lowslowTJ Posted March 17, 2008 Share Posted March 17, 2008 So I am continuing the search for a MJ and I found a 88 2wd 4-cyl auto with a bad motor. I am not opposed to a motor swap any ways, but what auto would a 88' 4-cyl have in it? thanks Link to comment Share on other sites More sharing options...
Wildman Posted March 17, 2008 Share Posted March 17, 2008 The automatic transmission should be a AW4, But with the bell housing for the 2.5, which can be changed to the 4.0 bell housing. You should drop CEThomas a note, he just stripped down a '91 XJ and has the complete drive line, 4wd, and 4.0 OH engine, and is close to you, and has done the complete conversion to his MJ ;) Link to comment Share on other sites More sharing options...
mjeff87 Posted March 17, 2008 Share Posted March 17, 2008 If it's factory, the rear axle will have 4.56's in it..... That bellhousing is a pretty rare bird, too. Also, the torque converter is unique...the front part of it that fits into the crank end is different than a 4.0 version. Jeff Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted March 17, 2008 Share Posted March 17, 2008 actually it should have a TF90x trans, I believe. Unless I'm confuzled on the years and that anything 87+ as an auto 4banger had an aw4 Link to comment Share on other sites More sharing options...
Geonovast Posted March 17, 2008 Share Posted March 17, 2008 Axle should be 4.10. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted March 17, 2008 Share Posted March 17, 2008 actually it should have a TF90x trans, I believe. Unless I'm confuzled on the years and that anything 87+ as an auto 4banger had an aw4 The 904 was only used in 1986 to the best of my knowledge. The AW4 was used starting in 1987. Probaly the easiest way to tell is see if it has the "power-comfort" switch. The majority (however not all) in the late 80's/early 90's has this switch. The TF904 NEVER had it. Link to comment Share on other sites More sharing options...
mjeff87 Posted March 17, 2008 Share Posted March 17, 2008 Axle should be 4.10. If it was a 5 speed, yes. '87-90 XJ/MJ's that came with a 2.5 and an AW4 got 4.56's. Jeff Link to comment Share on other sites More sharing options...
lowslowTJ Posted March 18, 2008 Author Share Posted March 18, 2008 so even if it has 4.56:1 won't it be a Dana 35? I may go look at it. I think I can handle a 4.0L/4x4 swap? Link to comment Share on other sites More sharing options...
tjbliley Posted March 18, 2008 Share Posted March 18, 2008 It will have a D35 and 4.56's if it is the AW4 2.5 combo. You must also make sure as Jeff said get the right converter. I know this cause I had to swap mine 3 times to figure out I needed a new one for my 2.5 instaed of the one I got from a 4.0. Hardest thing you will have is to find a front 4.56 to swap into it to convert it to 4WD, unless you can do the gears yourself. It is a good find if the body and frame are in good shape. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted March 18, 2008 Share Posted March 18, 2008 man, I just read this thread then phoned up a friend of mine and bought his 1989 2.5L 4x4 XJ with an AW-4 had him double check :D $50 for 4.56 geared setupd Schweeeet Link to comment Share on other sites More sharing options...
jtdesigns Posted March 18, 2008 Share Posted March 18, 2008 so let me get this correct...... 2.5L mj's that have the aw4 have 4.56's in the rear??? How do I know it has a aw4?? Year?? Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted March 19, 2008 Share Posted March 19, 2008 from the general consensus, 1987 to 1990-91 The XJ I just got the axles from is an 89 Link to comment Share on other sites More sharing options...
mjeff87 Posted March 19, 2008 Share Posted March 19, 2008 87-89 XJ/MJ's with an auto and 2.5L engine only. And if the rig is 4WD, you get the bonus of a 4.56 geared D30 front, too. Jeff Link to comment Share on other sites More sharing options...
