Oddmodman
Everything posted by Oddmodman
  1. Oddmodman
    Heartbreak
    I want like a million acre junk yard. Another man's trash...
  2. Oddmodman
    Heartbreak
    My neighbor just had a mini-stroke and I think he's realized he'll never get around to all his junkers in the back before he kicks the bucket. So yesterday these guys show up and start pulling cars out on a dolly. There goes an El Camino, don't really care; and then out rolls a 67-72 Chevy pickup. Sure the rockers are gone and the grill needs replacing, but otherwise it's pretty darn good. Went over and talked to them, they were indeed pulling things out to take to the crusher. It had a 4-speed manual, t-case, and good axles. Absolutely a crying shame. Discarding vehicles like that should be a federal crime. Breaks my heart.
  3. EXACTLY why I will not swap my bench out for buckets lol!
  4. Honestly I don't think it's terrible. It'd be hard to keep that finish alive though, methinks.
  5. Heat isn't hardly a factor here in Alaska, but I find that curious that all the 4.0s I've seen haven't had shrouds. :dunno:
  6. Oddmodman
    "jeepers"
    Well thank you that means I won't have to do any research :thumbsup: ; mostly I was just remarking upon his stupidity, especially for thinking bigger rims are bigger tires. I'll tell him about the lift, chances are he won't get it. I wouldn't know if I'd want to install it anyway for JeepcoMJ's reasons.
  7. Did they really come with shrouds with the mech fans? I have 2 MJs and just sold an XJ and none had shrouds. Is that a common thing to rip out then?
  8. Oddmodman
    "jeepers"
    So there's this guy I know that is another member of my church. He reminds me of C-3PO SO much it's sad. Anyhow, he's had a couple new Jeeps. He was telling me today that when he had his Liberty he was trying to ford a creek and hydrolocked his engine. In the middle of this story he's like, "Yeah, it's nice I don't have to dumb down my words for you; you know Jeeps." - (Referring to having hydrolocked his engine). So I was thinking, "Well that was stupid; don't you know where the intake is on it...??" He goes on to say how now that he has his new Patriot, it needs at least a two-inch lift, and asked what I would charge for installing it since he knows all I do is wrench on my stuff all day. Telling him idk what's out there for it and I'd have to research it, I asked him if he wanted the lift to put bigger tires under it, and he replies, "Well it's already got 18"s on it so I don't know how much bigger I want to get." OMG I almost physically :doh: . Some people think just because the vehicle they drive says JEEP on it, they're a wheeler by default... :dunce: :USAflag: :teehee:
  9. There are two golden torx bolts which hold down the seatbelt latches to either side of the middle of the seat. If I were to add a lap belt, those bolts are what I'd put them under. Shouldn't be hard at all.
  10. Same here man. Sorry that happened.
  11. There's no way if I owned your truck that I'd pervert it with a Ford engine. It all depends upon what you want the truck for in the end.
  12. I've got to say, this stuff you're making is clever! I especially liked the artistic fire rings I believe they were.
  13. Well, right off the bat I'd do a full tune-up. Immediately after I would do the seafoam-in-TB-and-brake-booster trick. Just did that to my buddy's chevy, huge difference! You already said you were getting better injectors. You can do a better exhaust, but you won't get its full gains without a better intake, and you won't get full gains out of either without porting your head. Also, Cruiser's tips are ALL worth doing, especially the CPS overbore and advance mod. The overbore should make it more reliable and the advance should net you free power. Electric fan as well, as has been mentioned. Full synthetics all around will lower all rolling resistances at all points that use oil. Good tires and an alignment will make sure you're not bleeding mpg. The skinnier the tire and the harder the rubber of the tire is should both help mpg. However, the harder the rubber, the less traction you'll have...which is kinda the point but its up to you to decide which side of the line you prefer; more traction or better mpg. All the other stuff they're mentioning with the axles and brake boosters, I've never done so can't comment on that. I've mainly focused on engine myself. Edit: Junkyard upgrades would include the 'horseshoe' intake out of a newer XJ.
  14. No that clears everything up. I kept looking at rockauto and there were clearly two options, a 1pc and a 2pc, and everyone kept telling me there is no 1pc. So, your explanation makes more sense. Thanks.
  15. Says it's a rear crankshaft seal aka rms.
  16. >>> What's this? http://www.rockauto.com/catalog/moreinfo.php?pk=1118220&cc=1181720
  17. So given the option, should I go with a two piece or one piece? And wouldn't grease be better than oil?
  18. Hi guys I'm looking at changing my RMS on a 4.0 that's out of its bay and is being used for a 2.5 to 4.0 swap. As far as I know the rms does not leak. but it has 180k miles on it, and the engine's already out, so as dad says, 'better safe than sorry'. That being said I figure I should replace the rms while the engine is divorced from its comanche since idk the condition of the rms. So I've checked Rockauto and they have lots of options. Should I go with one-piece, two piece, brand...? I figure one piece would seal the best. I just don't know if it would be better in the long run cuz I'm pretty sure the next time I'd have to change it it'll be in the truck and a one-piece unit would be harder to remove. FYI first time changing rms. Also, going with the cheapest one-piece oil-pan seal rockauto has.
  19. Exactly. It's got "the look" but the dude obviously didn't do any work himself. In fact he said as much. 'All custom professional work'. Blech.
  20. Don't take it to a mechanic. Do what you can and learn the rest here. That way you're self-reliable, can fix things in the future, and save some money.
  21. No, there's 12k invested IN the truck. I wouldn't pay over 6k. One man's dream build is another man's overpriced, professionally done ( :ack: ) showpiece. It's 'Baja' cuz of the flares. You know what else is 'Baja'? Taco Bell and Mtn. Dew.
  22. Yeah personally, I'd put a breathable 'catcher' - sock, cloth, or mesh - on the business end of a vacuum and try to suck it out. Then, it'll end up in the 'catcher' bowl.
  23. My first thought is of Luke Skywalker, Empire Strikes back, and Vader has just revealed who Luke's father is...
  24. Oddmodman
    Fixable?
    I'd say you could fix that. Depends how inventive you are and how good your fab skills are. Brazing is a good option methinks.
