Lewt2007
Everything posted by Lewt2007
  1. if you mean the comanche thundercheif it is on display at the walter p chrylser museum ive seen it and have been close to it in the museum here's the link
  2. Steel Blue Metallic is my favorite factory color even though the comanche never came in it from the factory mine is steel blue
  3. to be honest with every one that comanche my brother did a couple years ago started out life as a stock eliminator comanche its on my brothers website http://www.offroadbabes.com
  4. Better check the gearing in the front axle because if they are different they will fight each other in four wheel drive. plus the two wheel drive rear is geared different. i started with a 86 and a 90 4x4 and transfered the 90 drivetrain and dash to the 2x4 to make it 4x4
  5. 90 jeep comanche with home built lift kit and custom paint Image Not Found
  6. i think your black fullsize jeep truck is a j20 not 10 because the 10 didnt have 8 lugs on it or a dana 60 under the rear of it.
  7. i have the metric tonne package but my rear springs only have the main leaf from the Comanche with a set of j 20 front packs bolted to the Comanche main with a 2 in add a leaf
  8. Cherokee rear bumper will not the factory one was a step bumper where the cherokee one isnt
  9. there is a strip of rubber that runs along the flare in the rear and the hardware to secure the flares is available for purchase without having to buy the flares themselves
  10. did you try four wheel drive hardware they have new parts for Cherokee's in stock and they will ship it to you in strasburg
  11. yes the reverse lights don't work
  12. my backup lights do not work. the truck has been completely dissasembled and re assembled the lights worked before but now they don't how do i get them to work
  13. turn the key until you can hear the fuel pump a few times then hit the starter and it should light on the first try
  14. the four wheel drive works but the light in the dash does not come on when i go in to high or low range what causes it and how do i fix it
