So you absolutely have to remove the engine to change the rear main seal on the ba10/5 equipped comanches, huh?
This is a serious problem... I bought this Comanche for $8500 (ouch) and while it is not rusty, and very clean 4x4, it has taken so much money in like 2 months...
I don't really have any other options, too much student loans to finance anything, (and honestly wouldn't want to anyway... )
If I'm ripping the ba10/5 out, I may as well put in an ax-15 but that's at least $700 if I rebuild it myself and install it (have never done this before)... All searches for reasonable used ones are over $1000...
I am feeling very disheartened that I had to sell my property to afford a decent truck, and now it's leaking majorly from the RMS and I am here .. maybe this is more of a support request?
How do I get through this? Do I just put the ba10/5 with 220000 back in?
I do not believe that you have to remove the engine to change the RMS on a 4.0, regardless of engine.
Where are you finding that the rebuild for the AX-15 will be $700? Or is that figuring the initial purchase of one that needs a rebuild? I'm seeing rebuild kits for $350. That is assuming that you have the AX-15 crossmember already and that you're clutch and flywheel are in good shape. I would also only do an external slave AX-15 swap, as the internal slave cylinders don't seem to be made well anymore.
How do you use the truck? If you do a lot of towing and hauling or like to drive the truck like a sports car, it would be worthwhile to swap to the AX-15. If you just casually cruise around in the truck and don't really use it for truck stuff often, the BA10/5 will do just fine. In fact, my BA10/5 was a much smoother shifting transmission than my rebuilt AX-15 is.
How much oil is the truck really leaking? Unless the oil leak is very frustrating to you (I am one of those people that hates leaks) or the clutch is getting oil on it or its causing other problems, you can buy a lot of oil for $700. If the engine also has 220k miles on it, there is a chance that the crank is worn and a new RMS won't completely fix the leak anyways.
The transmission type is irrelevant to the rear main seal replacement. The transmission gets pulled (usually) regardless of the type. We were lucky enough to find an AX-15 from a Cherokee in a junk yard. Keep an eye out there.
Neither the transmission nor engine needs to be removed to replace the engine rear main seal. The only thing that has to be removed is the oil pan. Which you can remove if you unbolt the shocks and let the front suspension drop out of the way.
You don't have to pull the trans to change the RMS.
The RMS is a two piece seal.
You have to drop the oil pan and remove the rear main bearing cap. The lower half of the RMS is in the cap.  Use a small brass punch to remove the upper half of the RMS.
The truck was purchased to do farm work, pull small stumps, haul dirt, gravel, a trailer with roughly 2500lbs, get out of the mud, and do truck things. Though it is in nice shape, it's not really about that for me. Also, my crippling student debt means that I am married to any vehicle i may have until someone dies.
There's an ax15 transmission near me for $200. Kit is about $350, but it needs all sorts of other things other than rebuilt in order to get in there. $700 is kind of speculative. The kit from dead jeep is $2500ish, which is fine... I may just buy the kit because I don't really want to mess with finding all the parts and then finding out what condition they're in and such. Its just really inconvenient and most of my savings :/
Unfortunately the RMS leaks so much oil that it got on the clutch ,which now slips. The Chilton shop manual Rear main seal writeup says "remove transmission" as step 1 for ba10/5 and says "disconnect negative battery terminal" for the ax-15...
 I got the oil pan off enough to look up there and found a brand new oil pan gasket... Bad news... and there is no transmission inspection plate in there that I could see. It doesn't look like I can access the RMS from that side.
I put the project down and went home, so I'll send pictures next time I get out there to verify ...
Manual transmissions don't have inspection plates.  The dust shield is a solid, single piece of metal.
You have to remove the rear bearing cap to access the RMS.
You can get an AX15 rebuild kit with synchros and bearings for less than $130. They also have lots of other parts should you need anything else. I just finished rebuilding an AX15 2 weeks ago and used a bunch of parts from them.
https://www.allstategear.com/AX15-Jeep-Bearing-Kit-with-Synchro-Rings-p/bk163jws.htm
Okay! So the rear main CAN be accessed through the oil pan method. I got the pan off, and got the rear bearing cap off, and found the seal. Replaced the easy side, and then took my brass punch set to the rear main.
Now I have a new problem. The Rear main seal collapsed in on itself. I can sink my punch 1" through the original seal, bent (slightly) around the crank and it is not budging.
Side note, the dust shield appears to clamped between the motor and the transmission in this model. It also will not budge after all the bolts are taken out.
Suggestions?
I had a similar issue when I did my rear main seal. I had to loosen all the main bearing caps and pull down on the crank slightly to get the upper half of the rear main seal to move and rotate out. You just need to make sure to retorque any bearing cap bolts you loosen. They are supposed to be torqued to 80 ft/lbs. Torque them gradually, first to 40 then 60 then 80.
There is a metal rod in the seal itself.  Make sure you have the brass drift hitting it and not sliding by it to the side.
They do have a lot of stiction.  It sometimes takes a bit to get them to pop loose.
And be very careful sliding the new one in. Be sure it's facing the right way.  And be extra careful with the sharp edges.  They can shave it as you slide it in if you're not careful.
I was going say what Eagle suggested.
As for the dust shield, it is sandwiched between the engine block and the flywheel.  To remove the dust shield requires removing the transmission and the flywheel.
It's notched so you can slide the shield off without pulling the flywheel.  But you do need to separate the transmission.
things I've learned the hard way:
buy a reusable oil pan gasket so you don't need a new one each time you drop the pan again because the RMS still kinda leaks.
buy 2 RMS so you have a spare when you mess up the first.
I'm pulling the engine of this current truck (for other reasons) and look forward to finally doing an RMS while sitting in a chair rather than lying on the ground :D
Thanks everyone. I got it out without dropping the transmission or loosening the crank. That pin tip was helpful.
Tomorrow I will start putting it all back, clean her up, take her for a ride and see if she still leaks.
If it's the transmission front seal, well that sucks, but I think I'll start that one from the other end.
I do have an opportunity to purchase an ax-15 with the transfer case and everything for a swap for $500 if I pull it myself.
Worth it?
Worth it?
What year is it? That’s a good deal, but an external slave one is better.
Worth it?
Yes, if it is an external slave setup and it doesn't need to be rebuilt. If it needs to be rebuilt the most I would pay is $100.
