27
Everything posted by Eagle
I had a 4" lift on my '88 with 31" tires. This one looks at least as tall, or maybe a bit more. I'll guess 4" to 5" It sure is a pretty truck. Some day I'll get my '87 all nicey-nice like that.
X2 Sounds like a classic CPS failure.
Nope. Except for the early 4-cyl, which are 2", the exhaust systems on all XJs and MJs are 2-1/4". The catalytic converter is a 2-1/2" input, with a 2-1/2" outlet that necks down to 2-1/4" before entering the muffler.
You don't change just the window. What you swap is the glass, the surrounding frame, and the forward track for the large window (which is part of the vent window frame assembly. It's a fairly straightforward swap. Be advised, however, that the vent windows leak. The only certain way to stop them from leaking is silicone sealant. My '88 Cherokee had vent windows from the factory. I haven't opened them for 16 years. When I initially complained that they leaked, the official factory warranty repair was to remove them and replace with the stationary windows. At the time I refused, but now I wish I had accepted.
Don't have one handy to check, but my recollection is that the comfort/power switch has a pilot light, correct? So it's an ON/OFF toggle switch, same as the factory fog light switch, and the third contact is the ground connection for the pilot light. FWIW, Jeep did away with the switch in 1989 or 1990. Thereafter, all XJs (and MJs) came hard-wired in the POWER setting. Unless you are concerned about authenticity, I wouldn't worry about installing the switch.
The LWB Comanche sheet metal isn't perfectly straight, but the chassis is. Detour grumbled a bit about having to massage the lower rear quarter panels ... but he took the truck away, so there is now a template for him to work with. The rock rails won't be the problem -- he needs to get the lower rear quarter panels back into shape because of how tightly the rear bumper extensions fit to the body. Start saving your pennies, folks. LWB parts will be coming your way soon.
Yes, that's what I'm saying. Your stock driveshaft is 5/8" too long if you swap in a D44 without lifting.
If it's all the same to you, I'd much rather just go up to Logan Steel on a Saturday morning and see what's in the scrap bin. Who knows? Maybe I'll score a length of outer hitch steel tube.
Why? A Comanche with a blown engine is worth a lot more than a running Ranger or S-10, just because of the rarity if nothing else.
The steel used in hitch tubes and drawbars ain't special. Most folks would be sufficiently impressed if they just cited the fact that they use 1/4" wall tube and the competitors use (according to them) 1/8" all tube. (Actually, I think a lot of them use 3/16" but it has been awhile since I compared specs.) They didn't call it "hitch steel" to simplify anything. They created a meaningless term to make their use of ordinary steel tube sound special.
You obviously read the ad too fast, and missed the important stuff. They don't use ordinary hitch steel, they use INNER hitch steel -- with "astronomical" weight. (Funny -- my AISC steel handbook doesn't appear to know anything about this special grade of astronomically heavy steel, but I guess that's because structural engineers only design buildings and bridges, and not rock rails.) Now I'm curious. If there is an inner hitch steel, there must also be an outer hitch steel. Which is stronger and heavier? Maybe this stuff is inferior, and to get really REALLY good rock rails we should be using "outer" hitch steel. :eek:
The factory jack and handle for the MJ is exactly the same as for an XJ. Just hit the u-pull yard and look under the back seats of the XJs.
FWIW, the vacuum for the light works as CW said -- the switch should be on the passenger side of the firewall. The axle disconnect housing should have 3 vacuum tubes to it, but no electrical wires. As to the feeling that the t-case shifter moves back part way and hits a block: you are aware that there is a detent, right? It's a straight pull back to 4-HI, then you have to slide the handle to the right (offset) before pulling it the rest of the way for 4-Low.
