pizzaman09 Posted October 28, 2024 Author Share Posted October 28, 2024 The Comanche has been running great. Used it at the property the other day cleaning up brush and dragging the utility trailer up and down the hills to the burning pile. Link to comment Share on other sites More sharing options...
pizzaman09 Posted October 28, 2024 Author Share Posted October 28, 2024 Managed to catch a picture of the Comanche in the middle of a sundog. Also random other view Link to comment Share on other sites More sharing options...
Drahcir495 Posted November 2, 2024 Share Posted November 2, 2024 On 5/13/2022 at 10:53 AM, pizzaman09 said: Had to get a replacement new expansion tank. First one from Rockauto had a crack at the molding seem. I never noticed that the coolant was jetting out of the bottle . You have done quite a bit since I replied earlier. Great work Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 2, 2024 Author Share Posted November 2, 2024 14 hours ago, Drahcir495 said: I never noticed that the coolant was jetting out of the bottle . You have done quite a bit since I replied earlier. Great work Thanks! The Comanche has been quite reliable since I got the cooling system sorted. Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 8, 2024 Author Share Posted November 8, 2024 Changed my engine mounts today, they had definitely met removal criteria. Original mounts from 1989! The new mounts were factory style replacements and they are awesome! So much smoother. Most noticeable though is that it shifts into gears so much nicer! Link to comment Share on other sites More sharing options...
JZLAJeep Posted November 8, 2024 Share Posted November 8, 2024 18 minutes ago, pizzaman09 said: Changed my engine mounts today, they had definitely met removal criteria. Original mounts from 1989! What the?!? Having owned an XJ for the last 23+ years, changing motor mounts has become routine maintenance after that time one motor mount failed completely and the shifter was over in the passenger seat... Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted November 9, 2024 Share Posted November 9, 2024 17 hours ago, pizzaman09 said: Changed my engine mounts today, they had definitely met removal criteria. Original mounts from 1989! The new mounts were factory style replacements and they are awesome! So much smoother. Most noticeable though is that it shifts into gears so much nicer! Mine looked exactly like this when I removed em I replaced them with used genuine motor mounts from a ~00 TJ. Who knows how they will hold up, but they may outlast the clone mounts of unknown quality. I really wish keyparts would clone the motor mounts. I'd grab like 4 sets for keepsies. Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 20, 2024 Author Share Posted November 20, 2024 Upgraded the breather to have a GM style PCV and replaced the air filter. I did this same PCV mod on my first Comanche and it completely fixed the oily filter issue. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted November 23, 2024 Share Posted November 23, 2024 On 11/20/2024 at 5:52 PM, pizzaman09 said: Upgraded the breather to have a GM style PCV and replaced the air filter. I did this same PCV mod on my first Comanche and it completely fixed the oily filter issue. Woah, you have some details about this? My new dorman PCV tube expanded at the valve cover after 1 year and I had to add heatshrink to the tube to pickup the sloppy fit. It works fine but I don't mind learning about alternatives Thanks Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 23, 2024 Author Share Posted November 23, 2024 47 minutes ago, Salvagedcircuit said: Woah, you have some details about this? My new dorman PCV tube expanded at the valve cover after 1 year and I had to add heatshrink to the tube to pickup the sloppy fit. It works fine but I don't mind learning about alternatives Thanks This time around I simply cut the doorman Renix 90 degree elbow off about 0.08" above the upper flange of where it goes into the valve cover. The hole in that remaining piece is the perfect snug fit for the GM style PCV. https://www.autozone.com/emission-control-and-exhaust/pcv-valve/p/duralast-pcv-valve-pcv1214dl/830774_0_0?spps.s=1843&cmpid=LIA:US:EN:AD:NL:1000000:FLT:19489353541&&CATARGETID=120054150001289815&CADevice=m&gad_source=1&gclid=CjwKCAiA9IC6BhA3EiwAsbltOIUXIZGsQ4onUxbn7kMhR6ywKLHTWANKi4vz2KkVlGceaMG6DrMoYBoCHNIQAvD_BwE&gclsrc=aw.ds The barbed fitting is for a 3/8" ID hose. The Renix plastic tube is 1/2" OD. I took a piece of 3/8" ID hose and slid it over the barn, then a piece of 1/2" OD hose on that and connected it to the plastic line. I used silicone spray to lubricate everything to get the hoses on all fittings. Everything was pretty snug. My first Comanche was an interesting story, it had pumped the intake full of probably 1 quart of oil driving from Colorado Springs down to Kansas over a 4 hour drive. We swung into a small town auto store and I asked for a PCV, rubber grommet and air filter for an 88 Comanche. The guy handed me a GM style PCV, some grommet that fit perfectly and an air filter (totalling $6 in 2017). I knew nothing about the crankcase ventilation on a Renix 4.0L, but it already had something like the GM PCV, completely clogged and a very ill fitting grommet involving electrical tape. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted November 23, 2024 Share Posted November 23, 2024 Cool! Thanks for the info. That's a good alternative in case mine fails Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 28, 2024 Author Share Posted November 28, 2024 On 11/22/2024 at 10:08 PM, Salvagedcircuit said: Cool! Thanks for the info. That's a good alternative in case mine fails So, apparently this PCV idea was not a good one. It does indeed prevent oil from getting into the filter. However it prevents vacuum from the back port from being pulled by the intake and has caused my rear main seal to leak substantially more. I've decided to modify the PCV a bit to prevent it from blocking off the flow of air in to the engine. I did this by pounding a 1/4" square drive into the bottom of the PCV so it won't seat and seal off entirely. See photo: Now of course it is the end of the season with snow in the forecast tomorrow, so the truck was washed up and is parked for the winter. The PCV fix probably won't get tested until spring unless I have a major need for a truck this winter. Link to comment Share on other sites More sharing options...
pizzaman09 Posted March 16, 2025 Author Share Posted March 16, 2025 Been upgrading the seats with new upholstery and heated seats! See the build thread! Final seat install. Dash switch location. Link to comment Share on other sites More sharing options...
