Smokeyyank Posted February 26, 2022 Posted February 26, 2022 A while back when I was doing the headlight harness upgrade I noticed the radiator had a small pinhole leak in it. I currently do not have any overheating issues but want to be proactive so I don't. So question now is do I convert to an open cooling system or do I just replace the few parts and keep it closed?
jdog Posted February 26, 2022 Posted February 26, 2022 Personal preference really, if the closed is working and you don't have any issues replace with like radiator. If you want a radiator cap and there's more issues then just the radiator go open
phatton Posted February 27, 2022 Posted February 27, 2022 I switched to an open system and the truck runs cooler than it use to. It could be that the new radiator plays a big part, but I prefer the open system.
Smokeyyank Posted February 27, 2022 Author Posted February 27, 2022 Leaning towards open but the whole of ain't broke thing.......I'll more than likely swap it just wanting to gather options.
gogmorgo Posted February 27, 2022 Posted February 27, 2022 In theory you can also future proof with the later radiator and still leave it as a closed system just with added rad cap, leaving the option to go open in the future should you decide to do so.
cruiser54 Posted February 27, 2022 Posted February 27, 2022 I used to recommend leaving the closed system alone. But, I don't anymore. The plastic pressure bottles available now are absolute junk. Take the opportunity to convert now.
89 MJ Posted February 27, 2022 Posted February 27, 2022 10/10 would recommend doing an open loop conversion. It is ridiculously easy. If you use a Renix 2.5 overflow tank, it looks factory too.
cruiser54 Posted February 27, 2022 Posted February 27, 2022 https://www.jeepforum.com/threads/converting-closed-renix-system-to-open-but-have-questions.3685313/
Smokeyyank Posted February 28, 2022 Author Posted February 28, 2022 Great, thanks for the info. As for rads I know it's kind of a crap shoot. Was looking at this one https://www.mishimoto.com/1991-2001-jeep-cherokee-replacement-radiator.html But any other ones to consider? I believe the parts needed are. -rad -rad cap -Overflow -Thermostat housing from a 92+ I also plan to replace the water pump and hoses.
89 MJ Posted February 28, 2022 Posted February 28, 2022 Seems like you have it thought out well. I’m running the Mishimoto in my MJ, no regrets here!
AZJeff Posted February 28, 2022 Posted February 28, 2022 I bought a CSF from Rock Auto about 3 years ago, and found the workmanship (and thus performance) to be totally accceptable. I know that other guys have reported otherwise, but that has been my experience with both my current MJ and my previous XJ. I am a big fan of the open cooling system because they are "self-burping" and thus the issue of air trapped in the cooling system seems to be non-existent.
75sv1 Posted February 28, 2022 Posted February 28, 2022 If you go with a 2 or 3 row, use a MOPAR Clutch fan. The After Market ones are a bit wider. So, no clearance with a 3 row radiator. I have been using the CFS 3 row brass or all metal for over 5 years. I learned the hard way about the aftermarket Clutch fans. That and Death Wobble. DW took out the motor mounts. So, the engine flopped forward. I did have that radiator repaired. But its sitting up stairs above the garage if needed.
