camjeep3 Posted April 30 Share Posted April 30 Quick background. Truck was running fine until parked due to rear axle decided to explode. That was 10-12 years ago. I started tinkering on the truck put a fresh battery in and realized my fuel pump was dead. Went through the fuel system, new pump sending unit tank and regulator. Fuel to the rail. I get a crank but no start. Pulled a plug and I get a good spark whole cranking. Checked CPS at plug and voltage was low. Replace CPS. Nothing. Try another CPS. 0 voltage at plug with sensor isolated from truck wiring. I am going to do the cruiser checks but if I'm still confused. Should I see spark with a bad CPS? Link to comment Share on other sites More sharing options...
89 MJ Posted April 30 Share Posted April 30 You shouldn’t get spark with a bad CPS. Did you add fresh fuel or is it still the 10-12 year old fuel? Might need to drain the fuel system and add fresh gas. Link to comment Share on other sites More sharing options...
camjeep3 Posted April 30 Author Share Posted April 30 New tank. So fresh gas Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted April 30 Share Posted April 30 If you have spark but no start you can always check the timing and make sure the distributor is properly indexed. Link to comment Share on other sites More sharing options...
camjeep3 Posted April 30 Author Share Posted April 30 Something I will definitely check. But I figured unlikely since it hasn't been touched and the truck was running. Link to comment Share on other sites More sharing options...
gvthnks Posted Thursday at 07:44 PM Share Posted Thursday at 07:44 PM I don't understand. If you had good spark at the spark plugs, then your CPS was working. 0 Voltage at plug with sensor isolated from the truck? You won't get voltage on the CPS harness side plug. The CPS generates voltage as the flywheel turns in close proximity to it. So to check it, the CPS has to be in its location, and you check the two wires coming off of it looking for AC voltage. I run the multimeter leads from the CPS up to my meter laying on my windshield and crank it over with the key while looking for AC voltage. We're looking for about .5 VAC here. Are the fuel injectors firing? I'd use starting fluid to see if it will fire while cranking it over. If it does, that's the easiest way to isolate it to a fuel issue. Link to comment Share on other sites More sharing options...
camjeep3 Posted 14 hours ago Author Share Posted 14 hours ago I don't understand either. I am checking CPS as you describe and get nothing. Maybe I need to try a different meter. But if no CPS signal means no spark then I have a different issue. I'll try starting fluid and work from there Link to comment Share on other sites More sharing options...
gvthnks Posted 11 hours ago Share Posted 11 hours ago Make sure your meter is set to measure AC voltage and not DC. Link to comment Share on other sites More sharing options...
