Badge removal...
I'm in the middle of refurbishing the tailgate, and looking for advice on removing these badges without damaging them.  I've tried fishing line, but the line keeps braking (maybe I need heavier test, or metal wire...).  Are there little studs behind these things, that are inserted into holes in the sheet metal?  Thinking of trying heat gun next and gently prying with a putty knife...
2nd, any idea what these 4 little holes are?  Zooming in you can see 2 in the indentation above Command-Trac, and follow over to the other side are the other 2.  My current thinking is reflectors were there at some point?  But seems kind of excessive to have put holes in the metal for that...
I was able to get badges off junk yard Comanches using putty a knife, they came off in one piece. With that said since you have the luxury of doing this at home, definitely apply some heat, that adhesive is strong.
There was a product Undo (I think) that will allow you to remove stickers and stamps from paper. It doesn’t stain or leave a residue. My wife bought at craft stores. If you can find that, try dripping it on the emblem.
7 hours ago, Spinnakerblue89 said:
Definitely apply heat. And I have a protip: use something like a discarded credit card if you worry about damaging the metal surface or paint in any scenario. I keep old plastic gift cards for this reason alone.
:thumbsup:
