Posted (edited)
No need for a CNC machine unless you are looking to mass produce them.  Although nowhere near as fun as getting a new tool, a jigsaw, drill and maybe a dremel to clean up some rough cuts is enough to make the card panels.  I did mine probably 15 years ago and they are holding up pretty well.  If it hasn't disintegrated, using the oem card panel to as a template to make new one is pretty straightforward; carefully removing the skin from the original for reuse without damaging it was the most time consuming part.
Good to see people making parts for the XJ/MJ but i'm not sure who the target audience is at that price. Maybe someone who can't easily get their hands on an original in good condition to use as a template.
Edited by Boilermaker
Fix image sizes
What kind of staples did you use for this?
Had to pull one out to verify.....T50 1/4" (6mm) light duty staples.  Doing it again today, i would go with the heavy duty (thicker crown) stainless steel Arrow #504SS1, especially for a daily driver.
Thanks! I had been looking for the right size staple for a while but never got the chance to find such.
No problem. It may be possible to go slightly longer, maybe 5/16" or 3/8" (Arrow 505 or 506) for a better grip without going thru the front side of the skin.  1/2" is definitely too long, i remember starting with that and having it poke all the way thru.
I've have two more door skins in my parts pile that i haven't gotten around to doing this on.  Would be a good time to try a couple of different things and post a write up to the DIY section.
Agreed.
i was gonna do this as a side business if making door cards and making new ones, washing the material and putting them back together. But that’s been on hold for years.
A customer interiors guy once told me 1/8” birch is one of the best materials to use. For $125 though, I think I’d just grab  pair of the ones in the link. I don’t see an option for the round speaker cutouts though as found on the higher trims.
This came to my email yesterday, Nov 25. The email has pictures but I could not get those to copy and paste here.
https://smsautofabrics.com/
https://smsautofabrics.com/?mc_cid=ae0c544c91&mc_eid=25f860bed2
Lock in Door Panel Prices Now!
Dear xxx ,
After several years of resisting inflation, we’ve finally faced the difficult reality that we’ll
have to significantly raise door panel prices on January 1st, 2025.
If you have already received a door panel quote, or still need to receive a quote, you have until
the end of the year to place an order and lock in our 2024 prices before the prices go up.
We always keep our prices as low as we possibly can, but each custom-built set of door panels is
highly labor intensive and requires specific materials and tooling, and inflation has hit these
areas especially hard.
Price increases are never pleasant, but in order for us to keep offering the showroom quality
factory-correct door panels we have become known for over the last 30 years, we’ll be raising our
door panel prices on January 1st.
So get your order in by the end of the year to lock in our 2024 prices. We appreciate your business
and your understanding!
HOW TO ORDER:
Call us: +1 503-263-3535
Email us: info@smsautofabrics.com
Visit our website to get your FREE SAMPLES before ordering
View email in browser
SMS Auto Fabrics · 350 South Redwood Street · Canby, OR 97013 · USA
update your preferences or unsubscribe
Lock in Door Panel Prices Today! 🏷️.pdf
I made mine out of treadbright aluminum. But seen em made of panel wood. Just remove the vinyl then remove the staples holding the cardboard from the plastic door top liner and use it as a template. Then cut it out an paint or cover stick tye plastic piece on door and screw the card in place. They are easy to make.
