camjeep3 Posted April 30, 2025 Share Posted April 30, 2025 Quick background. Truck was running fine until parked due to rear axle decided to explode. That was 10-12 years ago. I started tinkering on the truck put a fresh battery in and realized my fuel pump was dead. Went through the fuel system, new pump sending unit tank and regulator. Fuel to the rail. I get a crank but no start. Pulled a plug and I get a good spark whole cranking. Checked CPS at plug and voltage was low. Replace CPS. Nothing. Try another CPS. 0 voltage at plug with sensor isolated from truck wiring. I am going to do the cruiser checks but if I'm still confused. Should I see spark with a bad CPS? Link to comment Share on other sites More sharing options...
89 MJ Posted April 30, 2025 Share Posted April 30, 2025 You shouldn’t get spark with a bad CPS. Did you add fresh fuel or is it still the 10-12 year old fuel? Might need to drain the fuel system and add fresh gas. Link to comment Share on other sites More sharing options...
camjeep3 Posted April 30, 2025 Author Share Posted April 30, 2025 New tank. So fresh gas Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted April 30, 2025 Share Posted April 30, 2025 If you have spark but no start you can always check the timing and make sure the distributor is properly indexed. Link to comment Share on other sites More sharing options...
camjeep3 Posted April 30, 2025 Author Share Posted April 30, 2025 Something I will definitely check. But I figured unlikely since it hasn't been touched and the truck was running. Link to comment Share on other sites More sharing options...
gvthnks Posted May 8, 2025 Share Posted May 8, 2025 I don't understand. If you had good spark at the spark plugs, then your CPS was working. 0 Voltage at plug with sensor isolated from the truck? You won't get voltage on the CPS harness side plug. The CPS generates voltage as the flywheel turns in close proximity to it. So to check it, the CPS has to be in its location, and you check the two wires coming off of it looking for AC voltage. I run the multimeter leads from the CPS up to my meter laying on my windshield and crank it over with the key while looking for AC voltage. We're looking for about .5 VAC here. Are the fuel injectors firing? I'd use starting fluid to see if it will fire while cranking it over. If it does, that's the easiest way to isolate it to a fuel issue. Link to comment Share on other sites More sharing options...
camjeep3 Posted May 13, 2025 Author Share Posted May 13, 2025 I don't understand either. I am checking CPS as you describe and get nothing. Maybe I need to try a different meter. But if no CPS signal means no spark then I have a different issue. I'll try starting fluid and work from there Link to comment Share on other sites More sharing options...
gvthnks Posted May 13, 2025 Share Posted May 13, 2025 Make sure your meter is set to measure AC voltage and not DC. Link to comment Share on other sites More sharing options...
camjeep3 Posted June 1, 2025 Author Share Posted June 1, 2025 Had a few mins and got a charger for the battery. With starting fluid it will fire up and die Link to comment Share on other sites More sharing options...
ratrapp Posted June 2, 2025 Share Posted June 2, 2025 if you have fuel pressure at the rail then the injectors have probably froze from sitting all those years. Link to comment Share on other sites More sharing options...
camjeep3 Posted June 2, 2025 Author Share Posted June 2, 2025 There is pressure at the rail. If I hit the valve it shoots fuel out. Any way to test the injectors before I buy new ones? Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 2, 2025 Share Posted June 2, 2025 To make completely sure you have adequate fuel pressure, rent a fuel pressure test kit from AutoZone or the like and verify pressure. Read post #5 https://naxja.org/threads/87-renix-4-0l-auto-weak-vs-strong-fuel-pump-sound-when-cranking.1063540/#post-245350096 There may also be a way to test that the PCM is firing the injectors properly. Link to comment Share on other sites More sharing options...
ratrapp Posted June 2, 2025 Share Posted June 2, 2025 yeah i would get a noid light and see if the injectors are pulsing.if they are and you have adequate fuel pressure i bet the injectors have froze up from sitting.its not that uncommon. Link to comment Share on other sites More sharing options...
camjeep3 Posted June 3, 2025 Author Share Posted June 3, 2025 I had the rail apart and contemplated replacing the injectors. I put seals on instead... So I fully expect I'll end up having to replace injectors Thanks guys. I'll report back Link to comment Share on other sites More sharing options...
camjeep3 Posted September 29, 2025 Author Share Posted September 29, 2025 I went ahead and put some injectors on.... No luck. I'll pick up the proper tools and start to actually verify what's happening. Instead of throwing parts at the problem Link to comment Share on other sites More sharing options...
camjeep3 Posted September 29, 2025 Author Share Posted September 29, 2025 Looking at cruisers tips. My map sensor hose is shot. Ie not connected from throttle body to sensor... Would this cause a no start? Link to comment Share on other sites More sharing options...
