Whitaker717 Posted April 23, 2022 Posted April 23, 2022 I am looking to replace all the window seals in the Comanche. I have some some research and came across some old ones. HAs anyone done this project in the last year or so, and if so is there a kit I can buy that has everything in it. Thanks guys.
JimiGibbs Posted April 23, 2022 Posted April 23, 2022 I bought this one a while back..... Have not installed it yet. Waiting on a paint job. https://www.jegs.com/i/Precision/757/DK+6110+84/10002/-1
Gubachoo Posted October 29, 2023 Posted October 29, 2023 Reviving this topic, anyone put these in or others and had good or bad experience. Just got mine painted and want to do them this winter. Any other tips or part suggestions?
Pete M Posted October 29, 2023 Posted October 29, 2023 I just last month used the Jegs kit. went on fine. though I found that the order in which you install them is very important if you only want to take it all apart once. while you're disassembling the door, take the opportunity to do other maintenance like vacuuming out the door and greasing all the moving window parts (including shooting some lithium grease up in the tube).
ghetdjc320 Posted October 30, 2023 Posted October 30, 2023 I ended up using the door portions of the weatherstripping but went with some nos Mopar seals for the cab opening. Perfect fit and worth tracking down.
Gubachoo Posted October 31, 2023 Posted October 31, 2023 Nice. Thanks for the info. I'll see if I can track down now seals. I mostly need iy for the seal on the outside of the window where it meets the door, lower portion. The desert sun has destroyed it
