moos
    Menifee, Ca
  • Interests
    Building,trading.
moos's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Yes I have oil pressure sweet baby jeebus,besides the hard line on the power steering pump which I have to swap no leaks, Still need to tackle wires.
  2. Fabd up a shorter hard line for my power steering pressurized line, I let the gasket on my oil pan cure 24 hrs and will torque the bolts to w/e the book calls for, oil goes in tomorrow unless my powersteering pulley gives me trouble looks cockeyed a lil. Hopefully I have oilpressure tomorrow... Sent from my SM-G900V using Tapatalk
  3. moos
    Ethical Conundrum
    Find a wrecked 97 cherokee an do a swap Sent from my SM-G900V using Tapatalk
  4. These are the wires to the HI-6 only the red+ ,an black- are hooked up, then two sets of two wires come out ones red n black others black an orange. Then I have 4 small wires, dark blue ,red,white, and green. Much help is appreciated ty. Sent from my SM-G900V using Tapatalk
  5. Couldn't find my yellow pipe tape but white should be fine idk. Sent from my SM-G900V using Tapatalk
  6. Cleaned the oil pan an painted , i couldn't find a non cork gasket gasket anywhere so going to use the "right stuff"-permatex . Used the sealant on the bottom half of the relocation kit(worked good), top half I made a 90 degree bracket an used my stock holes for the regulator?no idea I'm guessing because it looks stock location. The brass fittings I picked up at lowes male to female 3/8 work fine uptop , the 1/2 male to female doesn't they hit eachother, so I'm using one straight 2in brass pipe to a female 90. Everything i have is a mock up once I figure the right angle I will use yellow gas pipe tape tighten down n post pics. Also i need help with the hi-6 gold box, from what I see red an black are hooked up but everything else is not besides a small green wire that was disconnected and another group of wires are zip tide, much help is appreciated. Sent from my SM-G900V using Tapatalk
  7. AFAIK there isn't a way to remove a sticker decal to reuse. If you take a really good picture of it with a ruler to show scale, you can have one made cheap or do it yourself if you have the know how.Wonder if I put a piece of paper an use a pencil if it would work Sent from my SM-G900V using Tapatalk Is the sticker raised? If so a pencil or chalk would work to make a copy. It would be easier to use a good quality picture though as the sketch would be harder to reproduce since it wouldn't give perfect edges. A graphics company or even yourself could make a copy of it using a good photo and software like photoshop to create an exact copy. If I had photoshop I would be willing to help you out but I do not. Maybe a member on here does?Yea its raised , I just hope I can save the look or reproduce it, I haven't seen any with the decal. Sent from my SM-G900V using Tapatalk
  8. I'd join there but idk, I'd have to make a new thread an manage two threads seems like alot of work, prolly should though... Sent from my SM-G900V using Tapatalk
  9. AFAIK there isn't a way to remove a sticker decal to reuse. If you take a really good picture of it with a ruler to show scale, you can have one made cheap or do it yourself if you have the know how.Wonder if I put a piece of paper an use a pencil if it would work Sent from my SM-G900V using Tapatalk
  10. How's that bleeder work just pedal? Sent from my SM-G900V using Tapatalk
  11. Hopped in an drove it today. Still need to adjust the carb some more, an adjust the brakes. Sent from my SM-G900V using Tapatalk
  12. I also need to figure out how to clean the paint off the chrome, an does anyone know if lights go behind the grill? Sent from my SM-G900V using Tapatalk
  13. Anyone know how to find or save a decal? Reads ( camper special). Just wondering what to do when i paint it. Sent from my SM-G900V using Tapatalk
  14. Made this can to bleed the brakes. Went to lowes in the pvc area, 1/4 barb with threaded 1/2 in pipe, got a electrical nut an some washers, drilled hole to size an used some clear rtv. Sent from my SM-G900V using Tapatalk
  15. Clean n painted, an less than a quart of oil Sent from my SM-G900V using Tapatalk
