Help get my truck running.
Quick background.
Truck was running fine until parked due to rear axle decided to explode. That was 10-12 years ago. I started tinkering on the truck put a fresh battery in and realized my fuel pump was dead. Went through the fuel system, new pump sending unit tank and regulator. Fuel to the rail. I get a crank but no start. Pulled a plug and I get a good spark whole cranking. Checked CPS at plug and voltage was low. Replace CPS. Nothing. Try another CPS. 0 voltage at plug with sensor isolated from truck wiring. I am going to do the cruiser checks but if I'm still confused. Should I see spark with a bad CPS?
You shouldn’t get spark with a bad CPS. Did you add fresh fuel or is it still the 10-12 year old fuel? Might need to drain the fuel system and add fresh gas.
I don't understand.   If you had good spark at the spark plugs, then your CPS was working.
0 Voltage at plug with sensor isolated from the truck?
You won't get voltage on the CPS harness side plug.   The CPS generates voltage as the flywheel turns in close proximity to it.   So to check it, the CPS has to be in its location, and you check the two wires coming off of it looking for AC voltage.
I run the multimeter leads from the CPS up to my meter laying on my windshield and crank it over with the key while looking for AC voltage.   We're looking for about .5 VAC here.
Are the fuel injectors firing?   I'd use starting fluid to see if it will fire while cranking it over.   If it does, that's the easiest way to isolate it to a fuel issue.
I don't understand either. :laugh:
I am checking CPS as you describe and get nothing. Maybe I need to try a different meter.
But if no CPS signal means no spark then I have a different issue. I'll try starting fluid and work from there
To make completely sure you have adequate fuel pressure, rent a fuel pressure test kit from AutoZone or the like and verify pressure.
Read post #5
https://naxja.org/threads/87-renix-4-0l-auto-weak-vs-strong-fuel-pump-sound-when-cranking.1063540/#post-245350096
There may also be a way to test that the PCM is firing the injectors properly.
yeah i would get a noid light and see if the injectors are pulsing.if they are and you have adequate fuel pressure i bet the injectors have froze up from sitting.its not that uncommon.
I had the rail apart and contemplated replacing the injectors. I put seals on instead... So I fully expect I'll end up having to replace injectors :doh:
Thanks guys. I'll report back
