a engine control harness for my 90 Comanche that has all the connections for air conditioning. also looking will pay any price and shipping for harness trying to install ac and don't have the correct harness for the equipment truck came without motor trans transfer case that i installed had everything but its out of a 93 Cherokee and the engine harness is different in the 93 Cherokee