89 MJ Posted May 31, 2025 Share Posted May 31, 2025 Looks like you were spotted. Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 3, 2025 Author Share Posted June 3, 2025 On 5/31/2025 at 12:57 PM, 89 MJ said: Looks like you were spotted. Hey hey! Yep that's me! Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 8, 2025 Author Share Posted June 8, 2025 Finally did the rear main seal today. So far it doesn't leak! It was previously getting unsustainably leaky. Link to comment Share on other sites More sharing options...
James92 Posted June 9, 2025 Share Posted June 9, 2025 Ah, fun time. I just did mine last weekend! Nice job Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 9, 2025 Author Share Posted June 9, 2025 9 hours ago, James92 said: Ah, fun time. I just did mine last weekend! Nice job Nice! It's a satisfying job to finally get done. Link to comment Share on other sites More sharing options...
pizzaman09 Posted September 19, 2025 Author Share Posted September 19, 2025 The output shaft of my transfer case has been leaking, even though I changed the seal. So I figured the bearing was bad. Changed them both out today and low and behold, now the truck doesn't shudder when pulling away from a stand still. A little write-up is below. I had drained the T-case fluid and removed the drive shaft and tail cone. As you can see there is some wear on the original 275k mile bearing. I used a screwdriver and a hammer to work the old seal out, this went well as I only out the seal in last year. A 30mm socket, the same used for removing the drain plug from the NP231 T-case, fit nicely to remove the bearing. I started it with a hammer then moved to pressing it out in a vice. I did find that my new bearing on the right was a tad shorter than the original. I used a piece of bronze that I had laying around to drive the new bearing in with a hammer. The new seal got pressed in via the vice and a flat plate to prevent damage to the seal and a block of wood under the other end of the cone to also prevent damage to the sealing surface. I used a touch of RTV between the T-case and cone and a bit of blue Loctite on the three bolts. Make sure when reinstalling to point the drain slot down in the cone, I am not certain but it looks like one could clock it upside down and that might cause fluid to build up against the seal and not drain back towards the T-case. Link to comment Share on other sites More sharing options...
Drahcir495 Posted September 19, 2025 Share Posted September 19, 2025 Your interior is Very nice Link to comment Share on other sites More sharing options...
pizzaman09 Posted September 20, 2025 Author Share Posted September 20, 2025 1 hour ago, Drahcir495 said: Your interior is Very nice Thank you! At this point the only items left to address in the interior are the cracked dash and very worn out steering wheel leather. Link to comment Share on other sites More sharing options...
pizzaman09 Posted February 15 Author Share Posted February 15 After cleaning the Comanche up from the two times I drove it this winter, it has finally received new front brake calipers. Hopefully this solves the sticking caliper issues it has. Also started to work on reducing the oil leak out of the valve cover breathers. I drilled out the restrictor fitting and used a much larger tube to the intake manifold. It now pulls much harder vacuum on the valve cover and still idles at 650-700 rpm like normal. We'll see if it has any rev hang but I kind of doubt it. I had plans on putting a catch can in however there is now so much vacuum that it actually pulls from the air filter rather than pushes to the air filter. Link to comment Share on other sites More sharing options...
pizzaman09 Posted March 1 Author Share Posted March 1 Finally doing rear drum brakes. Purchased mostly new hardware. I wasn't going to do the drums but decided to order some after taking the old ones off. Also ordering some axle shaft seals. Also choose to do rear parking brake cables, I am excited to have a good parking brake rather than one that a small child could push the truck around with it engaged. Link to comment Share on other sites More sharing options...
pizzaman09 Posted April 29 Author Share Posted April 29 Driving home yesterday, I found the ignition key was stuck in the run position and I could not turn the truck off. I pulled main coil wire at the distributor to shut it down and the battery ground to turn everything off. Ended up tearing out the steering wheel and putting a new ignition cylinder in. It was less challenging of a job than expected. Took the opportunity to clean and lubricate the turn signal mechanism that had a lot of crusty old grease on it. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted April 30 Share Posted April 30 On 9/19/2025 at 6:31 PM, pizzaman09 said: The output shaft of my transfer case has been leaking, even though I changed the seal. So I figured the bearing was bad. Changed them both out today and low and behold, now the truck doesn't shudder when pulling away from a stand still. A little write-up is below. I had drained the T-case fluid and removed the drive shaft and tail cone. As you can see there is some wear on the original 275k mile bearing. I used a screwdriver and a hammer to work the old seal out, this went well as I only out the seal in last year. A 30mm socket, the same used for removing the drain plug from the NP231 T-case, fit nicely to remove the bearing. I started it with a hammer then moved to pressing it out in a vice. I did find that my new bearing on the right was a tad shorter than the original. I used a piece of bronze that I had laying around to drive the new bearing in with a hammer. The new seal got pressed in via the vice and a flat plate to prevent damage to the seal and a block of wood under the other end of the cone to also prevent damage to the sealing surface. I used a touch of RTV between the T-case and cone and a bit of blue Loctite on the three bolts. Make sure when reinstalling to point the drain slot down in the cone, I am not certain but it looks like one could clock it upside down and that might cause fluid to build up against the seal and not drain back towards the T-case. I definitely need to do this. Thanks for the writeup Link to comment Share on other sites More sharing options...
