derf Posted June 30 Share Posted June 30 I've had an idea rattling around in my head about reproducing a factory style roll bar. I have a tubing bender (JD squared) that I'm going to use to build a custom cage for another project, along with a few other things. I got the bright idea to take a factory rollbar and make what amounts to copies. Easy enough, right? Well, there's one snag. The biggest die I can get only fits 2.5" tubing. The tool doesn't support bigger. The factory bar is 3" tubing. I know I won't mind when I build mine. But I know some of you out there would love for someone like me to offer them up for sale. Question is, would people want them if they were made out of smaller tubing? Let me know your thoughts... Link to comment Share on other sites More sharing options...
JZLAJeep Posted June 30 Share Posted June 30 Yes! Ship with some assembly required (i.e. welding, painting)? Link to comment Share on other sites More sharing options...
derf Posted July 1 Author Share Posted July 1 I'm still thinking about ways to make shipping easier and cheaper. It'll probably have to be shipped truck freight on a pallet. But if I can ship with the legs not welded on, it would likely save some on the cost. I could also do a segmeted hoop with some sleeves at the joints so it could fit in a box. I could cut it between the bends. That would require more welding and finishing. But it would be much easier and cheaper to ship. Link to comment Share on other sites More sharing options...
Pete M Posted July 1 Share Posted July 1 the way I always envisioned it was to make a left and right side that gets welded together (with a sleeve inside at the joint). that way you only need to make 2 different parts (half-a-hoop and a leg) and just make 2 of each. Link to comment Share on other sites More sharing options...
derf Posted July 1 Author Share Posted July 1 3 hours ago, Pete M said: the way I always envisioned it was to make a left and right side that gets welded together (with a sleeve inside at the joint). that way you only need to make 2 different parts (half-a-hoop and a leg) and just make 2 of each. Yeah, though it would probably have to be an uneven split at the top. There is a slight bend in the center top. So the cut would have to be away from there to one side or the other. One thought is to make the main hoop in 3 pieces. The top section would have the center bend and the two outside bends going down. And cut maybe 3-5" at least down from those bends. Or probably right where the back legs attach. Then you'd have two pieces from the floor to the top bar. The user would have to weld 5 total segments together. The 3 pieces of the hoop and the stringers going back to the wheel well. Link to comment Share on other sites More sharing options...
Pete M Posted July 1 Share Posted July 1 I wouldn't even attempt the upper bend. it's not going to be an identical-copy anyway, so in my mind there's no real point to it. Link to comment Share on other sites More sharing options...
derf Posted July 1 Author Share Posted July 1 4 minutes ago, Pete M said: I wouldn't even attempt the upper bend. it's not going to be an identical-copy anyway, so in my mind there's no real point to it. Fair point. I can try it both ways. It may be good enough without or it may not look right. I was thinking about packaging for shipping as I thought about multiple sleeved pieces. If I cut it in 2, there are 2 pieces with a 90-ish degree bend taking up a lot of space in 2 dimensions. With 3 pieces, it still takes up room but may be a little more compact for shipping purposes. It's all speculation at this point though. I still need to get the die and some tubing to practice with first. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 2 Share Posted July 2 Out of curiosity, why not just fab this from 3" 16 gauge exhaust tubing with mandrel bends? That way it will look like a factory part. Simple enough to either tig or mig and smooth out the welds. I also like Pete's idea of a 2 piece design that could be either welded or bolted together for those that don't have access to a welder. Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 2 Share Posted July 2 8 minutes ago, ghetdjc320 said: Out of curiosity, why not just fab this from 3" 16 gauge exhaust tubing with mandrel bends? That way it will look like a factory part. The largest die his equipment can take is 2.5”. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 2 Share Posted July 2 2 hours ago, fiatslug87 said: The largest die his equipment can take is 2.5”. I'm suggesting not doing any bending but rather, using mandrel bent pieces and welding them together similar to how a custom exhaust is fabed up. Link to comment Share on other sites More sharing options...
derf Posted July 2 Author Share Posted July 2 2 hours ago, ghetdjc320 said: I'm suggesting not doing any bending but rather, using mandrel bent pieces and welding them together similar to house a custom exhaust is fabed up. Because 16 gauge is way too thin for a legitimate roll bar. I don't need super thick wall tubing. Not even .120 wall. But something thicker than 16 gauge is needed. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 2 Share Posted July 2 1 minute ago, derf said: Because 16 gauge is way too thin for a legitimate roll bar. I don't need super thick wall tubing. Not even .120 wall. But something thicker than 16 gauge is needed. Makes sense. To me the roll bar has been an aesthetic piece, but I suppose it could provide some level of protection in the event of a rollover. Link to comment Share on other sites More sharing options...
derf Posted July 2 Author Share Posted July 2 1 minute ago, ghetdjc320 said: Makes sense. To me the roll bar has been an aesthetic piece, but I suppose it could provide some level of protection in the event of a rollover. That and exhaust tubing would dent way too easily just throwing stuff in the bed and letting it slide around. Not to mention trying to attach anything to it or trying to use it as a tie-down for a load. Cosmetic is fine but I want to be able to do truck stuff with my truck. Link to comment Share on other sites More sharing options...
boxyjeep Posted 17 hours ago Share Posted 17 hours ago On 7/1/2025 at 9:03 PM, derf said: Because 16 gauge is way too thin for a legitimate roll bar. I don't need super thick wall tubing. Not even .120 wall. But something thicker than 16 gauge is needed. That's why it's called a "Sport Bar". It was never meant to have any structural capacity. I've dug into this a bit and evaluated the cost of materials, time/labor, and shipping, and it would likely have to sell for $800-1000. Unfortunately, you're not gonna sell a lot of these and the initial investment in tooling, test runs, and materials is going to be pretty steep. As much as I hate to say it, it's really just not commercially viable. Link to comment Share on other sites More sharing options...
derf Posted 17 hours ago Author Share Posted 17 hours ago 4 minutes ago, boxyjeep said: That's why it's called a "Sport Bar". It was never meant to have any structural capacity. I've dug into this a bit and evaluated the cost of materials, time/labor, and shipping, and it would likely have to sell for $800-1000. Unfortunately, you're not gonna sell a lot of these and the initial investment in tooling, test runs, and materials is going to be pretty steep. As much as I hate to say it, it's really just not commercially viable. Likely not. I do already have the tubing bender along with a welder for other projects. That's the big up front expense. I'm going to build one for myself and at least one or two others regardless so buying the die for the bender will happen. I don't expect to sell many. And I'll probably lose money. But I'm not doing it for profit anyway. If a few people really want them I can make them once I get set up later this summer or fall. Link to comment Share on other sites More sharing options...
boxyjeep Posted 17 hours ago Share Posted 17 hours ago 39 minutes ago, derf said: Likely not. I do already have the tubing bender along with a welder for other projects. That's the big up front expense. I'm going to build one for myself and at least one or two others regardless so buying the die for the bender will happen. I don't expect to sell many. And I'll probably lose money. But I'm not doing it for profit anyway. If a few people really want them I can make them once I get set up later this summer or fall. Best of luck! Interested to see how it works out. If the price is right I may even buy one from you. Link to comment Share on other sites More sharing options...