87MJTIM Posted September 29, 2025 Share Posted September 29, 2025 3 hours ago, camjeep3 said: Looking at cruisers tips. My map sensor hose is shot. Ie not connected from throttle body to sensor... Would this cause a no start? Yes, the MAP not connected is a definite “No start.” Crank, no start. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 29, 2025 Share Posted September 29, 2025 The map sensor being disconnected will not cause a no start situation. Mine liked to pop off every once and a while. It just causes a high idle. I pop it back in and it is back to normal. Link to comment Share on other sites More sharing options...
GonzoTheGreat Posted September 30, 2025 Share Posted September 30, 2025 I'll add to the confusion: when the map hose came off my '88, I had a very hard start and a low, staggering idle. Maybe it depends on the ambient air pressure at the time. Regardless, a disconnected MAP hose will cause some sort of significant issue, and should be addressed. I'll also add that Ive had a similar crank no-start, with good spark, after sitting for a long time, and it ended up being dry piston rings that didn't build enough compression for combustion. Have you checked compression? Link to comment Share on other sites More sharing options...
camjeep3 Posted October 9, 2025 Author Share Posted October 9, 2025 Retested cps and no voltage. Tried 2 sensors. Nothing. Ordered 2 more different brand spc from rock auto. I'm getting good at swapping cps unfortunately Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted October 9, 2025 Share Posted October 9, 2025 On 6/1/2025 at 3:54 PM, camjeep3 said: Had a few mins and got a charger for the battery. With starting fluid it will fire up and die Why are you trying multiple CPS sensors if it will fire when you use starting fluid? That indicates a fuel issue not a spark issue. On 9/29/2025 at 11:31 AM, camjeep3 said: I went ahead and put some injectors on.... No luck. I'll pick up the proper tools and start to actually verify what's happening. Instead of throwing parts at the problem Gas tends to varnish after sitting for long periods of time. Have you checked flow at the fuel rail by simply disconnecting the fuel hose and putting it in a bucket? If you don't have a steady flow I would start by changing the fuel filter. If that doesn't work your lines are likely gummed up and need to be thoroughly flushed. Link to comment Share on other sites More sharing options...
camjeep3 Posted October 10, 2025 Author Share Posted October 10, 2025 Sorry. There is context missing. The truck will no longer fire off on starting fluid. Fuel flow is there. After I replaced the tank and pump I blew the o rings out in the rail. I tested both cps with no voltage reading while cranking Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted October 10, 2025 Share Posted October 10, 2025 The CPS is difficult to probe correctly. Have you checked for spark with a spark tester? Link to comment Share on other sites More sharing options...
ratrapp Posted October 11, 2025 Share Posted October 11, 2025 i think you need to take a step back and start over.you need to verify fuel pressure with an actual gauge.if you have adequate pressure then use a noid light and verify you have injector pulse.if all is good then get a spark tester and check spark.if you have spark then get a compression gauge and check all 6 cylinders.all of these tools can be bought cheap enough at harbor freight.these are tools you will probably use again anyway.its not super common but i have had to replace the coil and control module on a few renix era mjs and xjs over the years. Link to comment Share on other sites More sharing options...
camjeep3 Posted October 13, 2025 Author Share Posted October 13, 2025 Ratrapp... You are 100% correct. And I already knew this I'm my head. The truck "ran when parked" was kind of my thought process going into this. But there has been a lot of time between now and then. I'm going to stop at hf after work and pick up the appropriate tools and start at square one. Thanks everyone for the help so far Link to comment Share on other sites More sharing options...
