JeffK Posted March 29, 2025 Share Posted March 29, 2025 From 84-90 is there any difference in the steering knuckles? i.e. caliper brackets/mounting? Thanks. Link to comment Share on other sites More sharing options...
89 MJ Posted March 29, 2025 Share Posted March 29, 2025 I believe it’s 84-89 have windowed knuckles. 90-01 do not. Something about the windowed knuckles makes them fit bigger brakes. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted March 29, 2025 Share Posted March 29, 2025 9 minutes ago, 89 MJ said: I believe it’s 84-89 have windowed knuckles. 90-01 do not. Something about the windowed knuckles makes them fit bigger brakes. Yeah Wildwood makes a big brake kit that fits the early knuckles but not the later ones. It is expensive. https://www.wilwood.com/BrakeKits/BrakeKitSearch?year=1987&make=Jeep&model=Comanche&option=4+X+4+Only&axle=Front+Kit Link to comment Share on other sites More sharing options...
89 MJ Posted March 29, 2025 Share Posted March 29, 2025 7 minutes ago, Eagle_SX4 said: Yeah Wildwood makes a big brake kit that fits the early knuckles but not the later ones. It is expensive. https://www.wilwood.com/BrakeKits/BrakeKitSearch?year=1987&make=Jeep&model=Comanche&option=4+X+4+Only&axle=Front+Kit Holy cow! Those are really expensive. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 29, 2025 Share Posted March 29, 2025 11 minutes ago, 89 MJ said: Holy cow! Those are really expensive. More like holy schnikes. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted March 29, 2025 Share Posted March 29, 2025 Here is the video on the install. Link to comment Share on other sites More sharing options...
pizzaman09 Posted March 29, 2025 Share Posted March 29, 2025 11 hours ago, 89 MJ said: Holy cow! Those are really expensive. Lol, it's all about perspective. I purchased big brake kits from Willwood for my 99 BMW M3 because the Willwood kit total, was 1/2 the cost of purchasing OEM replacement calipers. Compared to Jeep parts, this brake kit is mega expensive. I simply purchased some Hawk high performance bake pads for the front of my Comanche for about $50 during a sale and couldn't be happier. Link to comment Share on other sites More sharing options...
JeffK Posted March 29, 2025 Author Share Posted March 29, 2025 12 hours ago, 89 MJ said: I believe it’s 84-89 have windowed knuckles. 90-01 do not. Something about the windowed knuckles makes them fit bigger brakes. Thanks for clarifying that. I was looking at bigger brakes, Wilwood seems to be the simplest to install, but even if you opt for their solid rotors that kit is still almost $1100. https://www.summitracing.com/parts/wil-140-12576-r Link to comment Share on other sites More sharing options...
89 MJ Posted March 29, 2025 Share Posted March 29, 2025 59 minutes ago, pizzaman09 said: Lol, it's all about perspective. I purchased big brake kits from Willwood for my 99 BMW M3 because the Willwood kit total, was 1/2 the cost of purchasing OEM replacement calipers. Compared to Jeep parts, this brake kit is mega expensive. I simply purchased some Hawk high performance bake pads for the front of my Comanche for about $50 during a sale and couldn't be happier. That’s pretty crazy! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 29, 2025 Share Posted March 29, 2025 The 84-89 XJ 86-89 MJ and 87-89 YJ with the Dana 30 front axle all had the same knuckles that use a bolt on caliper that holds the pads. 90+ used “wings” cast into the knuckle that hold the pads and use a floating caliper design. The ability to bolt on the calipers is what lets you run bigger brakes. The Wilwood kit is very competitively priced as big brake kits go. You can build a kit yourself as well for less but with some trade offs. Link to comment Share on other sites More sharing options...
JeffK Posted March 29, 2025 Author Share Posted March 29, 2025 37 minutes ago, ghetdjc320 said: The 84-89 XJ 86-89 MJ and 87-89 YJ with the Dana 30 front axle all had the same knuckles that use a bolt on caliper that holds the pads. 90+ used “wings” cast into the knuckle that hold the pads and use a floating caliper design. The ability to bolt on the calipers is what lets you run bigger brakes. The Wilwood kit is very competitively priced as big brake kits go. You can build a kit yourself as well for less but with some trade offs. I looked into some of the DIY kits as well, I found this parts list on another jeep forum- -Early '84-'89 knuckles with the lugs for the caliper to bolt on (not the late '90+ knuckles with the brake pad 'wings') -Mustang GT '11-'14 Rotors 13.25" Centric 120.61098 -Calipers dual piston '11-'15 Durango or GC for 350mm rotors Centric 141.58011/12 -Pads semi-metalic Centric 30014550 -14mm grade 8 caliper bolts and washers -14mm drill bit to drill out the knuckle caliper mounting lug hole -Spacer machined steel- 1" thick, 1.375" diameter and 9/16" hole No pics with the post though, I assume the spacers are for mounting the calipers(?) Do you know of another kit that maintains the stock steering? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 29, 2025 Share Posted March 29, 2025 Here is a handy guide for a DIY upgrade: https://docs.google.com/document/u/0/d/1Cv83Y7F7hu4QK3Grd72LKF1uSeHcZERGiwWGbjfxG3I/mobilebasic Link to comment Share on other sites More sharing options...
JeffK Posted March 29, 2025 Author Share Posted March 29, 2025 1 hour ago, ghetdjc320 said: Here is a handy guide for a DIY upgrade: https://docs.google.com/document/u/0/d/1Cv83Y7F7hu4QK3Grd72LKF1uSeHcZERGiwWGbjfxG3I/mobilebasic Nice, thanks. Link to comment Share on other sites More sharing options...
70barracuda Posted March 31, 2025 Share Posted March 31, 2025 I have the wilwood kit. It was pricey but the jeep stops incredible since I've installed it. I was going to go the DIY route but honestly for 1k I felt it was just easier to get the kit instead of tracking down so many parts. Wilwood was bolt on, maybe 2 hours Link to comment Share on other sites More sharing options...
JeffK Posted March 31, 2025 Author Share Posted March 31, 2025 8 hours ago, 70barracuda said: I have the wilwood kit. It was pricey but the jeep stops incredible since I've installed it. I was going to go the DIY route but honestly for 1k I felt it was just easier to get the kit instead of tracking down so many parts. Wilwood was bolt on, maybe 2 hours I agree the Wilwood kit is the simplest solution. I don't mind saving a little money though, corrosion resistant rotors, new calipers and other needed parts for the DIY 13.25" rotor kit was less than $500. Link to comment Share on other sites More sharing options...