jtdesigns Posted March 19, 2008 Share Posted March 19, 2008 Super sweet... I know where an auto 2wd with 2.5l is right now.... but I'm not 100% on the year... 4.56's would make my 2wd street "prototype" real quick off the line!! :D I'll get a year and report back!!! Link to comment Share on other sites More sharing options...
lowslowTJ Posted March 19, 2008 Author Share Posted March 19, 2008 I dunno if I should buy it. it turns out its an 88' 2.5 manual (the dealer had it listed as auto Duh!) 2wd. the motor is bad too! they are asking $700.00. I want a 4.0L 4x4 and tranny type is not so important to me. what do you all think? I don't mind waiting, or undertaking a huge drivetrain swap:). Link to comment Share on other sites More sharing options...
jaekl Posted March 19, 2008 Share Posted March 19, 2008 These axle ratios don't make sense to me. Wouldn't the auto and the 4 speed have the same axle ratio? (Both are direct drive in high) The 5 speed would have a numerically higher ratio. My understanding is 3.55 for 4 speed/auto, 4.10 for 5 speed, and 4.56 is 5 speed towing package. Possibly 4.10 would be the towing package for 4 speed and auto. Are the towing packages common? I would think 4.56 in 4 speed/auto with stock tires would rev way too high. I understand why you would want it but why are we assume this rig has 4.56? Link to comment Share on other sites More sharing options...
brigarpeon Posted March 19, 2008 Share Posted March 19, 2008 I have an 86 X W/ 2.5, 5 Speed and 3.31 gears. It's a gas miser package. Now it won't run 15's in the quarter but it has enuff snot to travel and maintain highway speeds. It won't climb mountains on the highway in 5th but it will climb rolling hills. 5th gear is reserved for long somewhat level strecthes and 4th is the most used top gear. I have 215/75/15 All Season tires and get 25 mpg. My only gripe is "WHAT A DOG OFFROAD" I run out of horsepower before obstacle. I would advise to buy it. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted March 19, 2008 Share Posted March 19, 2008 I guess the fact an auto eats alot of HP to get up to snuff and move whereas an mt is a direct connect sorta deal Link to comment Share on other sites More sharing options...
lowslowTJ Posted March 20, 2008 Author Share Posted March 20, 2008 will an 88 2.5 be fuel injected/Renix or carburated? thanks. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 20, 2008 Share Posted March 20, 2008 renix F.I carbeurated ended in 1985. 1986 became FI Link to comment Share on other sites More sharing options...
lowslowTJ Posted March 20, 2008 Author Share Posted March 20, 2008 thanks! :D Link to comment Share on other sites More sharing options...
a1awind Posted March 20, 2008 Share Posted March 20, 2008 I have an 86 X W/ 2.5, 5 Speed and 3.31 gears. It's a gas miser package. we were taliking about that earlier... i thought gas misers were 4 speed mt only. or is it just lower hp and no tailgate Link to comment Share on other sites More sharing options...
brigarpeon Posted March 20, 2008 Share Posted March 20, 2008 we were taliking about that earlier... i thought gas misers were 4 speed mt only. or is it just lower hp and no tailgate That may well have been the Jeep Base Line Gas Miser package. Mine is 4x4 has different LCA's not sure about UCA's. I put a motor in this truck but used all the ancillary items from the original 2.5 so it should still be detuned. I also put the 5 speed in it but merely replaced the AX5 w/ an AX5. The original owner, possibly the dealership, had Good ol Rusty Jones undercoat it, probably because it didn't have any. I had to put a tailgate and back bumper on it. Whether they were on it when it came from the factory IDUNNO. Knowing the list of possible options and depending on how they felt like building it at the factory that day, I would dare to say it is within the realm of possibilities to have a Gas Miser sold in a semi or fully opted out configuration. Factories usually only build at the base by order only, they want to sell all they can sell. Link to comment Share on other sites More sharing options...
a1awind Posted March 21, 2008 Share Posted March 21, 2008 the miser didnt have a tailgate ... rearbumper i dunno but definatly no rear bumper Link to comment Share on other sites More sharing options...
