eaglescout526 Posted November 24 Share Posted November 24 What job does each of those relays have inside? Link to comment Share on other sites More sharing options...
Gjeep Posted November 24 Author Share Posted November 24 These are only present HO years in this location -- 2 are factory (dash illumination & horn) and 2 are from me (starter kill & dome light supervision when doors unlocked). 4 relays fit there perfectly without hitting metal support structure of main dash. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 24 Share Posted November 24 Neat!! Didn’t know that. Link to comment Share on other sites More sharing options...
NickyV Posted November 24 Share Posted November 24 Is the starter kill a security feature? I've been thinking about how to add an extra layer of protection to my MJ besides Ye Olde Club. Link to comment Share on other sites More sharing options...
Gjeep Posted November 24 Author Share Posted November 24 Not from the factory. Its a me add on via an old Viper brand alarm. Jeep did have a problematic security system in 91/92 for the higher end XJs but the MJ never got it. And majority of XJ owners I understand uninstalled it because it was leaving them stranded. I wanted all the lock/unlock features of a ‘modern’ truck since I took the time to add power windows and door locks. There are a couple ways can wire a kill switch solo though. Link to comment Share on other sites More sharing options...
jodawill Posted November 25 Share Posted November 25 On 12/23/2024 at 5:18 AM, Gjeep said: Key Parts parts installed – new set of repop taillights and linkage bumper set. As always, I try to avoid installing with rivets, so a stainless steel truss screw was used instead. This MJ will also get a power actuated tailgate lock similar to my other MJ tied into the power door lock wiring. The wiring isn’t as pretty as in my other MJ as I am constantly reminding myself to keep the focus of this build as a runner – an MJ to be used. Full window upgrade installed and working. 97+ XJ door handles were installed as I like the look of them over the original. New door to body bumpers and various plugs installed, in addition to fresh door lock cylinders to replace the brittle factory installs. And finally, the floorboard was POR15'd for a long and rust free life. Where did you get those tailgate bumpers? I see some on eBay for $40. I'm not sure what the quality is like. Edit: I found a post about the Key Parts one on eBay. It sounds like that's the closest to the OEM parts, so I ordered them. I'm glad I saw your post! I didn't know you could buy those. Mine are in rough shape. Thanks! Link to comment Share on other sites More sharing options...
Gjeep Posted November 27 Author Share Posted November 27 I got to cutting on an XJ roof rack for the MJ 80’s inspired light bar. Lots still to do around drilling another mounting hole on each rail, strategy around the holes needed for wiring and overall clean-up/ paint. Here she sits – not attached to the roof at all hence the gap between the roof and roof rack rail. I’m feeling good about this light bar, just not looking forward to drilling the hole at an angled surface… Also finally got around to bleeding the brakes after all the new parts were installed months back. Had a heck of a time with the front passenger line not bleeding/ getting any fluid. Zip. Nada. Never had something like that happen before so I took to Googling — the answer and fix — stomp on the brake pedal repeatedly. It resets the proportion valve to all open. Like I said, first time I experienced an issue like that. Brake booster (’95 XJ) and proportioning valve (’88 XJ) were NOS. Plug for the Motive Bleeder. I’ve been using mine for at least 20 years and it’s great. They sell different auto manufacturer caps to work with their main canister. Link to comment Share on other sites More sharing options...
Gjeep Posted 1 hour ago Author Share Posted 1 hour ago Finally got to it – AC is charged; R134a conversion using factory ’95 XJ parts as in my other MJ. Hard to tell how cold it truly blows as it’s at best 50* here currently. If the temperature gun I used was correct, the MJ was blowing 38* yesterday but want to confirm. Will retest. Where’s the sun when you need it... Testing the HVAC wasn’t without its challenges, as I could get the bezel control to open/close any of the doors. Pulled the vacuum lines off the back of the bezel and nothing. Assumed a vacuum leak but couldn’t find any. After walking away for a bit I thought I’d take a double-take at the check valves – one off the intake manifold and the other near HVAC side firewall. What was there I didn’t recognize. I pulled them both and noticed how tiny the port was where vacuum passed. Replaced them both with parts bin factory check valves and all started working again. Curious though for any who own a ’91 MJ if yours has these same check valves from the factory. I don’t recognize them. First pass at drilling holes on the lightbar I’m building out of an XJ roof rack, and everything worked out. I’ll be running wiring through the driver’s side channels near invisibly. You can see the small hole in the end cap it will run through then into the roof. They still need to be cleaned up and painted. Also got to rewiring the IPF headlight harness as it doesn’t play well with the Holley RetroBright headlights I’m going to be running. The IPF harness is great for standard headlights but doesn’t run its power correctly for the MJ to use RetroBrights with it. Kudos to Red Mistress for giving me the heads up on these. All my Jeeps will be getting a set. Link to comment Share on other sites More sharing options...