I measured the difference as 5/8" but 3/4" is close enough. Yeah, the D35 driveshaft is too long. Cutting 3/4" off the end of the yoke won't do anything -- the outer portion will still slam into the tailshaft housing when the suspension compresses. The good news is that its a lot easier and cheaper to have a driveshaft made shorter than it is to have a longer shaft made up. Actually, the 3" lift might just be enough to make it about right. Shaggy dog story: A friend of mine had a 3" lift in his father's 95 XJ. For some reason he decided that he NEEDED to jump it up to 5", so he threw in front coil spacers and 2" blocks in the back. Took it out for a test ride and the driveshaft fell out a quarter of a mile down the road. So if a 5" lift is enough to pull a driveshaft all the way out, a 3" lift ought to be enough to pull it out 3/4 of an inch. Try bolting it up and check to see how much space you have left for it to move forward. Post that, and some of us with stock vehicles can tell you how close that is to OEM.
I am in Connecticut, and the man at Detours is a friend of a friend. I have a couple of longbeds here that he is more than welcome to come measure off of, but they are not running or registered so I can't take them to him. If he has a trailer and wants to borrow one for awhile, that would be okay, too. Have him contact me. He can find me either here or at NAXJA for a PM.
Yeah, but the Toy axle uses a 6-bolt flange, like on full-size pickups and the old full-size Cherokee and J trucks.
Too bad you're almost on the opposite side of the country from me. I have a 2WD 5-speed that I would very happily trade for a 4WD version. Actually, I have three of the damned things ... and two of them are locked in reverse.
well if this was my 88 that would work. but in my 86 that isnt where the vac ball is. and with this v6 i have no clue where it is. i will look for it and check there first though. thx alot. alex The vacuum reservoir on the 86 should be a metal coffee can looking thing on the passenger side inner fender, with a tube running to the center of the coffee can "lid." If you have cruise control, you probably have two of the cans mounted next to each other.
Except for the fact that the perches aren't the same distance apart. You canNOT just drop an XJ axle under an MJ and bolt up an instant SOA Best deal around on new perches is the universal ones from the Mopar Performance catalog. They run about $10/pair (yes, that's for the pair, they come two in the box), and they are BEEFY. Much heavier than stock XJ or MJ perches.
No, they were absolutely correct. It "should" just bolt right up. They simply neglected to mention that it doesn't ...
Change in plans, needs to be looked over.
Eagle replied to feerocknok's topic in MJ Tech: Modification and Repairs
IMHO ... bad idea. As already commented, they'll get hung up on things. ("Things" usually meaning rocks, but can also apply to tree stumps, old fences, dead cows ... whatever you're trying to over instead of around.) My '88 MJ had a 4" Trailmaster lift when I bought it, with the front control arm drop brackates. Same idea. I hated them. Rock magnets, is what they are. -
New TJ D30 shafts in an old D30
Eagle replied to holeski's topic in MJ Tech: Modification and Repairs
Many thanks for the number of the seal for the passenger side of the diff. Did it fit right in, or did you have to do any machining of the opening for the seal to fit? What I don't understand is why there are two other seals. The factory setup for no disconnect is just one seal, at the diff housing. What's with the second seal at the disconnect housing? If an axle with no disconnect housing doesn't need a seal in the middle of the tube, why does having an empty disconnect housing around a one-piece shaft require a seal? -
Yet another manual to auto trans Q
Eagle replied to Cabz's topic in MJ Tech: Modification and Repairs
Why do you think you need to swap harnesses? The TCU in an '88 is free-standing, it isn't part of the ECU. The ECU is different, but I know people have driven manuals using the automatic ECU, and I suspect you can go the other way. Not certain, but I think all you need is the harness to connect from the TCU (which mounts under the right side of the dashboard, by the glovebox) to the engine harness. -
160,000 miles is just barely getting broken in, and $750 for a running MJ with minimal rust is a steal. My MJ isn't that high in miles, but I ahve an '88 Cherokee (which is the same vehicle, mechanically) that's now at about 254,000 miles and has had no major repairs. Still gets over 20 MPG highway, and has seen some challenging 4WD trails. Stick around -- we'll help you get it straightened out. For starters, do NOT use the 4WD on hard, dry pavement.
Longbed? How much do you want for it? What kind of condition is it in?
