Eagle Posted June 13, 2024 Share Posted June 13, 2024 When not hanging out here, I sometimes lurk on a forum for authors. A young woman on that site recently contacted me because she somehow thought I know something about welding. Since I can't recall ever mentioning welding on that site, I think she has me confused with someone else. But, I would like to help her with the question. She asked if there is an industry name or term for a bumpy weld, like this: Does a weld like that have a name? TIA Link to comment Share on other sites More sharing options...
jdog Posted June 13, 2024 Share Posted June 13, 2024 It's been a while since I have welded but those look like stitch welds to me Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted June 13, 2024 Share Posted June 13, 2024 I think @jdog is right. It's a technique where you place tack welds spaciously over the cutout region between the patch and the larger metal. You eventually fill the interface between the two materials, but you keep adding tack welds as far apart as possible in effort to even out the heat generated, prevent warping and lower the chances of punching through. This method is usually done on thin metals. It is tricky to get right. Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 13, 2024 Share Posted June 13, 2024 @neohic would know, he was a welding instructor. Link to comment Share on other sites More sharing options...
neohic Posted June 13, 2024 Share Posted June 13, 2024 Everything checks out in the above comments to me. Stitch welds… trigger welds… body work welding… it’s a series of tacks to control warpage by jumping around the part. This typically isn’t the type of weld that goes without sanding/finishing. Link to comment Share on other sites More sharing options...
derf Posted June 13, 2024 Share Posted June 13, 2024 2 hours ago, neohic said: Everything checks out in the above comments to me. Stitch welds… trigger welds… body work welding… it’s a series of tacks to control warpage by jumping around the part. This typically isn’t the type of weld that goes without sanding/finishing. What he said... Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 13, 2024 Share Posted June 13, 2024 As a person who has a lot of this sort of welding, I've just now learned what it's called! Link to comment Share on other sites More sharing options...
EUREKA Posted June 13, 2024 Share Posted June 13, 2024 My father owned a custom metal fab shop and I was a welder for years. I call it stitch welding. It's many tack welds. Link to comment Share on other sites More sharing options...
